Previous in Forum: Cable Sizing   Next in Forum: Destructive Harmonics Mitigation and recyclingback to useful energy
Testing a LM317T Voltage Regulator
06/12/2009 11:05 AM
Hello All I am the plant Electrician at a Copper Foundry and have been trying to revive a old circuit board for a coiler counter that was left outside for a long time.I have powered it up and have gotten one set to work but not the other as though both displays light up . My question is I am replacing components on the board and have already replaced several op-amp chips along with several transistors and almost every diode. I am try to test a LM317T voltage regulator (T-220 style) and am testing like a transistor but all 4 have same reading so I am thinking they are ok but would like to be sure. Thanks all
Also posted in: also posted in Instrumentation
Re: Testing a LM317T
06/12/2009 11:43 AM
You can conduct a basic-performance test by connecting:
Pin 1: To common ground (Supply - , DMM - , and load, if any)
Pin 2: To the DMM + probe (DMM set for DC voltage). You can also connect a load (a few Ohms) between this pin and ground.
Pin 3: To any DC supply from +7 to 40 V
(You can reach a datasheet at: http://www.fairchildsemi.com/ds/LM/LM317.pdf)
The voltage at pin 2 should be close to 1.25 V, independently of the load and the input voltage.
This is just a quick-and-dirty test, not ensuring fully functionality. But you don't get anything better when you check a transistor by simply measuring its hFE with a DMM.
Besides, the LM-317 is a tough regulator (including current limitation and thermal shutdown), so there is a good chance of finding your pieces in a good condition.
Re: Testing a LM317T Voltage Regulator
06/13/2009 11:25 AM
LM317 is a positive variable output voltage. To make sure that is working, the best way is to test it in a real life configuration.
Take a 120 ohm resistor and connect it between pin 2 (output) and pin 1 (adj). A 360 ohm resistor between pin 1 (adj) and ground. Connect pin 3 (input voltage which could be up to +40V). The output voltage should be close to 5V. If you connect a load 5 ohm or higher between pin 2 (output) and ground, the voltage on it should be a 5 V constant.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
06/13/2009 3:55 PM
You might want to swap the good side regulator for the bad one and see if the problem follows the regulator, if it doesn't, then suspect another component.
Good Answers: 54
06/13/2009 9:36 PM
I gave points to both fernandotasso and indel since their answers are both valid for testing the LM317. I can't think of a simpler/better way to test it.
I just want to add that, you can't test the LM317 like a transistor (although it looks like one) because its internals is a circuit, not a simple transistor. I haven't noted how a good LM317 looks like with a resistance check (then again, I don't know how much variation there will be from one device to the next).
regards,
Vulcan
Register to Reply 4 comments
Anonymous Poster (1); fernandotasso (1); indel (1); Vulcan (1)
