Previous in Forum: Substation Safety   Next in Forum: generator transformer connections
Hydro Electric Synchronous Generator
10/02/2009 5:05 AM
Sir,
Please give a detailed description regarding my below doubts:-
1. How the load of synchronous generator can be varied even though the generator runs in synchronous speed.
2. How the output voltage & frequency can be varied?
3. The Synchronous generator is running in synchronous speed even though the % of opening of water nozzle for the runner is varying and thus the water output from penstock is varying?
4. If negative / positive MVAR introduced to the system, what will happend?. Is this effect the generation?. Is it affect voltage?. Please expain with vector diagram?.
Rgds
BIJU
Good Answers: 97
Re: Hydro Electric Synchronous generator
10/02/2009 7:30 AM
The impulse turbine is fitted with a Governor (sensitive to RPM)
When more power is drawn the wheel will slow down causing the nozzle to open to deliver more water & power.
When too much water is released the speed will pick up causing the Governor to close the nozzle slightly.
The Governor therefore always attempt to keep the volume * pressure in balance with the Volts * Amps at a constant frequency.
10/04/2009 10:08 AM
Good reply
How the excitation current varies ?. Is there any equations?
How the MVAR introduced in the system affects the voltage ?.
Re: Hydro Electric Synchronous Generator
10/03/2009 11:23 AM
Regarding the above I say:
1. Vary the power input to the shaft, i.e., increase the opening of the inlet valve. Keep an watch over the PF.[ Conditions apply like water head.]
2. Voltage can be varied with change in excitation. Frequency can be varied with variation in prime mover input [ if the generator is in solo operation.]
3. Most likely the water head is changing.
4. The generator will be stable within the capability limit. The voltage will decrease with lagging and increase with leading MVAR.
byjuram (1); Hendrik (1); parameshmalakar (1)
