Previous in Forum: Automated Parking System !   Next in Forum: Anchor Box and Anchor Bolt
Pressures of a Pipe Line Header Having Incoming Different Pipe Streams
06/22/2009 12:24 AM
dear all
i want to know the concept of pressure in pipe lines. suppose we have different pipe line i.e L1, L2 and L3 with different pressures making a common header L4. L1, L2 and L3 are of size 3" each. Pressures are P1, P2 and P3.. what will be the pressure of L4 ... i know that Daltons law of partial pressure does not apply in this case because we cannot say that a 300 psig , 200 psig and 100 psig will have a header of 300+200+100=600psig pressure...so no need to even think of that..
Re: pressures of a pipe line header having incoming different pipe streams
06/22/2009 12:53 AM
Any stream at a pressure below P4 will not flow into L4, nor will it affect the pressure in any way. Unless you give flows of each stream including the flow out of L4 no answer is possible.
Good Answers: 19
06/22/2009 1:24 AM
homework??
06/22/2009 4:31 AM
Suppose, Flow in L1 = 25 cu.m/hr water @ 3.2 ksc (a) , L2=45 cu.m/hr water @ 1.2 ksc (a). I require the total i.e. 70 cu.m /hr at the common header ?? can all the three pipes have same nominal bore ??
Note. 80 NB for all the three pipes was the actual design.. I want to know the calculation procedure and the different parameters for sizing the diameter.. Also, is it based on continuity eqn. ??
06/22/2009 7:58 AM
<...can all the three pipes have same nominal bore ?...>
The economic diameter of any full pipe carrying liquid should ordinarily that which allows an average velocity between 1 and 3m/s.
Flammable non-ionic liquids should be ideally less than 1m/s so as to minimise the risk of static electricity build-up within them.
Re: Pressures of a Pipe Line Header Having Incoming Different Pipe Streams
06/22/2009 4:15 PM
For the three lines L1,L2 and L3connect ,all connected for one header , they will all has the same pressure , So it's not right to assume different pressure in each line.
Different are in pressure losses in each individual line which is mainly depending on pipe diameter , flow rate , flow speed and pipe material in additional to pipe fittings.
All these factors affects pressure loss in each line separately..
So you have two ways.
*- if you need a definite flow rate , you have to calculate to obtain pipe diameter.
*- if you have a definite pipe diameter , you have to calculate to obtain flow rate
Anonymous Poster (2); ducon (1); PWSlack (1); sphinx49 (1)
