Previous in Forum: Barcode scanner on ethernet with CPU 319-F DP   Next in Forum: Packard Bell Easynote R4622 Problems
United Kingdom - Member - British
Closing CD drive
08/24/2009 12:35 PM
Hi.
I have a code saved in notepad as OpenCD.VBS, to open the CD drive. The code reads:
Dim oWMP
Dim colCDROMs
Set oWMP = CreateObject("WMPlayer.OCX.7" )
Set colCDROMs = oWMP.cdromCollection
colCDROMs.Item(d).Eject
set owmp = nothing
set colCDROMs = nothing
Would this be modifiable to close the CD tray? I have tried changing "Eject" to "Close", but that comes up with an error saying
"Object doesn't support this property or method: 'Item(...). Close'
Code: 800A01B6"
bondy111
Good Answers: 97
Re: Closing CD drive
08/24/2009 4:46 PM
I don't know VB but try "Load"
Good Answers: 97
08/25/2009 12:53 AM
Retract CD tray scripts
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
08/25/2009 1:53 AM
cool!
  1. but how is this implemented?
  2. does this become a "permanent" option (Eject / Retract) that appears in the right-click menu for the CD-DVD/RW drive?, or do you need to execute some key-combinations to close the drive?
this questions is from a VBS dummy
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
08/25/2009 3:13 AM
I put the shortcut in my quick launch. Then I just click the appropriate one.
bondy111
Good Answers: 58
08/25/2009 3:42 AM
I copied that script, pasted it in Notepad, saved it as closeTray.vbs, created a shortcut and pasted the shortcut in my Quick Launch folder.
I double-click on the shortcut, but an error message says there's a VB compilation error. perhaps I need to compile this first? how do I do that?
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
08/25/2009 9:40 AM
Pardon me if this is a silly assumption, but I have to ask; what happens if you run the same script again? I know the switch on the front of the drive is press/open, press/close (a toggle type function). Perhaps the script works the same way? I have a multimedia keyboard, and it has buttons for Drive1 and Drive2 eject, and if they are pressed when the drive is open, they close. Perhaps too simple?
Tom
Good Answers: 97
08/25/2009 1:50 PM
You couldn't hold that cat eh?
Register to Reply 7 comments
Bondy111 (1); bwire (2); Hendrik (1); langyaw (2); tdesmit (1)
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
