Previous in Forum: What does WMP stand for?   Next in Forum: Help with an Old Wives Tale
11 comments
Good Answers: 97
Not Homework
08/07/2009 4:26 PM
I can't seem to get this one. I have 2 equations and 2 unknowns. How do I solve for the variables a and b?
1. 1.5 = 1/a + 1/b
2. 1.25 = 1/a^2 + 1/b^2
The above question had me worried
My solution
Let x = 1/a
Let y = 1/b
then you have
x + y = 1.5 & x² + y² = 1.25
the solution of x & y is then where the circle and the line crosses and a & b is then easy to solve.
My questions now are :-
1. Is that the best solution?
2. What is the possible application?
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Not Homework
08/07/2009 4:43 PM
That is probably the simplest way to get a good answer. You end up having to use the quadratic equation and I seem to get two valid answers for both x and y:
x = 1.5 - y
(1.5 - y)^2 + y^2 = 1.25 ======>2y^2 - 3y + 1 = 0
y = 1 or 1/2 ========> x = 1.5 - (1) = .5 ****or**** x = 1.5 - (.5) = 1
******************* y = 1 ; x = .5 ************* y = .5 ; x = 1
******************* b = 1 ; x = 2 ************* y = 2 ; x = 1
This seems wrong that you can get two equally valid answers that both check. Both are valid when plugged into the 1.25 = x^2 + y^2.
I think when there are fractions like that, it is best to make them into a variable for simplicity-sake.
Good Answers: 103
Re: Not Homework
08/07/2009 10:44 PM
This seems wrong that you can get two equally valid answers .
Quadratic equations do have two roots. (nth degree equations have n roots).
A line cuts a circle at two distinct points (in a special case the two are same and in anothe infinite number of special cases they are in imaginary area).
Re: Not Homework
08/07/2009 11:24 PM
Yes. I know that quadratic equations yield two roots. I guess I am so used to just eliminating a root, usually a negative one.
Good Answers: 74
Re: Not Homework
08/07/2009 11:21 PM
x = 1/a; y = 1/b
1. 1.5 = x + y; x = 1.5 - y
2. 1.25 = x2 + y2 ; 1.25 = 2.25 - 3y + 2y2 OR 2y2 - 3y = -1 OR y2 - 1.5y = -0.5
So...(y - 0.75)2 = -0.5 + 0.5625 = 0.0625
y = +/-(0.0625)1/2 + 0.75 = 1.0 or 0.5
and x = 0.5 or 1.0
a = 2 ; b = 1 OR a = 1; b = 2
Both solutions satisfy the original equations.
A circle centered on the x and y axis can be represented by x2 + y2 = R2
Any point on the circle has coordinates x, y. This problem finds the particular solution when the sum of the two coordinates is constant, in this case 1.5.
Why the problem was phrased in terms of 1/x and 1/y is not clear.
Bruce
Good Answers: 97
Re: Not Homework
08/08/2009 1:09 AM
Hi ba/ael
"Why the problem was phrased in terms of 1/x and 1/y is not clear."
Maybe this (homework) problem was for the (trigonometry) learner to be forced to identify one or more of the fundamental identities and solve the problem that way.
I cant remember but is 1/a² + 1/b² not related to tan?
Good Answers: 74
Re: Not Homework
08/08/2009 12:43 PM
Hendrik,
I believe sb had it right in Post #2. One equation is a straight line. The other is a circle of radius 1.25. The simultaneous solution of the two equations determines two intersection points 0.5, 1.0 and 1.0, 0.5 on the x,y axes. This corresponds to 2, 1 and 1, 2 in terms of a, b. But I'm not sure why the equations were written as reciprocals in the first place. Maybe it was done to test the student's cognitive powers.
Bruce
Re: Not Homework
08/09/2009 8:18 AM
Good Morning,
Below is the graph for the two equations with intersections at (1,2) and (2,1) representing the solutions to the system of equations.
My graphing utility does not handle discontinuities, so please mentally add a hole at the origin of the graph (0,0) since dividing by zero is a very bad thing!
Have a nice day all. John
Re: Not Homework
08/10/2009 2:23 AM
If you want to do it without the reciprocal substitution:-
1.5 = (a+b)/ab
so 2.25 = (a+b)2/a2b2
so 2.25 = (a2+2ab+b2)/a2b2..........A
AND 1.25 = (a2+b2)/a2b2).............B
A-B gives 1= 2ab/a2b2
so ab = 2
then substituting in the first equation gives 3 = a + 2/a
so a2-3a+2 = 0
(a-1)(a-2)=0
Re: Not Homework
08/10/2009 2:09 PM
1/a^2+1/b^2+2/ab=1.5^2=2.25
1/a^2+1/b^2=1.5 by subtracting the bottom from top we get 2/ab=1 or a=2/b
so 1/2/b+1/b=1.5 or b/2+1/b=1.5 or (b^2+2)/2b=1.5 or b^2+2=3b or b^2-3b=-2
so b=2
We know 1/a+1/b=1.5 so 1/a+1/2=1.5 so 1/a=1.5-0.5=1 Therefore 1/a=1 so a=1
Re: Not Homework
09/04/2009 2:43 AM
Instead of typing in all of these symbols, check out this new site that allows you to post questions in any format: vid, audio, picture, text. You can write out all of your math/sci equations and scan them up as a jpg or pdf.
www.domyassignment.com
Not Homework
01/12/2010 8:15 PM
You know what, here is something that can help you: I just found answers to my homework questions on TutorAnswer.com!
Register to Reply 11 comments
Anonymous Poster (3); ba/ael (2); Hendrik (1); Jaxy (2); Randall (1); sb (1); velisj (1)
You might be interested in: Precipitation Systems, Wellhead Equipment
