Previous in Forum: Mixing Gypsum and Concrete   Next in Forum: Dispensing System for Crosslinker Coating
Stainless Steel for Acid Service
08/07/2009 4:41 AM
Dear All,
Can i use SS for ACID(HCL) Service( concentration from 98 % to 20%), If yes , Which SS means SS316, SS304, etc.......and is there any sepcific requirement for using same ( i.e PWHT or limitation in carbon percentage or any other...)?
Viral Patel
Re: Suitability of SS for Acid Srvice
08/07/2009 4:57 AM
Check here.
Most pipework for HCl these days is plastic.
08/07/2009 7:02 AM
I have to say yes. 316 ss. We have several scrubbers they where installed with plastic piping and pumps. The only thing original on any of the systems is the 316ss flex hose and suck tube that we put in the drum of acid. The plastic pumps where a nightmare we eventually raised our totes and drums and now gravity feed our scrubbers no plastic. 316 ss flex line which we change out every two years. Lot of headaches have disappeared since then.
Re: Stainless Steel for Acid Service
08/07/2009 1:26 PM
No way! Stainless steels are susceptible to chloride corrosion.
08/07/2009 1:44 PM
Yes, they are, and plastic is susceptible to cracks, leaks and breaks, try keeping the plastic threads sealed if a guage or another piece of equipment is needed in the line. We use 99% and its been tried and true in my expierience you will have way far less problems with stainless steel with regular inspections and changing out the lines every couple years.
Register to Reply 4 comments
Mikerho (1); moore (2); PWSlack (1)
