Previous in Forum: The Media Just Doesn't Get Science   Next in Forum: Counterfeit Coin Problem v2.0
55 comments
Good Answers: 150
Rail Gun Designs
05/29/2009 12:52 PM
I'm thinking about building myself a rail gun just for grins. They seem simple enough, a High voltage multiplier connected to a big oil filled capacitor bank that is momentarily discharged through a paramagnetic conductive projectile between two conductive rails.
I've been thinking about the best design for the projectile. For simplicity's sake the crossection will be rectangular. I'm thinking a long dense projectile with torsion spring loaded fins for stability. say half an inch on a side by maybe 2-3 inches long.
Which brings me to the question of materials. the material needs to be relatively cheap, dense, highly conductive, and paramagnetic, or possibly even diamagnetic.
All of the railguns I've seen use aluminum for the projectile. Aluminum is paramagnetic but not terribly dense, but it is very conductive. I'm wondering if an aluminum (or copper) shell with a lead or bismuth core might not be the best of both worlds.
Highly conductive shell (that will carry most of the current through the skin effect) with a heavy dense core for maximum inertia.
For a launcher/injector I'm thinking a small gas gun fired by compressed air on the breech end of the barrel to accelerate the projectile into the rail gun section of the barrel.
For the rails themselves I'm thinking graphite with a copper bus bar behind it.
Anybody have any thoughts? Or know where I can find some cheap surplus HV oil filled capacitors?
Also I need to contemplate how to measure the speed of the projectile, I understand typical ballistic chonographs don't work, not sure if it is due to the muzzle flash blinding the optical sensors, or if the EMP is screwing with the electronics, or if the projectiles just move too fast to read, or some combination of the three. Most top out at 7000fps. Any ideas?
Who is John Galt?
Good Answers: 101
Re: Rail Gun Designs
05/29/2009 1:21 PM
No Ideas here, but it does sound like a fun and interesting project. I'll be interested to see how things unfold.
Good Answers: 62
05/29/2009 1:35 PM
I believe our representative from the PI (or RP) has some experience with these - if my memory serves. There has even been some discussion recently....
http://cr4.globalspec.com/thread/8666/Coil-Gun
OK, I was only sorta right
Good Answers: 150
05/29/2009 1:47 PM
Something like this.
I see I made an error in my thinking, since the magnetic field strength is proportional to the current, not the voltage, what I want is not a high voltage capacitor bank, but a (relatively) low voltage high current capacitor bank.
Who is John Galt?
05/29/2009 2:43 PM
Might want to talk to this guy:
No details, speed is unimpressive, but it looks cool.
Charlie don't surf.
Good Answers: 150
05/29/2009 2:55 PM
Coil guns and rail guns are completely different. coil guns utilize magnetic attraction, rail guns utilize the repulsive Lorenz force. Completely different mode of operation.
Who is John Galt?
Good Answers: 50
05/29/2009 11:37 PM
Glad you know the difference... Coil guns seem to have built-in inefficiencies.
But check this out. This was for another thread:
If you're interested I can tell you how Westinghouse powered their rail gun during the Star Wars period.
Good Answers: 150
05/30/2009 12:45 PM
Interested? absolutely! Why, was it a small nuke or something?=D
Something I'm trying to understand. I've asked Mr. Barros but he has not replied yet. Mr. Barros is using a 3.2kV system. If the propulsion is based on current, not voltage, why use such a high voltage system? It seems to me that doing that just makes the system that much more difficult and expensive for (apparently) no good reason. Is there something I'm missing here?
Who is John Galt?
Good Answers: 50
05/30/2009 7:29 PM
I think the reason for the voltage is it helps the current "move" as fast as possible.
Anyway, Westinghouse used a huge, off-center magnetic weight (like the size of a car) that was spun about a shaft. This was contained within a huge cavity containing the coil through which the weight rotated. When they fired the gun, great, big steel breaks were fired at the rotating weight using high explosives, which stopped the weight from rotating almost instantaneously! This caused the field to collapse and create an enormous pulse of current - which was sent to the rails of the gun.
Of course, the whole system was self-destructive, it even split the rails! However, they were looking for not only a weapons system, but a way to put small payloads into orbit.
Good Answers: 150
05/30/2009 7:59 PM
"I think the reason for the voltage is it helps the current "move" as fast as possible."
I'm not sure I follow.
