Here are two images of a slot car 'wing car' and a Formula One car:
Obviously, the designs are completely different. Slot cars are considered to be 'toys' by many people, but scale models have been used throughout history to study theoretical principles in almost every design ever made. In this case, one obvious difference between the two designs is the massive side panels on the slot car body. If you take these side panels off the slot car, it will slow down tremendously. So, here's my question for today: If you took two simple flat panels of clear polycarbonate plastic and attached them to the sides of an F1 car vertically, like the slot cars, would it go faster? Forget the rules, I know they wouldn't be allowed. This is just something to think about from a theoretical standpoint, and there may be other classes in racing where this would be allowed. If it makes such a tremendous difference with slot cars, why wouldn't it work with full-sized cars? And while I'm at it, if you took a simple 1' by 1' flat panel and attached it to the nose of an F1 car vertically to act as a front mounted rudder, and then hooked it up to the steering system so it moved when the steering wheel turned, would the added aerodynamic side force on the nose help it corner? Would the added weight of the rudder be compensated for by better handling? Again, forget the rules, this is just something to think about over coffee. I think too much, I think. By the way, did you know that the barcodes on the Ferrari cars are apparently code for 'Marlboro', one of their sponsors? Some tracks don't allow advertising for tobacco products, so Ferrari fooled them by spelling it out in barcode...
"I don't think, therefore I am not" - Rene Descartes negated
