Previous in Forum: Insertion type ultrasonic flow meter   Next in Forum: Reciprocating Compressor Control
10 comments
ABT THE TRANSMITTER
05/17/2009 6:02 AM
PLease tell me how we can calculate the URL value of rosemount trans. smart 1151.
suppose if the calibrated in 1000MMWC then can i use this kind of trans up to 8000MMWC.
Good Answers: 54
Re: ABT THE TRANSMITTER
05/17/2009 7:52 AM
If you have a manual, it will tell you how high you can go. The model number usually will tell you what range you can configure the transmitter to. If the upper limit is 1000mmWC, then it certainly can't be used to go higher than that. If the upper limit is 8000mmWC, it can probably be reranged to 0 to 1000mmWC. Again, the manual will tell you whether that is possible.
regards,
Vulcan
05/19/2009 4:35 AM
yes u r telling right but i have calibrated the 1000MMWC to 5000MMWC so i m unable to identify the accuracy of the transmitter
Good Answers: 54
05/19/2009 11:02 AM
So what's your real problem?
or
Please clarify.
regards,
Vulcan
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
05/20/2009 12:06 AM
what accuracy you need for the given transmitter ??
I think read the instruction maual
how u calibrated the transmitter with druck and muiltimeter or HART??
05/17/2009 10:40 AM
why don't you try it ! I think you play with words Are U working in antartica!!! let me know its very Important for u regards
05/17/2009 8:43 PM
IF U CANT'T GIVE ANY ANSWER THEN PLZ KEEP MOUTH SHUT..................
05/18/2009 2:24 AM
there no question of it ? pl don't mind
I think u r new to this feild
South Africa - Member -
Good Answers: 12
05/18/2009 1:14 AM
Hi there,
As Vulcan said - you cannot calculate the upper range limit of a transmitter. This is a physical property of the transmitter itself.
As stated earlier by Vulcan again - RTFM (read the f#cking manual)
Regards,
Craig
05/18/2009 1:25 AM
Vernac,
05/18/2009 3:40 AM
If all else fails, read the instructions.
Register to Reply 10 comments
akashjain (2); Anonymous Poster (1); craigza (1); find2am (3); PWSlack (1); Vulcan (2)
You might be interested in: Radio Transmitter ICs, Test Sieves, Shaker Controllers
