Previous in Forum: Having troubles with Daily Digest   Next in Forum: When all else fails - litigate
28 comments
APIX Pilot Plant Design Project - Member - New Member
Electric Cars
08/26/2009 9:19 AM
We will soon be seeing electric vehicles on our streets and highways. Most of these will either be hybrid or battery powered, a few may be hydrogen fuel cell powered. For the hybrid and battery powered, provisions will be made for the vehicle battery charger to be plugged into the home electrical system and/or special charging systems designed just for this purpose. But, I ask you electrical engineering geniuses, I have seen you on this list, to suggest your ideas, too.
Now, I am not an electrical engineer, not even close. However, I do have one suggestion. Tell me what you think. When you are at work or when your family is shopping, how long is you vehicle parked in the hot summer sun? When you are at home, where do you leave your car parked, in the garage or in the driveway? For how long do you have to sit in heavy traffic when going to work or on your way home from work? Keeping in mind, when one is driving an electric vehicle, the battery (fuel) is drained only when the vehicle is in motion or when the air conditioner, lights, and/or radio is operating. So, my suggestion, why not design the vehicle with solar (PV) cells on the roof of the vehicle to charge the batteries while it is in the sun? I do believe there is sufficient room on a car's roof for about 240 watt to 480 watt solar panels. This could, too, be retrofit to existing gasoline engine powered cars as well which could drive the AC, lights, and radio powered by a separate battery.
What do you think, gentlemen? Many of you have or are planning to add solar power to you home, why not, then, you car, too? Let us all contribute to the greening of the world. OH, and I understand that the LiFePO4 battery is being use in some European Electric vehicles.
chtank
Re: Electric cars
08/26/2009 9:37 AM
There's no problem in principle in fitting a solar panel to the roof of any electric vehicle. The problem is one of practicalities owing to the conversion efficiency of today's solar cells. It simply isn't worth it at the moment.
Solar panels have been capturing energy on water-going vehicles for years. The principal use is to make sure that there is something in the batteries after a long layover that can be used to put the lights on and/or start the engine.
Harvesting sunlight for propulsion is something else. The area needed to capture sufficient sunlight over sufficiently long times in between duty cycles is rather more than the footprint of the vehicle, so fixed installations are a better way to go, in principle.
Solar/battery-powered air conditioner? That'll be the day! Why not just open the windows?
Re: Electric cars
08/26/2009 9:50 AM
By golly, I never new a Brit to be so negative. It is my understanding that the whole of Europe was far ahead of the USA when it come to the implementation of alternate energy. My old motor home had deep cycle house batteries that were charged by a small solar panel. But think on this, 240 watts at 12 volts provides 20 amps of charging power. Two hours in our hot Texas sun could provide sufficient charge to get one home after a day of shopping. The solar panels would be to supplement and compliment, not replace a plug-in charge.
chtank
Re: Electric cars
08/26/2009 10:22 AM
The reply was intended to be neutral.
Given that a road vehicle may need, oh, say 5-10kW while moving, plus any air conditioning load for warmer climes, consider the duty cycle of the vehicle, the panel efficiency, and whether there is sufficient area on the vehicle to fit enough panel to cover the duty cycle. If the panel were intended merely to supplement rather than provide all, then why not go for full land-based collection and distribution rather than relying on recharge? After all, there's lashings of rooftops and desert in some places just waiting to be exploited.
It's only arithmetic.
National characteristics: there is a saying along the lines that an American will have tried and failed three times before the Brits have made up their mind....
Re: Electric cars
08/26/2009 11:12 AM
I like your "National Characteristics" statement.
The first time you read it it seems to promote one group, the second time you read it you think it promotes the other group, the third time you read it you just have to stop and say Hmmmm.
I can't tell which group is getting a backhanded compliment. he he.