BTW, every time I read your signature line, my mind inserts an "o" in the name, which gives a whole new meaning to the quote....
Who is John Galt?
06/01/2009 9:33 AM
To put it simply, why use high voltage when current makes the field, back EMF. As the projectile accelerates the higher velocity produces a back EMF that cancels the voltage applied and now no current followed by no further acceleration. Now if one really could fabricate an ideal current source capable of fabricating any voltage required to counteract any load, then voltage would not be a problem.
Good Answers: 150
06/01/2009 9:57 AM
Ah, ok, I see what you are saying. I was thinking about this this morning and I also realized that as the capacitor bank discharges, the voltage will fall, which since the circuit resistance is essentially the same (or higher due to erosion and arcing) the current will fall as well. So I would have to design the system so that I have the desired current at the end of the discharge cycle, not at the start and then extrapolate back to the beginning to find the initial charge voltage. If you throw the back EMF into the circuit that makes it even higher. I presume I will need HV/HC diodes connected backwards across the rails to prevent the back EMF from damaging the capacitor bank as well.
Who is John Galt?
06/01/2009 11:41 AM
A consequence of this is you should find that your capacitor does not fully discharge. Keep that in mind when you design your capacitor charge circuit.
You're going to have a devil of a time doing this, so be careful. You say that you don't see the devil yet. Well he's right there, hiding in the details.
Good Answers: 150
06/01/2009 12:16 PM
Yep, that is usually where he hides. He's a crafty bastard too.
I haven't done any significant electronic design in years and I'm really rusty.
Who is John Galt?
06/02/2009 7:55 AM
Might you not start somewhere "safer"? This sounds like a dangerous project....
Good Answers: 150
06/02/2009 8:08 AM
What's the fun in that? =D
I have a healthy respect for High Voltage systems, I've been bit by them before and it is NO FUN. I'm definitely going to follow Nikolai Tesla's excellent safety advice of keeping one hand in my pocket at all times....
Who is John Galt?
06/02/2009 8:19 AM
...like that Captain in the film the "Caine Mutiny", always playing with his "worry balls"?
Good Answers: 150
06/02/2009 10:55 AM
Heh, actually, the reason is to prevent the possibility of forming a circuit that runs from one arm, across the chest, and down the other arm. Such a circuit can lead to cardiac arrest.
Who is John Galt?
06/02/2009 11:18 AM
I knew that having stood on pure rubber mats with my right or left hand in live switchgear on a rocking ship at sea.....the other safely in a pocket.....and two guys watching to make sure none of the MEs try and make contact!!!!
I was actually trying to make a small joke.....
Good Answers: 150
06/02/2009 12:01 PM
Yeah I know.. I was yanking your chain too.
Who is John Galt?
06/02/2009 12:11 PM
You got me!
And there is me thinking that you had no sense of humour!!!
Good Answers: 150
06/02/2009 12:16 PM
In the words of Tommy Lee Jones in MIB....None that I am aware of....
Who is John Galt?
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
06/02/2009 12:23 PM
So if I touch my deer fence with both hands, It could be my last screw up. Thanks for the tip. I just touched it with one hand , accidentally, today. I was barefoot at the time. Good thing deer don't have hands. Well, the venison would be nice.
Good Answers: 150
06/02/2009 12:27 PM
Nope touching it with both hands probably wouldn't be much worse than with one hand since the fence is at the same voltage potential. now if you had one hand on the ground and one on the fence, THAT would be dangerous.
Who is John Galt?
06/02/2009 12:39 PM
Neither one or both hands will be lethal. The deer fence supply designers specifically made it to not sustain enough current to be lethal. It's a deer deterrent, not a harvester. Rather unsporting idea if you ask me. Luring a deer to a multi kilovolt wire with multi kilowatts of power available.
Good Answers: 150
06/02/2009 2:15 PM
Depends, it would probably be lethal to me because of my heart problems, there are a lot of people who have irregularities in their heartbeats that don't realize that they have them. I certainly did not know until I was in my mid 30's. Kids die every year in school athletics because their heart went into fibrilation, and nobody knew they had anything wrong with them until the day they died. Texas has started requiring an echocardiogram for school athletics which will catch some things, but what is really needed is a T-wave alterans stress test, but those are expensive.
Who is John Galt?
06/03/2009 5:15 AM
On the other hand I read about a fellow who was cured of chronic fatigue syndrome after he received a jolt from an electric fence.
