Previous in Forum: Diesel Fuel Storage Question   Next in Forum: Leaky Sailboat
Conductivity of Demineralized Water
08/14/2009 8:50 AM
I have a DM (De-mineralized) water treatment plant. It consists a sand filter then activated carbon filter then a 1 micron filter (poly propyline thread type) then a 0.5 filter then RO (reverse osmosis) filter then a mixed bed resin (anion & cation). Recently I changed the filter elements and resin. But the conductivity of the water raises to 190 whereas the conductivity of the water before treatment is 170. previously we got conductivity below 4. Now I need the conductivity below 4. what may the problem? what can I do now?
Re: DM water conductivity.
08/14/2009 9:01 AM
[Assuming the measuring units are μS/cm]
Is the RO equipment in good order as regards correct flows and pressures? - the membranes aren't fouled/blocked/damaged, are they? Are all the membrane interconnectors and vessel end-connectors in good order and not split/missing?
When was the last time the membranes had a manufacturer-recommended chemical clean procedure carried out on them?
Is whatever antiscalant dosing and pH correction that is fitted to the RO actually working correctly?
Is the mixed bed resin selection correct? Has one of the two resins needed actually been left out?
Re: Conductivity of Demineralized Water
08/14/2009 12:25 PM
PWSlack covered alot.
One more thing that may help, what is the flux history on the R.O.
If you get the membreanes back flushed and washed, use knowledgable chemical people that know what they are doing, some chemicals (polymers for instance) react to some salts, and fouling your membranes beyond cleaning.
08/14/2009 11:23 PM
Please tell us size of equipment, membrane size, resin capacity, feed water characteristics, flow rates etc. Recently i faced a difficult situation in demin plant design and my post in CR4 helped a lot.
Please also check conductivity after RO and before resin bed, that will help you to decide whether the problem is with mixed bed or RO.
Just a moment,... you did not interchange concentrate and permeate tubings when you did the changes, did you? !!
sisira
08/15/2009 1:46 AM
Yur concern is it that after replacing the filter and resin the mixed bed out let conductivity is 190 while inlet conductivity is 170.
Normally it happens that if after regeneration proper flushing could carried out, if you have done it then repeat the regeneration and concentrate on sequence if all Ok.
Contact the resin manufacture and seek for his advise, "hpefully" resin shelf life is lasting and you have conducted all resin performance test according ASTM.
08/18/2009 12:32 PM
dear jewel,i couldn't understand the purpose of D.M. plant after R.O. system;as R.O. system can remove upto 99% of T.D.S. even of size 0.0001 micron.Also you just can't use D.M. plant if you are using water for drinking purpose.you can use a water-distiller if want to use water for lab purpose.Distiller will give you much cheaper pure water than D.M. plant.you may be having higher conductivity of water as the final water may have residual caustic or Hcl. please cheque.
01/28/2010 5:22 AM
I have a similar problem like Jewel.
We are having DM water in closed loop zero leakage system supplying DM water for cooling purpose to MW electrical drive. Normally we maintaing the conductivity at .2 to .3 micro S/cm. But after changing the DM water cartridge the value went upto 7 and it took 14 hrs to come down toa level of .5. Where as normally it takes only 3 hrs to rise the conductivity to .3 in 3hrs and 5 to 10 mins to recharge the conductivity to again at .2
Register to Reply 6 comments
Anonymous Poster (2); babloobarjinder (1); phoenix911 (1); PWSlack (1); Sisira (1)
