Previous in Forum: Fluid Dynamics   Next in Forum: Pipe Standards
Pump Power
08/06/2009 11:09 AM
What is the formula to find out the shaft power of a pump....
Re: pumps
08/06/2009 3:55 PM
Power for pump :-
P= Q U g H(J\N)....... Watt
Q: Capacity of fluild m3\s
U : Denisty Of Fluid kg\m3
G : Garvity earth 9.18 m\s2
H : Total Head ( Include any dynamic , static , Friction Losses , Net Pressure suction head) m
That is power in watt
power in KW We duplicate in 1000
Powe in HP = 0.736 KW
That is For Pump Circulating pumps calculates
and check for more accuracy
Eng., Ahmed
Re: Pump Power
08/07/2009 3:27 AM
The power needed for any fluid mover can be found by multiplying the pressure rise by the volumetric flowrate, and dividing by the efficiency.
Rules of thumb like the above can give a good first stab at it. However, it's the efficiency bit that is a problem, so reference to manufacturer's published pump performance curves is the usual way out.
Register to Reply 2 comments
You might be interested in: Line-shaft Spools, Shaft-hub Locking Devices
