Previous in Forum: neutral cable to earth   Next in Forum: tones
14 comments
DC/DC Regulator Schematics
03/10/2009 5:25 AM
Does anybody have electrical drawing of DC/DC regulator for baby motorcycle or web page
Battery is 18V and DC motor is 15A.
Zele
Good Answers: 53
Re: DC/DC Regulator Schematics
03/10/2009 11:19 AM
Instead of using DC Regulator you may control it better with pulse width controller like in block diagram
03/11/2009 2:02 AM
Mr. rakesh ,thanks for your answer.
Zele
05/26/2009 7:04 AM
Mr. Rakesh Thanks for good idea
Anjum
03/10/2009 10:51 PM
Did rakesh_semwal mis the actual question here? Are you looking to regulate the speed as rakesh_semwal shows in the diagram he provided or are you trying to charge the battery?
Good Answers: 53
03/10/2009 11:36 PM
No, It control the amount of energy by making power on and off, with changing pulse width.
Regulators drops voltage and that make it less energy efficient, where as here we are controlling duty cycles that make it more efficient,
Good Answers: 53
03/11/2009 12:03 AM
Just want to add, The potentiometer used in ckt is for the speed control.
03/11/2009 2:16 AM
Mr. rakesh
Block diagram is OK for understanding but do you have elect. shematic diagram or do you know any web page where I could buy it.
Zele
Good Answers: 53
03/11/2009 2:52 AM
Answer I posted was conceptual and you may need to do little bit R&D on it, There are three basic component
Timer IC NE555 to make a square Wave generator and then converted to saw tooth or triangular.
Comparator LM358 That will convert triangular input in to square wave again that with the adjustable duty cycle.
Power Transistor to Drive your motor.
If you will take these three segment separately,then it can be much easy for you to search and find out some details or web.
03/11/2009 1:59 AM
Mr. rakesh semwal is recognized my question. I really need speed regulator
Zele
03/11/2009 3:43 AM
It is better and simpler to use a ready made controller.
A very good one ( 8,4 - 36 Volts and until 45 Amps ) designed right for the DC brushed motors , you can find at the link below :
(you need to use "search" feature for the item named 'Navy Control 570 ') !
http://at.robbe-online.net/rims_at.storefront/49b769680023dd67271b3e0dc1460697/UserTemplate/1/?ISID=49b769680023dd67271b3e0dc1460697
Good Answers: 53
03/11/2009 4:24 AM
What if the OP want to make it himself for his learning? Its a cut and paste solution that can make him a good purchase manager but not good engineer.
03/11/2009 6:45 AM
Mr. rakesh
Thanks for your advise, thanks for your comments about my problems.
Zele
03/11/2009 8:23 AM
I am sorry but i did not understood that Mr. Zmahmet want to make himself the device. It is for his baby which do not intend to wait so much.(the device is not quite easy)
03/11/2009 10:57 AM
Well, this sounds like something a person should be paid to do. Instead of hiring someone, I recommend you look into the web sites for Analog Device, Texas Instruments, National Semiconductor for switch mode power supply designs. These companies are more than eager for you to use their products. You should expect to fail in your initial choices, for this will be a learning experience for you.
Register to Reply 14 comments
Anjum (1); Anonymous Poster (1); mrt (2); rakesh_semwal (5); redfred (1); zmahmet (4)
