Previous in Forum: Connecting a Shaft to Servo Gearbox   Next in Forum: Scraped Surface Heat Exchanger
8 comments
Valve Bypass
05/28/2009 7:04 AM
What is the use of providing Bypass arrangement in the valves?
Re: VALVES
05/28/2009 7:07 AM
What valves?
Good Answers: 103
Re: VALVES
05/28/2009 7:37 AM
Bypass arrangement?
or balancing lines?
Re: VALVES
05/28/2009 11:05 AM
hi chandrakumear:
you can repeat your equ. for more to appear what are you need exactly?
Iove all
Good Answers: 18
Re: VALVES
05/28/2009 11:38 AM
Usually used for balancing hot/chilled water systems.
Re: Valve Bypass
05/28/2009 10:19 PM
We does not have clear picture regarding your By Pass Valve.
If I am not mistaken, I do believed that, your By Pass Valve is for piping.
If so, the actual usage of the by pass valve is to by pass the flow, in case if you need to do some repair at the main valve.
For example in the water filters system,
I do not know if you had see a water filter system before. In this water filter system, the inlet pipe is connected to a TEE and a inlet valve before to the water filter inlet.
At the outlet of the water filter, it also connected to a outlet valve and a TEE and the final pipeline will be to your machine or your consumption.
So,.. At both TEE it will be connected to a valve call the By Pass Valve.
The function of this By Pass Valve is for you to by pass the water flow, without going thru the filters while you can dismantle out the water filters for services, repair or whatever thing you want to do with it.
Most of the By Pass Valve is use for emergency by pass, in case there is a need for some emergency repair need to be carry out on the spot.
Good Answers: 19
Re: Valve Bypass
05/29/2009 12:25 AM
You mean by-pass of a Pressure Reducing valve or Temperature Controlling Valve? This is done with 3 Valves to isolate the PRV /TCV to take it off the line for repairs in event of malfunction. Similar done for steam traps.
Re: Valve Bypass
05/29/2009 2:07 PM
The bypass is used when the valve needs to be maintained and the fluid flow must continue . The bypass should a manual or automatic control .
Good Answers: 61
Re: Valve Bypass
05/29/2009 5:59 PM
On page 3 of this site:
http://www.ejprescott.com/products/ValvesTap/LargeDiameterDiscValves.pdf
They show large diameter Gate Valves with a Bypass from the upstream side to the downstream side. This Bypass is required because there is too much pressure on the disc when the valve in closed and It cannot be opened. The Bypass bleeds the flow thus the pressure from the upstream side and allow the Valve to be opened.
Is this what you are asking about?
Do it once and do it right
Register to Reply 8 comments
basriraqi (1); Bill (1); ducon (1); PennPiper (1); PWSlack (1); sb (1); Simon Wan (1); Tal (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
