Previous in Forum: carbon credits for steel melting shops   Next in Forum: air pressure
Controller Failure
04/26/2009 8:08 AM
Hi, We had a hotwater system controller failure.I was wondering, generally what could be possible reasons for a controller failure in a plant environment.
Good Answers: 54
Re: Controller Failure
04/26/2009 10:14 AM
Why not start with your own list of possible reasons? I'll just add my own. I'm not going to let you off the hook that easily .
regards,
Vulcan
Good Answers: 38
04/27/2009 12:06 AM
human failure
for the rest.
Not enough data does not compute
04/27/2009 3:28 AM
What sort of failure? Overvoltage? Did someone stand on it and break it?
04/27/2009 11:11 AM
The most common failures typically don't require an explanation. Fork lift collision with hot water heater. Plumber closes wrong valve for maintenance. Those that require more subtle interpretation of the available data require available data.
04/27/2009 11:21 AM
The first thing to look for in hot water systems is the temperature sensors, in which case it is not the controller but the sensors, another possiblility is that the controller may be old and the internal long life battery used to retain programming may have died.
Epke (1); PWSlack (1); redfred (1); Robert Trout (1); Vulcan (1)
