Previous in Forum: Windows 98 SE - Frozen Startup Window   Next in Forum: Importing Messages to Thunderbird
23 comments
Good Answers: 101
Watermark in Solidworks
07/30/2009 6:14 PM
I'm sure there is a very simple solution to creating a transparent watermark on a drawing, but I have yet to discover it.
I'm trying to put "Internal use only" In BIG transparent letters (like a stamp) across some drawings. So far I've had no luck. I am running Solidworks 2006, I have Photoshop CS4, and I'm convinced this can be done. What am I overlooking?? I've tried the help files with no luck, and searched the net for a while with no luck. Every time I attempt to bring something into Solidworks, It either is a solid white(non-transparent background, or only the filename shows up where I would expect the image.
So... I humbly beg for any assistance on the matter, as It appears I am not capable of performing this seemingly simple task.
Pathfinder Tags: Solidworks watermark
Re: Watermark in Solidworks
07/30/2009 7:18 PM
There's stuff on the web. "water mark with PC" Got some hits.
You've probably already done this.
Good Luck.
Good Answers: 101
07/30/2009 7:49 PM
Yeah, creating the watermark isn't the problem. It's getting it into Solidworks/AutoCAD that is causing me grief. I just want to be able to bring the transparent text into Solidworks and place it over my drawing so you can still see the drawing easily, but a lightly shaded text is visible. My end goal is to have the "watermark" image files available as something like a stamp, which I can simply "stamp" my drawing when completed, before sending it to anyone. I would like to create things such as:
"CONFIDENTIAL"
"INTERNAL USE ONLY"
"CLASSIFIED"
"NOT APPROVED FOR CONSTRUCTION"
ETC, ETC...
07/30/2009 8:18 PM
"WHATEVER YOU DO, DON'T ACTUALLY BUILD THIS!!"
Charlie don't surf.
08/01/2009 11:31 AM
Too Funny...
Out in a Bowt
07/30/2009 10:27 PM
We convert all of our drawings to PDF for distribution - creating a stamp like you describe with Adobe is simple. It doesn't help if you really want to stamp the source file, but it works well with "shop copies".
Good Answers: 101
07/31/2009 11:31 AM
Thank you,
That is where i was headed if I just couldn't get the CAD Programs to do it. (which I can't) Why the heck is this not something already available as a plug-in for SW or ACAD? Ohhh well, maybe the new 2010 version will have this feature... I'll just have to upgrade.
07/31/2009 1:14 PM
I agree - it seems like something that should be a pretty basic feature. Another of my pet peeves is the complete absence in any drafting package (that I have ever worked with) of the overlapping CL centerline symbol. Just proves that software designers aren't really engineers!
08/01/2009 9:18 AM
Hi: I run Solidworks 2006 and it has a centerline symbol as you describe. I also use AutoCad and you are correct you have to create it and save it as a block I guess.
08/03/2009 8:11 AM
With respect to the CL symbol, many 3D MCAD programs have this built in. I think I have also seen in in AutoCAD, but this may have been their Mechanical package.
08/01/2009 9:21 AM
My Canon printer can do this as an extra while printing from any program.....check your printer manual, it may be easier than you think......
You might even "pre-print" your paper using Word or similar, in a contrasting color, then print your documents on that.......I am sure in Word and or in the printer, you can do a "washed out" color quite easily.....experiment.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
08/01/2009 11:04 AM
What about drawing what you want in AutoCAD, then edit and save it as a block. Paste in as needed? I've done a lot of funky stuff with title and revision blocks so this should work.
I think I even remember doing it on a side job but I can't find it without looking and that is too close to work on the weekend.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 204
08/01/2009 11:41 AM
The E-Drawing application that comes with SW has some of this functionality, but more for viewing. I've never tested it to see if it printed. Perhaps you could try and publish/print your drawings through E? I no longer have access to solidworks so can't test any theories...
Chris
08/01/2009 1:38 PM
When saving from Photoshop, save it as a Post Script file(.PS) and make sure you select "enable transparency" if you made the picture or words using transparency. The imported drawing can then be
positioned by dragging it around or by specifying co-ordinates. The PSDRAG
and PSQUALITY variables control the drawing's appearance when it is being
dragged.
Although the easiest way to put a watermark on yor doc. is to let your printer do it. Most decent printers allow you to select an image or phrase to watermark your doc.
08/01/2009 10:36 PM
Paint.NET is a freeware Photoshop clone. (http://www.getpaint.net/) If you can export your image to a JPG, or other file, that program can do what you are looking for.
If you cannot export and you have MS Office, you can install the MDI printer driver. The MDI document can be exported to a TIF file.
Good luck.
Good Answers: 68
08/02/2009 5:37 AM
Hello RVZ17,
I searched using your heading and got a lot of stuff back.
The first part of this post is instructions "How To".
The next bit is a list of some sites which may help.
How to add Watermark to SolidWorks Drawing (with linked value)
Posted on February 12th, 2008 by fcsuper
How to add a Watermark to SolidWorks Drawings
By Matthew Lorono
For whatever reason, watermarks are sometimes necessary, even on drawings.
