Previous in Forum: Direct PC to PC Communication   Next in Forum: Human Speech is Bi-otic (Like Vision Can be Bi-focal)
14 comments
Audio Amplifier Speech Understandabilility
08/30/2009 8:01 PM
Has anyone tried to make an audio amplifier which produces more speech understandability. Like those audio amplifiers used in hearing aids, they amplify, but to us millions who are hard-of-hearing (hoh), the understandability is downright poor. Hearing-aid manufacturers do a tremendous amount of continually improving of their aids, but alas, none of it seems to be right on target. So we hoh souls plunk down our thousands of dollars, only to be rewarded by once more assigning the aid to the dresser drawer. Maybe those dresser drawers derive some benefit, I don't know.. .......What is needed is a means to amplify the consonants and not both consonants and vowels. Vowels to us hoh make all the volume and the weak consonants can't be heard in the midst of all this vowel volume..I don't think it is that big of an electrical engineering problem to design circuitry to distinguish vowel from consonant. After that is accomplished the vowels can be attenuated or conversely, the consonants can be amplified. Am I correct in my assumptions or am I missing something? ..............The basis of my beliefs as indicated above has to do with how speech itself is created. You see, vowels are produced beginning at the vocal chords which are vibrating membranes which can then be amplified tremendously through use of the various cavities in the skull, like the sinuses. One can actually see these vowels on an oscilloscope because the sound is repetitive and can be represented by a frequency or tone. Not so for the consonants. The consonants are created in a totally different manner, typically by mouth and tongue movement and thus have little amplification. (e.g. lip-reading make use of these mouth movements). By contrast to vowels, consonants do not have this same repetitive nature and these non-repetitive sounds might typically labeled as noise. But not any old noise, but "characteristic noises" which we learn from infancy on can have meaning. Like the pure spoken sound of consonants B.C,D are barely heard, so when we wish to talk about consonants we add vowels to them like, Beee, Ceee, Dee so the listener can "hear and understand" what is being referred to. That is the hearing enigma for us hoh folks as I see it. Hearing and understanding are not synonymous, at least not for us hoh souls. It can make a zillion bucks if you patent, design and build a highly understandable audio amplifier as I have indicated. As a follow-on, if this hypothisis is correct, and I believe it is, then all audio systems, yes all audio systems will have built-in consonant amplification or to accomplish the same effect, vowel attenuation. And another zillion bucks is deposited in the bank. Whoops, maybe not. Its OK, its a Canadian bank.
Good Answers: 83
Re: Audio Amplifier Speech Understandabilility
08/30/2009 9:57 PM
Would this be of any help?
http://www.eurekalert.org/pub_releases/2009-08/afot-htw080509.php
...Prof. Miriam Furst-Yust of Tel Aviv University's School of Electrical Engineering has developed a new software application named "Clearcall" for cochlear implants and hearing aids which improves speech recognition for the hard-of-hearing by up to 50%.
"Hearing-impaired people have a real problem understanding speech," says Prof. Furst-Yust. "Their devices may be useful in a quiet room, but once the background noise levels ramp up, the devices become less useful. Our algorithm helps filter out irrelevant noise so they can better understand the voices of their friends and family."
Based on a cochlear model that she devised, the new patented technology is now being developed to improve the capabilities of existing cochlear implants and digital hearing aids. Adding Clearcall to current technology is quite straightforward, says Prof. Furst-Yust, and requires only add-on software for existing devices...
08/30/2009 10:01 PM
I would have thought the hearing aid manufacturers world wide must know this surely.
They must be more than a glorified graphic equaliser in these times of DSP.
As you suggested its probably more a matter of seperating these consonant sounds from the background noise.
My nephew picked up a new (top of the line) hearing aid a month or 2 ago, had it back for adjustment several times. Finally realised it was the sound of the computer fan in the room was drowning most other things out.
I intend to make an instrument or two to help him out passing the last area of his mechanical apprenticeship he needs to get his mechanics papers .. namely 'diagnosing engine faults by ear' .. I suspect it will not be that easy though and is one of my longer term projects. Maybe its time to start ....
on (another) side note .. I have always found it surprising that high resolution images where captured before good quality audio. I now consider both photography and audio 2 dimensional (since you need to consider time as an important aspect) .. I guess it was lucky that chemistry is suited to capturing images before electronics came of age.
Good Answers: 146
08/30/2009 10:25 PM
This is an issue I did a lot of reading about, a few years ago. I have a file of pdfs I downloaded at that time which I don't have url's for offhand.
The matter of consonants being important is exactly as you said. They're described in the literature as "cues". So "cue enhancement" is a good search term, as is "speech enhancement". Here's one by Sonmez et al on "consonant discrimination" technology - there's a free version of this paper available somewhere online.