I suspect coincidence but maybe it works.
Fun to watch
Good Answers: 62
06/02/2009 12:58 PM
My now wife was approaching the hot wire that kept the cows out of the yard
I yelled "Watch the hot wire!" knowing only that she had grown up in Texas and every Texan knows what a hot wire is....
After she got back up I found out she grew up in the suburbs of Houston.
06/02/2009 1:03 PM
Of most humble husbands know when to laugh only on the inside.
Good Answers: 62
06/02/2009 1:38 PM
I was saved by my ability to not laugh out loud
as well as the plastic sign she reached over with the lightning bolt that said "Warning - Electric Fence - Shock Hazard!"
But that ability you refer to? She calls that the benefit of getting a husband "previously trained".
Good Answers: 150
05/29/2009 2:57 PM
ooh, just had a thought, what about a blank pistol/shotgun round for the injector? Hmm...
Who is John Galt?
Good Answers: 16
05/29/2009 3:45 PM
Would bronze do for the projectile? I know it's conductive and non magnetic. Al-bronze. K bronze, S bronze, Berrilium-Copper? All available as 20' bar stock. Anything else for that matter.
Sounds like fun!
De gustibus non est dispudandum.
Good Answers: 150
05/29/2009 5:27 PM
I think using anything with beryllium in it would be a VERY BAD idea. These things vaporize the rails and armature (projectile) when they are shot. beryllium vapor would probably ruin your whole day (life actually). NOT SAFE.
Conductivity of the projectile is of paramount importance. That means you are pretty much restricted to gold, copper, silver or aluminum. And even then, you want them to be as pure as possible for maximum conductivity. aluminum is chosen because it's melting point is lower than the rails, it becomes the sacrificial member.
Who is John Galt?
05/29/2009 7:10 PM
You have too much time on your hands.
Good Answers: 150
05/29/2009 7:48 PM
Now I could see a sintered composite of tungsten carbide in a pure aluminum matrix as a projectile. Perhaps with a solid tungsten core.
Who is John Galt?
Good Answers: 52
05/29/2009 11:25 PM
Nope, depleted uranium is the way to go, sheathed in aluminum. The aluminum can be swaged over the DU chunk. Stand clear!
Mark
Good Answers: 150
05/30/2009 10:08 AM
On general principles, I'd agree with you, but getting my hands on DU might be somewhat problematic....
Who is John Galt?
Good Answers: 52
05/30/2009 11:13 PM
Easy peasy ... a quick holiday to Iraq or Afghanistan with a small radiation counter will let you pick up the correct DU chunks everywhere there has been artillery. Larger chunks as the armor from all kinds of vehicles.
http://en.wikipedia.org/wiki/Depleted_uranium
Mark
Good Answers: 150
05/30/2009 11:34 PM
Yeah but then you have all the uranium dust to deal with too.... I'd just as soon pass, unless I really need to pierce armor or something.... but then the armor itself would probably be lousy with DU as well.
Who is John Galt?
Good Answers: 32
05/29/2009 11:40 PM
Interesting ideas.
Aluminum looks a nice idea if used as thick surface coating and if it melts then by wetting will provide better contact also. You still have to have high density for the projectile so inner core need to be heavy, non-toxic and also cheap. I think it is a nice idea to build these machines in small working model.
05/30/2009 5:06 AM
What have you got? Bad neighbours maybe?
Good Answers: 150
05/30/2009 10:16 AM
Naw, I love my neighbors. They are quite literally the best anyone could hope to have. I'd say we're practically family, but I don't much like my family...=D
I just like things that go boom, I also like to be able to reach out and touch things at a mile or more.....
Besides, if the revolution ever does come, it might be a handy bit of kit....
Who is John Galt?
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
05/30/2009 2:57 PM
yeah, those mexicans who trying to cross the border into texas. you need to arm yourself these days know.
Making mistake is part of learning.
Good Answers: 150
05/30/2009 7:00 PM
Who is John Galt?
05/31/2009 6:48 AM
See! I just had my imagination running wild.
I believe the Infra cam was developed to watch the mexicanas crossing your border at night, am I right?
Good Answers: 150
05/31/2009 11:45 AM
That camera is a waste of money, by the time anyone can get there, the invaders are long gone. people don't realize just how huge and desolate west Texas is. you've got one deputy for every 500 square miles if you're lucky. The smugglers just smile and wave at the camera, or they cross a half mile further away and avoid the camera altogether.
