Previous in Forum: "Does a DC motor run on AC current"   Next in Forum: synchronizing Diesel Generator
27.5 Volt dc series motor speed control
05/23/2009 5:53 AM
Dear Sir,
I have a 27.5 volt, 1.1 amps, 10,000 rpm, carbon brushed dc series motor. I want to use this motor in a small car on 24 volt battery supply. I need circuit diagram of speed control circuit (bydirectional) for this motor. Please send me this circuit diagram.
I shall be thankfull to you
Pathfinder Tags: nazir
Good Answers: 53
Re: 27.5 Volt dc series motor speed control
05/24/2009 7:22 AM
This old thread should be able to answer your question.
http://cr4.globalspec.com/thread/34610
05/25/2009 7:20 PM
anjum; you got answers on speed control, i did not see one on reversing control, you will need a 4 or 6 leads/terminals to reverse motor. perry
Good Answers: 53
05/26/2009 10:51 AM
DPDT Switch between circuit output and motor can work.
Register to Reply 3 comments
You might be interested in: DC Motor Drives, Circuit Breakers, Motor Test Equipment