Since SolidWorks has no watermark feature, and does not allow the user to change the order of certain drawing entities, a workaround is necessary. Here the most effective and powerful method useful for Drawing Templates and Sheet Formats.
1. Open the drawing.
2. Create a drawing layer by choosing the layer icon.
3. Change the layer name and description to something identifiable. Then click on the color block in the Color column and choose a very light color. Select OK.
4. Goto pulldown menu File and select Properties.
5. Add the property Watermark. As a place holder, give this property the value of "PRELIMINARY" or something similar.
6. Edit Sheet Format.
7. Use Annotation Note to create and place the entity that will become the watermark.
8. Edit the properties of that Note to adjust its font, angle, size, etc as desired. Then, link the Note to the custom property Watermark, as shown in the figure. Select OK.
8. Change the layer of the Note to the newly created layer.
9. Right Mouse Button click on the Note and select Make Block and accept.
9.5. Due to some funky behavior that I've discovered by SolidWorks when loading a watermarked template into an existing drawing, I'm adding this one step: Once you make the block, change the layer of the block to the same layer you set for your Note.
10. Save the Sheet Format (under pulldown menu File and select Save Sheet Format).
11. Edit Sheet. The Note will now appear underneath all other objects on the Drawing Sheet.
12. Save this document as a Drawing Template (under pulldown menu File and select Save As…, then change Save as type to "Drawing Templates").
This creates both the Drawing Template and Sheet Format with an embedded watermark. To change the text of the watermark in any drawings that use the Drawing Template, simply go back to Files>Properties, and edit its text value.
To remove the watermark, simply replace the current value with a space. These instructions are geared towards SolidWorks 2007 or earlier. SolidWorks 2008 or later instructions will be similar, though how to access some of the functions may have changed.
Try these:
SolidWorks Legion » Create a SolidWorks Drawing Watermark
For whatever reason, watermarks are sometimes necessary, even on drawings. Since SolidWorks has no watermark feature, and does not allow the ...
www.fcsuper.com/swblog/?p=7
- Cached - Similar -
SolidWorks Legion » How to add Watermark to SolidWorks Drawing ...
www.fcsuper.com/swblog/?p=24
More results from www.fcsuper.com »
How to add a watermark to a drawing - SolidWorks Tips and Tricks At times, a watermark such as "CONFIDENTIAL" is required on a drawing print. Unfortunately, SolidWorks does not have a watermark feature. ...
www.aboutsolidworks.com/watermark.htm
SolidMentor - How to watermark your drawings - SolidWorks ...
31 Jan 2008 ... Re: How to watermark your drawings. Ya'know, I actually covered this topic back in Dec based on a discussion in the SolidWorks forums. :) ...
solidmentor.com/modules/news/article.php?storyid=82
EZ SolidWorks Watermark « 3DVision Technologies Blog
I've seen quite a few strategies for putting a watermark on SolidWorks drawings… .putting them on their own layer, embedding a Word document, special fonts, ...
www.3dvision.com/wordpress/.../ez-solidworks-watermark/
SolidWorks :: The commercial edition can open SolidWorks Education Edition (EDU) files, but they will have an intentional watermark. SolidWorks Education Edition can open ...
www.solidworks.com/sw/esp/4637_ENU_HTML.htm
Good Answers: 101
08/03/2009 11:51 AM
I will try that this morning. Thank you for the great answer!
I do like the printer option, but the one problem I see with that, is when I create a drawing, It is placed onto the network for our people to use. It can be printed from just about anywhere (even in multiple states). And I need the mark on the original drawing, and visible when looking at it on the computer screen.
Thank you to everyone!
I'd bet that I'll have my marks by the end of the day.
08/02/2009 9:29 AM
try: control panel=>printer=>property=>set watermark, then u ok.
Good Answers: 97
08/02/2009 2:55 PM
I believe you have the functionality within CS4
Give look 1 / look /
In Word - format/background/watermark
Free editor
Good Answers: 68
08/02/2009 7:57 PM
hello wire,
How you doing?
With reference to the book by "O'Rielly"/ I have a book on another subject by him and it is amazingly detailed. I can recommend any book written by him!
You sent some useful links my friend. I am saving them, just in case!
Good Answers: 68
08/03/2009 3:24 AM
Hello wire,
In Word - format/background/watermark.
I forgot you could do that in Word.
Cheers my friend!
Take care............
08/03/2009 2:43 AM
For what it's worth its a doddle in sketchup:-
11/23/2009 3:50 PM
Right click, Edit Sheet Format
Insert Picture (Save your message as a picture and select it)
Set transparency to .97 or whatever.
Save sheet format or as drawing template.
07/18/2010 2:46 AM
Not really sure about thee watermark feature inside SolidWorks but i'm sure there should be some functionality .......
As for stamps we have been using blocks for a stamping feature where you can define the layer and line weight and even customise your tool bar with an icon for each stamp as necessary .... Hope this helps
Solidworks user
Anthony @ Alno
www.alnoproductservices.com.au
Register to Reply 23 comments
Andy Germany (1); Anonymous Poster (6); Anthony@ALNO (1); babybear (3); bwire (1); chrisg288 (1); lyn (1); markar (1); plancette (1); popcornwizard (1); Randall (1); RVZ717 (3); snowboy (1); stevem (1)
