Previous in Forum: Air Water Tower   Next in Forum: Wanted: High-Speed Hydraulic Pump
17 comments
How to Convert mm H2O into Bars
08/13/2009 5:48 AM
We have positive pressure air blowers in our machine. According to manufacturer, the pressure of blower should be 300mm H2O. I want to convert that pressure into bars or mbars. Can anyone help me out?
Re: How to convert mm H2O into bars?
08/13/2009 5:57 AM
The conversion can be carried out using the factors that are given in this link.
08/14/2009 7:34 PM
Send me a email and I will send you pdf comparison charts. Have not recieved any contact with this forum for a long time ... do not know why. Do not know how to do attachments in this forum. Email is gbatt@internode.on.net Batt
08/13/2009 5:59 AM
... or you can use this pressure units converter.
08/13/2009 6:21 AM
0.0294 Bars
Re: How to Convert mm H2O into Bars
08/13/2009 11:03 PM
I use this site, You can convert anything to anythng here. i have yet to find a conversion they were not ready for, http://www.onlineconversion.com/
08/14/2009 2:25 AM
08/14/2009 3:31 AM
When you dive, water exerts one bar every 15 feet. You could use that as a rule of thumb. 300mm is about one foot. That is 1/15 of a bar or 66mb.
08/14/2009 4:04 AM
Sure that's not one bar increase every 33.5 feet?
That gives 300mm of water ≈ 0.03 bar (30 mbar).
Good Answers: 137
08/14/2009 4:33 AM
That's right. Lohdi is confusing 1 ft w.g. with 1 psi.
300 mm w.g. = 30 mbar, near enough for most purposes.
Cheers.........Codey
08/14/2009 9:25 AM
I stand corrected. Yes it is 30 mbar.
Thanks Silvio Calvi.
08/14/2009 9:32 AM
That is incorrect. Roughly by a factor of 2.
10 m or 10,000 mm or 393.7 inches is equal to 1 bar.
300 mm = .03 bar or 30 mbar.
To be precise, its 29.42 mbar.
08/14/2009 9:03 AM
0.02939055118 bar
08/15/2009 10:15 AM
10 meters = 1 bar (approximately, very close)
so
300 mm = 0.03 bar (for all practical purpose)
08/16/2009 1:47 AM
pl. go to www.onlineconversion.com for any conversion. accordingly,
300 mm of water = 30 milli bar
good enough
thanks.
08/16/2009 2:28 PM
Atmospheric pressure is approx. 10.2m of water, so you can go from there.
08/17/2009 1:43 AM
Thanks to all for a very good discussion.
05/16/2013 1:04 PM
Dear Mr.Signode,
I bar = 1000 mbar = 0.9838 Kg/cm^2 = 10.197 Metres of Water Column = 10197 MM of Water Column
This is based on 1 atmospheric Pressure = 14.696 psi = 1.03 Kg/cm^2 = 1.0469 bar = 34 Feet of Water column. You can easily convert from one unit to other unit.
DHAYANANDHAN.S
Register to Reply 17 comments
Abdel Halim Galala (1); atorroja (1); batt (1); Codemaster (1); dhayanandhan (1); Floram (1); gajendrasingh01 (1); JohnDG (2); lodhi m f k (2); marcus43 (1); NSS (1); PWSlack (1); Signode (1); silvio calvi (1); yesyen (1)
