Previous in Forum: Generator Not Able to Take Load   Next in Forum: Old Motor Replacement
Motor Starter
09/08/2009 11:39 PM
Hi All,
I am looking for some guidance, code, practice discussing starting methods applied for induction motors depending on different application, rating of motor, RPM, torque .....I mean how we make dicision to use soft start, VFD or Wye-delta ...Highly appreciate any suggestion/advice. Any link to provide some theory would be helpful.
Thanks
HH
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Motor starter
09/09/2009 1:02 AM
This looks like a homework alert...
It's all about the Boom! - MythBusters
Good Answers: 244
Re: Motor starter
09/09/2009 10:17 PM
Re: Motor Starter
09/10/2009 3:44 AM
Soft starts Pros/Cons
1. Pros:Soft starts are way cheaper than VFD. Use Cutler and Hammer or Square D.
2. You must know your application. If the electrical grid can't provide the juice for your soft start don't use it. Soft start require alot of inrush current to get the motor to full speed. Flicker is your common issue.
3. Cons: You only can start motor maybe 3-4 times in an hour. It you need to start more than that switch to VFDs. The windings on the soft start get really hot quick and well lock you out if you exceed a certain amount of starts or temperature. Again know your application.
VFDs Pros/Cons
1. Pro: Use VFDs when your trying to control flow or level in a tank, well, channel, etc...
2. Most client I work with have the $$$ and typical I always see VFDs around water treatment and waste water treatment plants.
Register to Reply 3 comments
msamad (1); rabat (1); Sapper (1)