Who is John Galt?
05/31/2009 10:39 AM
By reading your link it really makes me convinced that not even Texas is spared by those men behind the curtain which often turns things upside down and beyond comprehension until you see it to believe it.
(I honestly felt that Texas was one the handful of finest places on earth - not just in western movies.)
05/30/2009 5:14 AM
Maybe you need to hook up with this guy.....
Best of luck, but don't point it my way!
Do it while you still can!!
05/31/2009 1:39 PM
I'd lean more towards a superconducting coil gun myself. Something that would pump out steel ball bearings at serious velocity and a high rate of fire.
You could probably build a railgun with junkyard parts easier, though.
How about designing the railgun around a standard model rocket, then building the rocket out of aluminum tubing with an aluminum nose cone? The model rocket engines will inject the projectile into the accelerator, then continue acclerating it after it leaves the barrel. You might need to redesign the rocket nozzle to a De Laval type nozzle to maximize gas velocity. Can you say 'kinetic-kill weapon'? No illegal components, so the ATF can't complain.
For a timer, use a couple of laser pointers and old-fashioned photocells. Measure the exact distance between the points where the projectile will intersect the lasers. Write a BASIC or other program that starts a counter when the first photocell stops receiving light, then stops it when the second one stops receiving light. Figure the clock speed of the counter, and you have the time it took the projectile to go from A to B.
ASCII silly question, get a stupid ANSI.
Good Answers: 150
05/31/2009 7:38 PM
I'm pretty sure the muzzle flash would blind any optical sensor, which is probably why standard chronographs don't work.
Who is John Galt?
06/01/2009 6:57 AM
I was thinking in terms of putting the photocells at the bottom of a piece of pipe or some such to shield them, hence the laser pointers.
05/31/2009 2:57 PM
I forgot to give you this link http://en.wikipedia.org/wiki/Rail_Gun after read it.
It is a good stuff but you'd need a bit of juice to run it.
06/03/2009 5:20 AM
I'd apply WAQAP principles ('Wrong As Quick As Possible', intellectual property of KrisDelTM corporation)
Build a small test version, you will doubtless learn more from a small (safer) test rig than you will from a shed load of research.
It has the added advantage that materials and components will be cheaper and more readilly obtainable.
Also we'll get to see some results quicker....
Injector could be a simple spring or even a sharp tap with a hammer.
Good Answers: 150
06/03/2009 8:23 AM
I'm thinking a gas piston operated semi-auto mechanism for the injector that will load a new projectile into the breech with each shot from a gravity fed magazine..... I plan on building a "hot rail" design so it is just a matter of injecting the next projectile after the cap bank has recharged....(assuming the rails aren't damaged.)
This sort of gun does not scale down terribly well imho, you've got to have a strong enough current to generate enough force to move the projectile. That means that the rails have to be big enough to handle the current, but they can't be too big or the centerline of the field is too far away from the armature.
All that said, I don't plan on building a big one. Probably about the size of the one Sam Barros did, but with some tweaks. For instance, I'm thinking of using Argon as the injector gas. I'm thinking that it would form a plasma easier between the armature and the rail and make for more efficient current conduction than plain air would. It would also prevent the formation of nitrides on the rail surfaces.
I'm also thinking of altering the rail geometry at the muzzle to prevent a lot of arcing as the armature leaves the gun.
Sam used 32 6800uF 400V caps in a series paralell array, but those caps aren't cheap. I'm thinking lower capacitance caps and more of them. that should increase the amount of current they can instantaneously supply, if nothing else it makes it cheaper.
Who is John Galt?
06/04/2009 5:29 AM
Neon may work better than Argon and shouldn't be too hard to get.
Good Answers: 50
06/04/2009 1:59 PM
Make sure to tie a string on your projectile... Connect the other end to the rail gun. That way you can use it more than once.
Register to Reply 55 comments
Andy Germany (5); Anonymous Poster (1); edignan (3); Isti80 (3); lyn (1); Mark Stockman (2); MauriceS (1); redfred (4); Relativity PL (2); ronwagn (1); Rorschach (22); RVZ717 (1); sceptic (2); Shyam (1); stevem (1); Tippycanoe (1); user-deleted-1105 (1); vermin (3)