On the more technical side, Kalman filters are a method of enhancement that's been studied recently. (I admit it, I have no idea what a Kalman filter is or how it works. but you might! Feel free to enlighten me.)
Ultimately, the specific frequencies involved in the sound of cue consonants are pretty well defined, so there's no reason they shouldn't be preferentially enhanced by a selective amplifier. But apparently in practice it's not quite that straightforward - or as you said, the hearing aid people would be doing a lot better for their thousands of dollars..
incus opella
08/30/2009 10:37 PM
Speech is just vibrations of air molecules that transfer energy. Whats a vowel sound in your language may just be a mechanical vibration in a machine. My one tractor resonates at the letter 'Z' when loaded just right. Is it saying 'Z' to me or is it just a complex acoustical phenomenon?
Also whats a consonant sound like when spoken with an accent? Or which is what in a different language?
Speech to text software is presently the only real artificial method of converting sounds into words that can be understood that I am presently aware of.
If your hearing is that bad cochlear implants are likely the only way your going to ever hear anything properly again. But even then with some forms of nerve damage induced hearing losses even then its not going to help much or at all.
08/31/2009 3:24 AM
No pun intended, but, I'm all ears on this one. I did much unprotected shooting in my youth and am now paying for it. Haven't gone to an aid, yet, but am close.
You'd think that, after a while, practicality would rule out over vanity.
Re: Audio Amplifier Speech Understandability
08/31/2009 9:00 PM
There appears to be some interesting studies being conducted on this subject. I haven't read all the suggested links, I intend to set time aside to do that.
I have experience with the subject matter in that I have a cochlear implant in my left ear and am past the hearing aid category with my right ear (hearing necessity is more appropriate).
Al Mond is correct in his assertion that the understandability of the present day hearing aids leave a lot to be desired. When you have a slight to moderate hearing loss (I'm not going to complicate this with DB's) modern day hearing aids can be tuned to enhance different frequency's and actually aid in hearing and understanding.
The problem kicks in when you have a severe to profound hearing loss, you require such an increase in volume that it causes distortion. One of the criteria for receiving a cochlear implant is that you cannot understand some percentage of normal conversation. The number may be 30 to 40 percent, I don't remember the specifics.
The cochlear implant isn't the cure all that people think it is either. If you are someone like Limbaugh who has excellent hearing and abuses medications to the extent that you lose your hearing a cochlear implant is a no brainer and almost guaranteed success. What happens in the operating room is; the nerves from the ear are surgically disconnected, an electronic receiver is installed and wires are inserted into the nerves feeding the brain. This receiver receives signal from a transmitter (magnetically coupled to the receiver) that is worn in the vicinity of the ear or on your belt (your choice). Any input that you had from the ear is now nonexistent.
In my instance I had not had any hearing of significance for the past 50 years or so in my left ear. This wasn't that much of a problem because I had good hearing in my right ear. I went through the hearing aid in the drawer business when I thought I was losing my hearing in my right ear. during that time I had some surgery on the ear to relieve the pressure in the ear. That was the beginning of the end. since that time I progressed/regressed whichever, to a profound loss in the right ear.
I had the cochlear implant in the left ear about 10 months ago, I was doing great with it. I never got to the point that I could use the implant stand alone but with the combination of the hearing aid in the right ear and the implant in the left I got to the point that I could understand the radio and talk on the telephone. I lost all comprehension of music about 4 or 5 years ago and with the implant I could distinguish the basic beat.
In April of this year I had to have an abdominal aortal aneurysm repaired. I took some pain medication that was ototoxic. The pain medication was only supposed to be toxic to hearing when taken in massive quantity's. In my case it caused a 30 DB further loss in my right ear. I lost all the progress that I had made to that point.
It is starting to improve, I am getting back to where I was. The loss was a nerve loss so what I am seeing has to be the result of the implant. But like I said before the implant is not a cure all.
My answer to the question is they haven't perfected the hearing aid for seriously deaf people, but there may be help on the way for HOH people. There are some awfully smart people addressing the problem.
If you fail to follow through, you will fail.
09/01/2009 10:36 AM
I have had good results with the aids from America Hears. These aids were so superior to two expensive different sets that I had before. I don't recall right now what they had to say ref what this post addresses but they are worth investigating. They were very detailed and courteous with my extensive inquiries.
09/01/2009 4:54 PM
I'm no expert on this, but I suspect that the root problem is that consonant sounds consist of very brief (though abrupt) transients. Vowel sounds are sustained longer (voiced), hence are easier to pick up and amplify.
Another problem is that a really high-fidelity amplifier may entail enough components that it is hard to squeeze them into a small space without sacrificing quality. Thus there must be compromises in the case of miniature devices. Al Mond's original post is excellent in the questions it poses and the ideas suggested. Same for several of the replies.
