Previous in Forum: Steam Tables: Specific Enthalpy vs. Specific Entropy   Next in Forum: Crimping Load for Composite Rod
Testing a Nitrogen Pipeline
05/18/2009 8:04 AM
Hi gurus,
Can i test the pipe line with nitrogen as per allowable hydrostatic pressure to avoid hydrotesting,which precuation i need to be taken and which standard allow me to do?
Re: Testing of pipe line with Nitrogen to avoid hydrotesting
05/18/2009 8:16 AM
Surely the point of hydrostatic testing is that it's safer than using a gas?
Gas can give you an explosion as it expands...A hydrostatic failure can still be nasty but you are more likely to get a gush or a flood or a crack rather than a bang...
Please correct me if I'm wrong someone.
05/18/2009 8:43 AM
hi,
thanks for reply.i agree with you that nitrogen can be caused of burst and can i say it is unpractical due to safety point of view but think about it that if suppose it is gas line then it will work on working pressure.then what???????
05/18/2009 8:47 AM
D'uh?
The whole point of testing with something safe at a pressure which exceeds the working pressure, is to avoid a failure when the line is actually working with gas.
Someone help me out here please...fast!
Good Answers: 18
05/18/2009 10:46 AM
"D'uh" says it pretty well.
Nitrogen gas compresses -- water doesn't (much); when bursts occur, water quits blowing out after pressure is released (almost immediately) -- nitrogen does not quit blowing out when rupture occurs; it only quits blowing out when pressure inside pipe is same as outside pipe.
Size of hole and pressure of nitrogen determines speed at which one gets head cut off by blow-out.
Leaks show up easily with water -- leaks do not show up easily with nitrogen.
Re: Testing a Nitrogen Pipeline
05/18/2009 9:57 AM
No, no. You're doing fine.
We'll just be sitting quietly over here, watching the proceedings.
05/19/2009 4:00 AM
The whole point of hydraulic testing is to prove the assembly will withstand the maximum operating pressure plus a healthy safety margin, before the operating fluid is introduced.
Google photographs of "boiler explosions" to see what sort of damage can ensue otherwise.
Good Answers: 18
05/19/2009 8:10 AM
Boiler explosions . . . I remember from my youth (somewhere around 55 years ago ) that a laundry's boiler exploded about two miles away. The "boom" was incredibly loud, considering how far away it was, and it rattled the windows in the house.
My father and brother and I jumped in the car and headed toward where the sound came from and found that it was the laundy that our family used for dry cleaning and with whose owners we were friends. There were broken windows in homes and other buildings as far as two city blocks away. The rear half of the laundry building was blown to smitherines.
Anonymous Poster (1); Bill (2); PWSlack (1); saleem arain (1); user-deleted-1105 (2)
