Previous in Forum: International 1066 Crankcase Problem   Next in Forum: Thermodynamics Trumps Fantasy
White Metal Bearing
07/06/2009 3:25 AM
our ball mill 3mtrs dia x 5mts long our counter shaft bearing are white metal bearing 180 degrees , i have taken impression 60% on bearing of the shaft , and fixed and taken trail for 15mts , the bearing temperature are high 72 drive end and 75 degrees on non drive end what is the problem
Re: White Metal Bearing
07/06/2009 8:17 AM
What is the ambient temperature?
With what is the bearing lubricated?
Good Answers: 103
07/06/2009 8:47 AM
Are the bearings new or old? Recently once we replaced a bearing in a high speed machine and in that we had a problem. Investigation has pinpointed to the improper lobes machining.
Check for lubricant contamination.
Are they hydrodynamic bearings or hydrostatic support is given? (The ball mills we make, of course larger ones) are hydrostatically supported with the soft metal only for the back-up for lube failure.
What is counter shaft? (our counter shafts are small one and then roller bearing supported) the 180 deg ones are what we call the main support bearings, for us it is 120 deg not 180 deg.
04/17/2010 3:47 AM
We used to use white metal fpor our mill bearings (untill 1996,not now). In addition to oil lubrication, we used to give water jacket around the bearing which will take away excess heat. White metal wears rapidly at higher tempetratures.
White metal being softer, any contaminant in the lube oil will get embeded in the white metal thus rubbing itself witht he metal part causing temperature rise.
One has to watch out for engineers - they begin with the sewing machine and end up with the atomic bomb. - Marcel Pagnol
NitinPK (1); PWSlack (1); sb (1)
