Previous in Forum: Pressures of a Pipe Line Header Having Incoming Different Pipe Streams   Next in Forum: Pipe Dia Calculation
12 comments
Anchor Box and Anchor Bolt
06/22/2009 1:05 AM
Anchor bolt is used as foundation bolt in our application.But wat is the real necessisty for providing Anchor Box cant we directly fix into the foundation by providing hollow pockets in foundation.
With Regards,
Dinakar
Re: Anchor Box and Anchor Bolt
06/22/2009 3:33 AM
Onto what are the mechanical fixings to be attached, then?
06/22/2009 10:58 PM
Yes, you can, where the anchor box can be compensated by the hollow pocket.
06/24/2009 12:42 AM
Is there any specific reason for providing anchor box
Good Answers: 97
06/24/2009 12:04 PM
Is there any specific reason for providing anchor box?
It is the method of choice by those observing wisdom...
Good Answers: 120
06/22/2009 11:07 PM
bolts embedded in concrete can corrode. The corrosion products occupy a larger volume than the steel and cement and they exert an irresistable pressure on the concrete that leads to spalling and in time to failure of a stressed bolt.
The embedded box is usually galvanized and also spreads the load, so in theory there is no corrosion. Special epoxy end seals are also used.
Some hints can be found by drilling down into this search
http://www.google.ca/search?hl=en&q=%22anchor+box%22+%2Bconcrete&btnG=Google+Search&meta=&aq=f&oq=
Per Ardua Ad Astra
06/23/2009 3:55 AM
Also, by using the hollow pocket and epoxy, you can attain the same advantages as provided by anchor box when you apply the same type of epoxy.
06/27/2009 12:51 AM
Where to use Single anchor box and double anchor box
Good Answers: 97
06/28/2009 3:44 AM
Good Answers: 93
06/22/2009 11:08 PM
What exactly do you mean by Anchor Box?
What is the savings or improvement of making hollow pockets in the foundation?
I can't really answer your question, since I partly don't understand what you mean by Anchor Box.
I have put many an anchor bolt into a foundation so as to later attach sill plates so the building doesn't blow or float off its foundation.
You don't get wise because you got old, you get old because you were wise.
06/23/2009 12:55 AM
Normally the anchor bolts are used to prevent shifting and not uplift. For uplift a longer J bolt is set in a wet concrete pour and is attached to the treated lumber prior to the floor being set down or the bottom plate of a wall as it is set in place (as in a garage wall).
A box is often used for corrosion prevention in areas where the ancors are constantly exposed to water or other liquid seapage and such.. Or just for the heck of it.
JL Mealer
Mealer Companies LLC
http://mealercompanies.com
Good Answers: 97
06/23/2009 2:06 AM
How to provide both anchoring and adjustment without the simple utility of the anchor box?
Good Answers: 97
06/23/2009 3:04 PM
Register to Reply 12 comments
Abdel Halim Galala (2); aurizon (1); bwire (4); dinakarj (2); JLMEALER (1); PWSlack (1); Transcendian (1)
You might be interested in: Bolt Tensioners, Bolts, Anchors
