Previous in Forum: Jet Engine Help?...I want electric!   Next in Forum: Generator low freqency
16 comments
pump impeller selection
09/07/2009 5:44 AM
I am facing frequent pronblem in pumps, processing media is slurry with concentration 30% of fine silica powder (Partical size <30Microns). Every time when we open the pump after 2 months running we observes complete erroded impeller and volute casing. We are using centrifugal pump(with Closed Impeller ) & Roto pumps.
Pl suggest me suitable pumps or suitable MOC of impeller or suitable type of impeller.
Thanks
Joravi
Pathfinder Tags: SLURRY PUMPS
Re: pump impeller selection
09/07/2009 12:06 PM
Not much to go on. You might try here:Power Plant Slurry Pumps
Lyn
09/08/2009 11:32 PM
Thanks for showing your interest in this problem.
09/07/2009 4:23 PM
Have you tried an ASTM A532 material?: (Don't know about the corrosion in your service though)
http://www.astm.org/Standards/A532.htm
09/07/2009 11:02 PM
Try using soft or medium hard rubber lined, semi closed impeller.
09/07/2009 11:05 PM
I don't know what may be commercially available in pumps with rubber-lined casings and rubber-coated impellers, but rubber or similar elastomers may work for resisting abrasion. (Think of a sandblaster hose, for example. The basic idea is that the abrasive particles bounce off a flexible surface, rather than carving into a rigid surface.) Web searching for slurry pumps or abrasion-resistant pumps may help. Also ask your usual pump supplier, who may be able to give good advice. An air-powered diaphragm pump might also be suitable.
09/08/2009 11:29 PM
Thanks for your intersst in this issue, I have one air powered pump I am planning to use it for slurry application.
09/07/2009 11:51 PM
Good Answers: 74
09/08/2009 4:49 AM
Cavitation - Wikipedia, the free encyclopedia
Try this information for solving the problem. It takes a bit of reading but could give some hints about what could be really happening. Good luck, Ky.
The Twain Has Met
09/08/2009 11:22 PM
Thanks for interest , I need more guidence on selection of type of impeller & MOC .
09/08/2009 9:00 AM
You may have cavitation along with abrasion. Need more information. I am a pump sales engineer in Detroit Michigan. Supply pump model, horsepower, system requirements of gpm and TDH (PSI), impeller trim, pump setting, and amp draw when pump is new. You need to tell me the pressure right at the discharge when the pump is new.
Joe T
Inga Binga Bunga Banga Boonga Binga Buuuunnnnga
09/08/2009 11:11 PM
Dear,
We dont have cavitation problem only abrasion is the issue, pumps are suitable from the head & flow point of view only doubt is on MOC & type of impeller.
We are using Cast iron casing and cast iron impeller ( closed Type) , now i am intersted in knowing that will it be benefitial for me to go for Cast steel or SS casing & Cast steel impeller for this application. Also what type of impeller is suaitable for same.
09/09/2009 8:40 AM
CD4 hardened cast stainless steel is the hardest material we can cast into pump impellers and castings. The next step is coatings.
Joe T
09/08/2009 1:08 PM
Do you have a lot of back pressure ? Sounds like the lines your pumping into may be too small. If they are too small then expect the same problem with any new pump to same size.
09/08/2009 11:01 PM
Dear Sir,
Thanks for interest, as we are processing slurry , frequent jamming problems are also there thats why our pipeline sizes are on higher side. No undersize pipelines are used in plant.
I am interested in knowing MOC of Impeller & casing for highly abrasive slurry.
Thanks
09/08/2009 11:22 PM
09/15/2009 2:51 AM
try on this site:
http://www.lightmypump.com/
is a wonderful source of info on pumps.
S
corrosion protection & prevention
Register to Reply 16 comments
Anonymous Poster (4); askjoet (2); dadw5boys (2); joravi1 (5); ky (1); strider6 (1); Tornado (1)