Everything I know about opera I learned from Bugs Bunny
Re: Electric cars
08/26/2009 11:31 AM
actually, what I was looking for was that we contribute ideas for improvement. Ideas such as the prime mover (i.e. electric motor) built into each wheel and controlled by computer to assure that the proper power was contributed by each wheel to account to turns, road conditions, and even braking. After all, the current gasoline fueled prime mover through a transmission, provides only 3 to 7 HP to the road. It would seem to me that if each wheel contributed a portion of that power directly, it would save close to 75% of the energy through the thermal and friction loses of the engine/transmission. Let's give some thought to this, since one of the main considerations for our energy crisis of today is efficiency and conservation. Let us have yoiur ideas, please, after all, we are scientists and engineers are we not? I hope we were all taught how to think, so, let us publish our thoughts. BTW, if one does publish a good and usable idea, it is dated, thus, the copyright becomes the right of the first to publish.
chtank
Re: Electric cars
08/26/2009 5:30 PM
Please bare in mind that 'PWSLACK', myself and many others have already discussed this topic in great depth before on CR4 on numerous threads over the years, hence the basic summary comments made.
Please perform a search of CR4 for the numerous relevant threads. There are literally dozens of threads covering pages and pages of comments, theory and web links on the subject (it is a very common topic). Don't forget to include MPG and fuel millage threads also.
We will be happy to answer or expand on any specific questions that have not already been covered.
Re: Electric cars
08/27/2009 2:47 AM
Ooh that's good! How about wheels that lift up when they can't contribute anything significant to the optimized model, thereby allowing potential blow outs to be removed also. A teetering inline wheeled prime mover with saftey wheels ready for imbalance! :)
Good Answers: 183
Re: Electric cars
08/26/2009 10:25 AM
I do not understand why you asked for an opinion if you immediately disagree with a negative one. If you are so convinced that you are right no reason to ask.
Re: Electric cars
08/27/2009 11:52 AM
make the auto body out of solar panels . magnets on the wheels to charge when the cars is moving too a constant charge to the batterys.
I suggested this 5 years ago I belive in another engery soultion thread
Good Answers: 61
Re: Electric cars
08/30/2009 3:38 PM
"magnets on the wheels to charge when the cars is moving too a constant charge to the batterys.
I suggested this 5 years ago I belive in another engery soultion thread."
Please tell me you are not serious.
P.S. Where did you learn to spell?
Re: Electric cars
08/30/2009 6:00 PM
Well I will try and keep you busy since you enjoy spell checking so much.
The shots I take at the VA trying to save my left leg make it hard to sit lonf and read or respond. So when I rush spelling takes a beating but experienced people look past little thing and are not real anal about posting on web sites.
We are not writing poetry or some Health Care Reform bill to save the $1.7 Trillion more the USA pays than other countries to cover fewer people and get substandard care now are we ?
Re: Electric cars
09/17/2012 7:54 PM
I use my 63 watt panel that i made,to charge or run anything in my car. Laptop,fans ( air went out ),etc.
Re: Electric cars
08/17/2013 10:36 PM
Last week, I received and used a Greenworks Lithium Ion Battery (cordless) powered lawnmower. The 4Ah 40 Volt battery had enough power for me to mow both the front and back yards on one charge. Now, if I have a 63 watt panel like =saveone12 has, I could set it up in a sunny location and maintain a charge on my batteries easily between weekly mowing. Since the electric automobile will most likely be using LiFePO4 battery, it may not be able to be fully charged while on is in the shopping mall parking lot, but at least the driving range can be extended between charges.
chtank
Re: Electric cars
08/26/2009 10:16 AM
It's on the way!
http://gizmodo.com/5022382/solar-panel+powered-prius-in-2009-confirmed
Yes - those Brits are a bunch of negative nellies.
Re: Electric cars
08/26/2009 10:26 AM
Cup of tea, anyone?
Re: Electric cars
08/26/2009 10:26 AM
Now that looks like my next car, to replace my Honda Element if it ever wares out. BTW, my last name is Tankersley, I believe I have a shire and a church named after me just out side of London, hehehe.
chtank
Re: Electric cars
08/26/2009 10:33 AM
Tankersley is near Barnsley in Yorkshire, and is around 170m from London. It's over 3 hours by road internal combustion engine, according to Google Maps, though a solar-collection-no-topup-powered vehicle hasn't yet been developed that can do that distance in that time in this climate.
Re: Electric cars
08/26/2009 11:01 AM
My grandfather homesteaded in Oklahoma in 1889, he served on the Territorial legislature, helped to found what is now Oklahoma State University and had a hand in writing the Oklahoma State Constitution. He died in 1909, my father was only 6 years old at the time, but he did get to see statehood. In my genealogy search, however, there is some evidence that my line was adopted into the Tankersley clan, with the real immigrant being Stropes, Stroops, etc. who came to the colonies from Germany in 1640 and was a gunsmith by trade. This may or may not be true as the trace of the Tankersley line was incomplete and broken in the mid 19th century.
