Previous in Forum: Using a UPS as an inverter   Next in Forum: Small, but very important
10 comments
Good Answers: 15
on POLYDOES . . . heard of them?
09/06/2009 2:47 AM
i suggest - look at POLYDOES here [ http://tofique.fatehi.us/Mathematics/Polydoes/polydoes.html ] and share your comments . . . do you know of any other resource for POLYDOES on the internet?
Pathfinder Tags: mathematics polydoes tofique
Good Answers: 97
Re: on POLYDOES . . . heard of them?
09/06/2009 3:07 AM
I like the word.
Would a nut be an example ?
Good Answers: 183
09/06/2009 5:00 PM
What applications do you see for them?
Good Answers: 74
09/07/2009 12:59 AM
Would they come in different tastes too? That's the only application I could think of at the moment, Ky.
The Twain Has Met
Good Answers: 11
09/07/2009 5:22 AM
As so often, the term is defined by the opposite, polydoesn't, the generic cry of the bad and slightly illiterate parrot trainer.
horsepower measures work, ponypower measures pleasure!
Good Answers: 74
09/07/2009 5:38 AM
That gives it another dimension: sound! Other wise your always on top, Ky.
The Twain Has Met
09/09/2009 5:58 PM
It seems that the difference between Polydoughs and toruses is that the poly-gone shape means you can use a spanner to apply torque when a polydo doesn't (talk, that is)
09/07/2009 11:03 AM
Hi Tofique, Mathematicians normally come across donuts in the context of topology, but, all your polydos are identical to an ordinary ring donut in that context. Have you discovered any properties of them which are not covered by the study of other solids (platonic etc.)?
Good Answers: 183
09/12/2009 2:06 AM
In fact your "discovery" is a body which pushed to the limit as number of side becomes a torus.
Again what is special? What does it have as possible applications?
10/16/2009 11:22 PM
So, are you saying that polygons are useless because if they have many sides, they are a circle anyway? What is your point?
Good Answers: 183
10/17/2009 4:32 AM
I think it is clear enough:
1- it is particular case so that I am asking myself where is the novelty
2- I asked in a very polite maner what are the possible applications.
If you read and make the effort to understand then all is clear.
Apparently you did not do the effort to read seeing your question.
Register to Reply 10 comments
Anonymous Poster (2); Hendrik (1); ky (2); nick name (3); Randall (1); saddlechariot (1)
