Previous in Forum: Bonding Jumper in Cable Trays   Next in Forum: Frequency Increase Through VFD
11 comments
AC & DC reactors
10/09/2009 5:11 AM
I want to know how new technologies (if any) in designing AC and DC reactors help in reducing their sizes for harmonic filters applications.
Many thanks
Hazem Zubi
Re: AC & DC reactors
10/09/2009 6:08 AM
The equations may be found in any textbook on radio receiver design.
10/10/2009 2:09 AM
I know there is a finite element calculator "maxwell" of Ansoft that can design reactor electromagnetically. However, if the reactor is high power rated, thermal design should be considered too for the accuracy of electrical parameters. Therefore, high rated reactors can not be downsized much, I think, with the classical design.
10/10/2009 5:19 AM
One of the reactor construction methods which can be used is helical windings. -Harit
Good Answers: 80
10/11/2009 10:48 AM
The magnetic material used is the major factor for the size.
If we had a lossless material with extremely high saturation level and permeability, you could shrink these reactors to <1% of the present size.
For the moment, silicon steel is the most cost effective in most applications. And there very little that can be done without adding forced cooling.
If your budget allow it, you can use newer glass metal or iron powder materials with better characteristics and toroidal / pot core shapes. You might cut the weight in half but at a much higher cost.
It all depends on how much you are willing to pay.
10/12/2009 5:34 AM
Thank you for this valuable information.
I need to know during the last and coming decades how are reactors (coils) designers doing to shrink the reactors sizes for power harmonic filtering applications for adjustable speed drives systems (Medium power).
Many thanks
Hazem
PhD researcher
Good Answers: 80
10/12/2009 9:19 PM
Most likely by generating less harmonics using active front end drives. This is what happened (is happening) with switching power supplies. We also do it on our line of large power supplies (100KW+).
Most likely, we will combine fast switching frequencies with smaller inductances made of exotic material. When you increase the frequency, you reduce the weight of your magnetics to a point where expensive high performance material become cost effective.
10/13/2009 11:19 AM
I am designing a passive filter for harmonic mitigation in AC drives application which are common in industry and increasing rapidly. As these filters are usually bulky I have read that new magnetic materials are developed to reduce the size. So I want to know is that true? and how is this trend progressing?
Many thanks
Hazem
10/14/2009 7:55 AM
Hazem, That is interesting, we have good experience designing LV transformers and chokes. you can contace me on mehtah (at) gmail .c0m -Harit
10/14/2009 9:40 AM
Mehtah, the email you send is not complete address.
What and where is your job?
Best rgds
Hazem
PhD researcher
10/15/2009 1:56 AM
Hazem, we design and manufacture transformers and chokes in India. The email is correct, mehtah (at) gmail.com Whats your email? -Harit
10/16/2009 5:04 AM
Mehtah
I send you an email, did you get it?
Hazem_zubi@hotmail.com
Hazem
Register to Reply 11 comments
Anonymous Poster (2); hazemzubi (3); marcot (2); mehtah (3); PWSlack (1)
