Previous in Forum: Peening?   Next in Forum: Permanaent Magnetic Chuck-- Changing Flatness
Metrology: Thread Gage Out of Spec
06/19/2009 7:18 AM
To all,
As the above mentioned suggests, I have a thread gage ( trunc) found out of spec by two different accredited labs.
The labs are .00001 apart on their findings which I can accept.
The gage itself was +.00008 oot.( tol=+0.0 ,-.00003, trunc)
Since the gage was sealed and dormant for 9 years, and was checked for accuracy when it was decided that it was needed, what would be the probable causes of this defect. I am fairly new to metrology. Can anyone un the field explain this? thanks
It is functionally good, but we are a 17025 company.
Pathfinder Tags: Metrology
Re: metrology: thread gage out of spec
06/19/2009 7:24 AM
<...the probable causes of this defect...>
One possibility is a difference in temperature between the two measurement events.
Good Answers: 183
Re: Metrology:Thread Gage Out of Spec
06/19/2009 8:37 AM
Nominal dimension for the gage? Material of the gage?
Temperature is maintained (or should be maintained) within <±0.5°C. You have to check if this condition was respected, if not the references could have been different. You should ask for this too.
Re: Metrology: Thread Gage Out of Spec
06/19/2009 10:37 PM
Hi,
I'm not in mechanical metrology, but I do know that those things are checked at 20°C. There would not be measurement results from 9 years ago surely. My guess is it was out of specs when it was stored. You probably could have bought a new one for the price of two calibrations.(?) I don't see any choice but to replace it now.
-S
06/20/2009 12:55 AM
Size of a steel gage can change over time due to latent metalurical effects. The slow conversion of Austinite to Martinsite or perhaps vis versa, it has been a couple decades since I knew this information well.
Good Answers: 150
06/20/2009 10:12 AM
guest is correct that metallugical effects can cause distortion. I'm not real familiar with the steels used for gauges, but I've seen some duplex stainlesses move by orders of magnitude more than what we are discussing here, so it is conceivable that metallurgical effects could be in play here.
Who is John Galt?
06/20/2009 11:25 AM
Another possibility could be that the gage has been inspected to a higher class in the same thread size which narrows the acceptable dimension parameters. Gage materials, like any others, can move over time. Even slight amounts of corrosion will grow a dimension, and when removed, will leave it lower.
The last possibility is that the 9 year old cert was done on 25 year old equipment and just wasn't as reliable as what we have availible today. Also, some labs only verify pitch, and not form.
How can you be two places at once when you're actually nowhere at all?
Location: crankshaft producing hub in belgaum,karnataka,india
06/21/2009 9:05 AM
first of all it has to be checked with what care it was stored.whether the right rust preventive was applied . a closed atmosphere calls for accumulation of moisture and more stresses on the part being stored hence this variation.pl check the position of part being stored.
Register to Reply 7 comments
Anonymous Poster (1); Jerry New Hampshire (1); nick name (1); PWSlack (1); ravi bagewadi (1); Rorschach (1); StandardsGuy (1)