Also, please see my working website, http://chtank.org. Ignore any report that the site is not a valid URL, since it has passed the W3C muster. I do believe the invalid URL fault is with Firefox. You will find me, also, as a minor contributor to the Sustainable Engineering section of this CR4 forum.
Yes, a cup of tea would be nice, or, perhaps a pint of good English ale at the local pub.
chtank
Re: Electric cars
08/26/2009 1:16 PM
Was that part of the wholesale adoption of "street urchins" in the late 1800's when "orphan trains" brought 1000's of kids from East Coast cities to the west?
Good Answers: 32
Re: Electric cars
08/26/2009 10:55 PM
The solar panel on the Gen III Prius powers a small electric fan that keeps the cabin ventilated while the vehicle is parked on the sun. It does not contribute to the motive power. I do not think it has anything to do with air conditioner either but I could be mistaken here.
johny451
Good Answers: 101
Re: Electric cars
08/26/2009 12:40 PM
If you are suggesting to implement the solar panel for a "recharge while it sits in the lot/driveway" type of installation, I think its a great Idea. Save the plug in time, and reduce grid use. It will definitely not provide enough recharge power to be of any use while driving, but I'm assuming the panel's would be for the sole purpose of a trickle charge while the vehicle is not in use. In that case... ok in my book.
Re: Electric cars
08/26/2009 1:00 PM
Exactly! But the trickle charge at 12 volts might be at 10 to 20 amps. Of course if the trickle is at 24 or 48 volts, the, of course, it would be at 5 to 10 amps or 2.5 to 5 amps, repsctfully.
chtank
Re: Electric Cars
08/26/2009 11:41 PM
Capstone tested one of it's micro turbine in a Ford not long ago.
Checck out thier mico turbine and the Air Bearing
http://www.capstoneturbine.com/prodsol/techtour/index.asp
Re: Electric Cars
08/27/2009 2:40 AM
I'd rather park in the shade with my soft exterior car that robotically can't kill by psychotic choice and buy the electricity from the car park solar umbrella robots!
Re: Electric Cars
08/27/2009 8:06 AM
Hi Electric Cars,
I have been a solar guy for 30 years, and there is so much room for improvemnet to use solar cells on our cars.
I built a 4'x 8' roof rack and attached it using tie downs at the corners of the rack, and used a snow ski rack to mount the cooling platform to, and it reduced "cooling" load by >50%, buy it does not look good. Sure, PV panels could power up our batteries while driving or parked on a similar platform. Why Not?
Yes, and Pruis has installed solar panels (on the roof) to operate cooling fans. Hey, we did an engineering analysis of radiant heat load on Army Barracks in El Paso, and the numbers for reducing heat load by shading came to reducing the energy for HVAC by 50%! I am a dealer for automated rolling shutters (rolladens), and we waste tons of energy by neglecting to use shading devices as a cooling device, on anything.
I use rolling shutters to control, "Modified Thromb Walls" for both passive solar heating and cooling! Hey, let's cut our energy bills.
We have to think about, "how can I use passive ideas for heating and cooling?". We talking about megabucks in savings.
Daylight Rolling Shutters DRS
Re: Electric Cars
08/27/2009 3:00 PM
Water proof you connections and place a solar panel under water the see how much your output goes up. They operate at high levels when cooled.
Good Answers: 101
Re: Electric Cars
08/27/2009 1:00 PM
Use magic solar panel paint to paint the car, thats the trick!
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
Re: Electric Cars
08/27/2009 4:53 PM
All you really need are some frictionless muffler bearings to greatly improve the performance of your vehicle.
Sorry, I'm in a really rediculous mood today.
Register to Reply 28 comments
bhankiii (2); Brett Johnston (2); chtank (6); dadw5boys (4); DaveB (1); Daylight RS Company (1); energyconversion (1); jack of all trades (1); Johny451 (1); nick name (1); PWSlack (4); RVZ717 (2); saveone12 (1); Vandarye (1)
You might be interested in: Vehicle Wrapping Services, Battery Holders
