Previous in Forum: Excess Flow Valve for Spherical LPG Tank   Next in Forum: Sizing a Cable for an Inductor Heater
8 comments
Fishplates vs. Welds for Rails
05/08/2009 3:49 AM
Dear Sir,
What is the necessity for providing fish plate joint in Rail instad of welding the joint
With Regards,
Dinakar.J
Re: Rail
05/08/2009 5:46 AM
  • It is easy to disassemble the joint for maintenance
  • The joint allows rails to slide lengthways with fluctuations in temperature
  • The system is more tolerant to ballast deficiencies
  • The system is suited to lighter sleepers
Good Answers: 103
Re: Rail
05/08/2009 8:56 AM
I remember the answer from my school days, we use to listen then, when they taught about thermal coeff of expansion and one of the point made was the fish plates.
The ballasts and the banking were of course later in class 11 or 12 as I remember when they taught about the noise and the centrifugal forces.
Good Answers: 143
Re: Rail
05/08/2009 8:13 AM
Well...
Re: Fishplates vs. Welds for Rails
05/09/2009 12:37 AM
I assume you are talking about a rail joint in track that is not Continusly Welded Rail (CWR). For a repair or new joint, if you can do a field weld cheaper than drilling two (minimum) holes and installing the fish plates and bolts, that would be acceptable. Just keep in mind that creating long stretches of welded rail can lead to "sun kinks" as shown above if the track structure can't restrain the expansion.
CWR has its beneifts, but comes with its own set of headaches in return.
ASCII silly question, get a stupid ANSI.
Good Answers: 25
05/09/2009 7:07 AM
Hi Dinaakari,
Indian Railways have number factories spread out at number of places like Mumbai,Meerut,Secunderabad etc.where they have Rail Welding factories.Rails are butt welded up to 100 mts length. There are special machines for such job and special wagons and cranes which handle such long rails.
Rails are welded so as to reduce the noise in the running trains, but after each 100 mts fish plate joints are provided for lateral expansion of the rails during hot summers.I hope now matter is clear to you.
Suresh Sharma
05/09/2009 7:54 PM
Rdducing the number of fishplate joints also saves wear on the tires on the wheels. tire maintencnce is an expensive process as the axles have to be removed and sent to a shop with special machine to cut and grind the wheels. I have seen this being done at some place in South India. At the fishplate joint which is I believe after 10 welded rail sections, there is a gap that takes care of the lateral expansion that occurs when a train moves on the rails and they get warmer and expand
vshwn7@aol.com
05/10/2009 5:26 AM
Dear Suresh, Fish plates are provided to resist lateral expansion that will take place in Summers
05/11/2009 4:27 AM
Continuous, long-welded rails [CWR] require more rigorous engineering practices than fishplated rails.
  1. The rail must be stiffer
  2. The sleepers or other carrying devices must be heavier
  3. The ballast must be more plentiful
  4. The rail fastenings must be suitable
  5. The rail must be stretched, usually, when laid (many operations take place overnight) so as to be at a neutral stress point when temperatures rise
  6. "Breather switches" are usually provided where CWR adjoins fishplate-jointed track.
  7. Mechanised track installation and maintenance becomes the norm
To reduce site welds, strings of CWR are made-up in factories by the flash butt-weld process, introducing site delivery complications, and the strings welded at site using the Thermit process. This type of track reduces the requirement for service interruptions for maintenance compared with fishplated track, and reduces the need for maintenance on vehicles, as others have indicated above.
Fishplated track is therefore more suited to places where traffic is lighter, and manual, heritage, maintenance practices are the norm. Most national rail service providers, where speeds are high and traffic is heavy, will provide CWR where possible and economic. The UK's National Rail Track Design Handbook gives examples where fishplated track may be installed new and where CWR should be installed new, so national standards are the best source of information.
Due care must be exercised when forming holes for fishplate bolts to reduce the risk of rail-end breakages from stress cracks. Periodically, the joint must be disassembled for routine inspection and lubrication, which cannot usually be done under traffic.
Other operators have different standards: London Underground, Coras Iompar Eirann (Irish Rail) and various heritage rail operators, for example, will have different applications for CWR versus fishplated track for sound practical and economic reasons, and the balance point between the two types will be different for each one.
The fishplate, incidentally, was patented by William Bridges Adams in the late 1840s.
Register to Reply 8 comments
Anonymous Poster (1); Mark Stockman (1); PWSlack (2); sb (1); suresh sharma (1); TVP45 (1); vishmayor (1)
