Cryogenic experts,
I am designing a process that uses repetitive cooling of the material to -150C followed by heating it back to 10C many times in a row. The treated material is placed in a closed chamber at variable pressure between one and three bars abs. I intend to use liquid nitrogen flowing through a heat exchanger (inside the isolated chamber) as the cooling media and another one with water to provide the heat. Obviously, I will drain the water before each cooling cycle.
The material inside of the chamber has to go through the thermal cycling without being disturbed. I cannot transfer it between a hot and cold bath as the rate of temperature change has to be controlled at 10C per minute.
I am worried about the thermal stress (-150C to 10C) seen by the heat exchangers and their penetration through the chamber walls. I expect about one hundred cycles a day on a continuous basis. Hopefully for 10-20 years.
Stainless steel and brass are used extensively in my industry. Are these materials suitable at these temperatures? Do you have any suggestion regarding the material selection and especially the types of joints to be used at the chamber interface with the outside world?
Also, do you have any suggestion for the thermal insulation material? My searches have pointed to vacuum double walls, mineral wool, various urethane foams and aero-gels. Each manufacturers claim their product to be the best.