Good Answers: 146
09/08/2009 7:18 AM
I found this pdf paper by Rodman, which gives an excellent overview of intelligibility issues re: consonants and fundamental frequencies. It's about telephone systems, but covers all the basics of intelligibility very coherently. The trick about consonants is that they contain most of the information in speech - he puts this very clearly.
Couldn't get the link to work, it's the pdf "Effect of Bandwidth on Speech Intelligibility" from polycom.com listed at the top here:
http://www.google.com/cse?q=bandwidth+intelligibility+Rodman+2006&sa=Search&cx=partner-pub-2070091971271392%3Aougxymc6y19&ie=UTF-8
What isn't discussed in this paper, is when there is a noise problem in the upper frequencies (think wind in a hearing aid, for example). I've used 9500 or 9000 hz as a cutoff frequency for speech intelligibility, to get rid of interference in the upper band - it seems to help. His data show that 7000 hz is a reasonable bandwidth for intelligibility.
There is other work that supports the view that the amplitude ratio between consonants and vowels is important. From the figures given by Rodman, vowels energy is generally below 3000 hz while consonants energy is generally above it. So a simple "intelligibility amplifier" might want to reduce energy below 3000 hz, raise energy from 3000 to 7000 hz, and maybe cut off above 8 or 9000 if there's interference in the high frequencies, for example.
It's also true that in hearing loss we may lose specific frequency bands - so custom adjustments would be a good idea. But anyone HOH can test out these simple ideas with a basic audio filtering program with lowpass and highpass filters. (I did my stuff with Audacity).
incus opella
Good Answers: 12
09/08/2009 6:13 PM
artsmith...sorry to say but nothing new if your post. If you just google 'audiogram' you will see that this is exactly the bands that are tested and hearing aid bandwidths are also in this range.
Good Answers: 109
09/01/2009 5:19 PM
Hi,
Hearing and discriminating may involve correlation between the two ears.
This may suppress the noise from sources that are not in the same direction as the wanted source.
No human or mammal correlator in the brain is known (as far as I know, I am not an expert on hearing) but birds have it hard wired in a hollow bone that connects the two ears and is equipped with sensorial nerve cells along its length!
Birds are much better then we are, owls grasping mice below 5 to 10 cm of snow or in the dark.
As I have problems since the age of 17 when I did blow 1 cm3 of explosive unintended in 70 cm distance and had 3 days ringing in one ear and a drop in the 1500 to 2500 Hz band in that ear and a marked difficulty to hear and understand in noisy environments from then on - this is leading me to the conclusion that a correlator is existing and necessary inside our brain. A correlator that is tuned by our brain towards the direction where we want us to "focus" our hearing.
As we do not hear the phase of the many frequencies we can (or not) hear a new (not new in RADAR "hearing" may be not new in audio) approach might use the fact that the power spectrum is the Fourier transform of the autocorrelation function.
I would like also further developed the concept of direct coupling of sound to the bones of our skull - bypassing the impaired hearing system. Any microphone - amplifier - exciter will be possible. To be tuned in frequency response in the region of 30Hz to 10KHz (?) or 16 to 17 octaves each to be resolved by half tones. Will fit with considerable battery power into 2cm diameter and 5 to 8 mm height.
This may be much more powerful than any other approach - but two buttons behind/below the ears may be not accepted by everybody.
RHABE
09/02/2009 1:56 AM
I used to have a boss who wore glasses which had a built in hearing aid: they coupled the sound directly into the bone via the "behind the ear" section. They looked far more like conventional glasses than these.
bone conduction hearing system on spectacles
Good Answers: 12
09/03/2009 6:45 PM
There is always constant research in this topic;
Good Answers: 40
09/08/2009 11:56 AM
Carefully glanced-thru existing posts, hoping this isn't redundant...
The TOPIC and opening line: "Has anyone tried to make an audio amplifier which produces more speech understandability" really rang loud-and-clear, but in the context of a different arena of application.
Deep sea commercial divers, when breathing heliox mixed gas, were unintelligible on the earliest / original intercomm units. Lots of science went into development of the helium unscrambler units that are used today.
I, myself (like another poster) suffered some hearing loss from hunting / target shooting and inadequately-protected 8" howitzer firing (observing). Even the current state-of-the-art unscramblers doesn't make the voices totally clear for me.
Sounds like an opportune time for SOMEONE to take the bull by the horns and organize whatever ongoing efforts exist to standardize the "voices" (and 'overall performance') in such tools as pocket translators, GPS units, etc.
IF things were, in fact standardized, transitioning from one country to another in the future (using the various "Help" units) might be facilitated greatly ... especially for us aging types...
Register to Reply 14 comments
artsmith (2); daffy (2); lyn (1); ndt-tom (1); otha (1); Randall (1); RHABE (1); stoney (1); sue (1); tcmtech (1); Tornado (1); W9GFX (1)
