Previous in Forum: 1993 Honda Won't Start in Warm Weather   Next in Forum: 1974 Rambler - Painted Chrome
8 comments
Pressure and Velocity Reduction in Water Pipes
06/17/2009 6:27 AM
Regarding pressure and velocity of water when passing through pipe
In our case, Water pass through 1.5 inch pipe and pressure for that point is 3 kg/cm2 .
then told me the what flow passed through pipe and velocity of water in that pipe. please tell me relation of formula.
In this line for this pressure is it got 150 lpm flow ?
Re: Regarding Pressure and Velocity of water when passing through pipe
06/17/2009 6:43 AM
The pressure in the pipe is not relevant in this case.
To obtain average velocity, divide the flowrate by the cross-sectional area of the pipe. 2.2m/s sounds about right, and would be acceptable, being below 3m/s.
06/17/2009 6:48 AM
For such pipe , a 150 gal/min gives a High speed , about 7 m/s
lenght pipe will affect flow.
devitg
06/17/2009 6:53 AM
The original poster has 150lpm, not 150gpm.
06/17/2009 10:15 AM
My fault , sorry.
devitg
Re: Pressure and Velocity Reduction in Water Pipes
06/17/2009 11:11 PM
yes your 1.5 inch pipe will give 150LPM flow rate basing it on pipe nomograph @ fairly rough pipe material @ 1.2m/s velocity
06/18/2009 6:52 AM
regarding water velocity in 1.5" pipe at 150L/min.
to calculate velocity, V = 1273.2 x L/s / d*
V = 1273.2 x 2.5l/s / 38.1*mm = 2.19m/s
To determine pressure drop in Kpa per meter, assume D'Arcy friction factor of 0.017
loss of head = 0.017 x 1 x 2.19* / 2 x 9.97 x 1000 = 0.109m
pressure drop = 0.19 x 1000 x 9.79 = 1.06Kpa per meter.
hope this helped
06/18/2009 8:59 PM
To calculate the flow through a pipe, you need not just the size and pressure at a single point, but the pressure at two points and the type and material of the pipe. A 1.5 inch sch 80 pipe has a diferent inside diameter than a sch 40 PVC pipe. Other posters have shown that is is possible to see the flow you are asking for, but that does not guarantee that that flow is present.
A good online pipe flow calculator I use a lot is http://www.pipeflowcalculations.com/
Do this. Don't do that. Can't you redesign?
06/18/2009 11:29 PM
The pressure is not a factor for flow rate, but the difference in pressure is the cause, and may be your piping system have a 100 kg/cm2 in static condition, and there is no flow rate.
From piping hydraulics handbook, for 1 1/2 inch steel pipe schedule 40 used for water at 60o F:
● For flow rate 3 gallons/min: the velocity is 0.473 ft/sec & pressure drop is 0.043 lb/in2 per 100 ft.
● For flow rate 4 gallons/min: the velocity is 0.630 ft/sec & pressure drop is 0.071 lb/in2 per 100 ft.
● For flow rate 5 gallons/min: the velocity is 0.788 ft/sec & pressure drop is 0.104 lb/in2 per 100 ft.
Abdel Halim Galala (1); andrew_ward (1); devitg (2); ericpolc (1); GreyeTech (1); PWSlack (2)
