Previous in Forum: Fishplates vs. Welds for Rails   Next in Forum: Valves and Flow Coefficients
Sizing a Cable for an Inductor Heater
05/08/2009 3:55 AM
SIR
WE HAVE A PIPE HAVING DIAMETER OF 150MM ANS LENGTH 300 MM AND THICKNESS 5 MM.I WANT RO HEAT THE MATERIAL PRESENT IN THE PIPER/CYLINDER BY USE OF TRANSFORMER ACTION.
i WOULD 60 NOS OF TURNS OF 10 SQ MM ABLE AROUND THE PIPE AND 230 V VO;YAGE APPLIED THE INSULATION GET OVERHEATED.i WANT THE PIPE SHOULD HEATED UP TO 250 TO 300 DEG BUT THE CABLE WHICH IS WOUND AREOUND THE PIPE SHOULD NOT GET OVERHEATED.tHE MATERIAL BEING USED IS COMBINATION OF CASTOR OIL+CAUSTIC AND PHINOL
TELL ME HOW MENY NO OF TURN I SHOULD SELECT?
WHAT SHOULD BE THE SIZE OF CABLE ?
PLZ REPLY
Re: iNDUCTION HEATER
05/08/2009 6:46 AM
Please turn off Caps Lock.
Please advise:
  • The flowrate of the material
  • The percentage make-up of each component of the material, so a mixture thermal capacity can be estimated
  • The start temperature
  • The finish temperature
This will enable a heat duty to be calculated.
After this it is then a matter of selecting the correct heating arrangement for the task.
05/13/2009 5:35 AM
Flow rate 300 Lit/Hr
Capacity 1.5KL
Initial temp 40 to 300 deg to be maintain constant
Regd
Satish Deshkar
Register to Reply 2 comments
