Previous in Forum: New power immed.-distrib. tech/std. conserves?   Next in Forum: Cable Vibration When Starting a Motor
23 comments
Brushed Motor
12/12/2006 7:54 PM
I wanted to know if there was a way of controlling a brushed motor from the back EMF it produces?
Re: Brushed Motor
12/13/2006 2:06 AM
Lock the armature so that it cannot rotate
Re: Brushed Motor
12/13/2006 6:40 AM
How would that help?
I mainly want position control of the motor using the EMF some how...
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
Re: Brushed Motor
12/13/2006 9:42 AM
I don't think so. If the motor is well designed, the back-EMF should be relatively constant. It is possible to sense position on some types of motors using back-EMF or current (for example: switched reluctance motors), but not with brush motors. You'll need an position sensor.
Re: Brushed Motor
12/14/2006 7:43 AM
You either need to use a stepper motor or gear down the dc motor and use a resolver or encoder to sense position. Back emf would sense motor speed.
Re: Brushed Motor
12/14/2006 3:00 AM
Steve is right, not possible.
Re: Brushed Motor
12/14/2006 3:27 AM
Yes, well, there is if you go for "brushless" dc Motors. I think the question you are asking is whether you can eliminate the brushes from a motor!
Look up "sensorless brushless dc motors" on the www and there should be a number of electronics/motor manufacturers marketing this technology.
Re: Brushed Motor
12/14/2006 3:49 AM
I know about brushless motor, but that would mean you need a frequency control....What if the motor was slow 10~20rpm? wouldn't you see the EMF spikes more easily?
Re: Brushed Motor
12/14/2006 8:52 AM
If you look at the spectrum of the DC current, you will see a component at the commutator bar passing frequency (we looked at this as a diagnostic tool when I was at GE Research). However at best that gives you an estimate of speed - and of brush condition - if you're interested in diagnostics :-)
Re: Brushed Motor
12/14/2006 9:42 AM
http://www.spectrum-engineering.com/01/index.htm
If it is 12v or so, this out to do it.
Re: Brushed Motor
12/15/2006 7:12 AM
Please read the post. He wants to sense and control the rotor position of a DC motor without using a position sensor. Spectrum doesn't seem to address this issue.
Re: Brushed Motor
12/15/2006 6:03 AM
This looks like a problem that the model railway world solved many years ago by froviding feedback controllers. Check out "Gaugemaster" on the www.
Re: Brushed Motor
12/15/2006 7:10 AM
I'm not sure how this is relevant. He wants to sense and control the rotor position of a DC motor without using a position sensor.
Good Answers: 18
Re: Brushed Motor
12/15/2006 10:05 AM
Simple . . . Integrate and scale the terminal voltage, compensate for the IR drop in the armature and include brush contact resistance, and run it really, really slowly, otherwise, the brake you must have to stop at a point in the rotation may not work well.
Re: Brushed Motor
12/15/2006 1:22 PM
....which is why NOBODY does it that way!!!! You really need a position sensor for DC motors with a commutator..
EUREKA!!!
Re: Brushed Motor
12/15/2006 2:25 PM
Open loop integration won't work. The integral will quickly diverge from the true position (where quickly = milliseconds, or seconds at most). We've used integration in the past, but only when there's a way to reset the integrator at very frequent intervals.
Good Answers: 18
Re: Brushed Motor
12/15/2006 3:57 PM
Puleeeezeee! I was only joking . . . But it works well mathematically!
Re: Brushed Motor
12/15/2006 8:10 PM
Wasn't it Yogi Berra who said: "In theory, there's no difference between theory and practice."
Re: Brushed Motor
12/15/2006 7:43 PM
Yeah I did try Open loop integration, but its was out 5mm every time I went forwards then backwards..lol
Re: Brushed Motor
12/16/2006 3:08 AM
I was of course joking when I suggested you prevented the amature from rotating I misread your post and thought you wanted to eliminate the back EMF!
Good Answers: 247
Re: Brushed Motor
12/17/2006 11:22 PM
And I've been thinking of you as syphrum alone... Turns out there is a whole other side to you.
Re: Brushed Motor
12/18/2006 1:56 AM
I was indisposed and called upon my alto ego to stand in for me
Re: Brushed Motor
12/18/2006 2:56 AM
......sadly, using your alto ego is always a failure.......
Good Answers: 247
Re: Brushed Motor
12/18/2006 12:05 PM
... especially if you are a baritone
OK, shoot me.
Register to Reply 23 comments
Andy Germany (3); Anonymous Poster (4); Bill (2); Blink (2); hidaza (3); Murphys (1); Steve (6); syhprum (2)
You might be interested in: DC Motor Drives, EMF Meters, Motor Test Equipment
