Previous in Forum: Vent Stack Mechanical Design   Next in Forum: SS 316 & SS 316L
Expansion Tank
09/18/2009 10:53 AM
I doubt if an expansion tank is required for a Point Of Use electric H2O heater. Anyone know for sure? This is for a single 4 gal, 120v, 1500w POU H2O heater serving 2 restrooms. Thx.
Good Answers: 40
Re: Expansion Tank
09/18/2009 3:23 PM
The purpose of an expansion tank is to equalize pressure in a closed system.
I see no reason to have an expansion tank on an open system such as a point of use heater
Good Answers: 16
Re: Expansion Tank
09/19/2009 4:21 AM
Definitely NOT required, your point of use heater needs to be as close as possible to the actual point of use. Otherwise you have excessive piping that needs to be heated every time you open your hot water valve.
Will this be possible while serving two restrooms with one unit?
Re: Expansion Tank
09/19/2009 12:03 PM
You need to know how long it takes for the temperature to recover. If the two restrooms have a lot of traffic, you could quickly run out of hot water. For low use, no problem. Might I suggest instead, installing an instant on-demand water heater. They are more economical to operate and can be sized to meet all your needs.
Mr.Ron from South Ms.
Re: Expansion Tank
09/21/2009 11:09 AM
The manufacturer's information leaflet supplied with the equipment and the local plumbing codes have all the answers on this one.
Register to Reply 4 comments
PWSlack (1); ronseto (1); techno (1); Tim in Mexico (1)
