Previous in Forum: Instrumentation   Next in Forum: Removing Plastic Liners from Aluminum Soda Cans
53 comments
Moon Elevator?
11/09/2009 11:10 AM
Can a wire be dropped from a geosync orbiting satellite back to earth in such a manner that supplies (maybe even people) can be hoisted from the earth to the satellite or vice versa (like a clothesline)? Will this action cause the geosynced satellite to come out of orbit just a little at a time? And can we supply the fuel to correct this orbit as needed with this line? It would seem a cheaper method of resupplying the space satellite than using manned rockets. Could a shuttle then be used to collect the supplies from this geosync satellite and then resupply other non-synced satellites? If we want to take this question further we could ask if an elevator could be built from the earth to the moon? Maybe we would land on our heads instead of our feet.
Re: Moon Elevator?
11/09/2009 11:21 AM
I think the cable would weigh to much...and it might pull the moon closer.
Dreams are the blue print for reality.
Re: Moon Elevator?
11/24/2009 5:21 PM
Re: Moon Elevator?
11/09/2009 11:25 AM
Yes
Re: Moon Elevator?
11/09/2009 6:06 PM
No
Reply Score 2 for Off Topic
Re: Moon Elevator?
11/10/2009 5:42 AM
Good answer...in that it recognizes an inherent flaw (of reasoning) in the original question - Positing a theoretical (physics) question regarding the possiblity of a space elevator - but coupling it with an "applied physics question...viz: essentially about what would make the theoretical question invalid OR(!) valid? Guests has answered that component of the inquiry which is not fallacious in and of itself.
As to space elevator (or moon... under the right [non-earth] conditions), that was discussed previously on CR4, but was not recognized for what it was!
Re: Moon Elevator?
11/09/2009 11:26 AM
That mass that were raised from the surface of the earth would need to be supplied with energy to keep it there. If it doesn't come from the geosync satellite losing altitude, and changing its speed, during the hoisting operation, where does it come from (rhetorical question)?
It's easier to get rid of the clothes line and accelerate the mass using some form of vehicle. Which is sort-of-why it is done that way.
Re: Moon Elevator?
11/09/2009 12:41 PM
It is possible, not quite technologically feasible yet. I remember reading a story about this several years ago one of the problems is any currently available material would break under its own weight much less putting any load on. Carbon nano tubes show promise as a material that would be strong enough to create such a cable.
http://en.wikipedia.org/wiki/Space_elevator
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Re: Moon Elevator?
11/09/2009 11:01 PM
See also http://www.npl.washington.edu/AV/altvw109.html
Good Answers: 101
Re: Moon Elevator?
11/09/2009 2:02 PM
Any cable long enough would weigh quite a bit I would think. We would first need to blast the whole thing up into orbit before we could "drop" it to earth. Not sure we have the ability to send that type of payload to orbit. If we were to do it in sections, it would be a complicated ordeal to hook the different pieces together while hanging in semi-orbit. Personally I think we need to put more efforts into either the time machine, or the molecular transporter.
Good Answers: 38
Re: Moon Elevator?
11/09/2009 3:47 PM
I remember reading somewhere, years and years ago, that there is nothing man made that will support it's own weight up to 1 mile. Spider silk was the only thing that had the properties that might have worked but we could not duplicate it nor get the little buggers to weave it into a cable.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Moon Elevator?
11/09/2009 6:00 PM
Are you referring to a standing structure one mile high or a hanging object one mile long?
There are countless oil wells and a few deep mines that are well beyond one mile in depth with continuous lengths of cable or piping hanging down the bore holes and main shafts.
Re: Moon Elevator?
11/10/2009 7:11 AM
They might hang but are also hanging in mud the density of which is varied to suite the process required, this supports the drill string and stops blowouts.
Also a cable or whatever from some satellite would be subject to unknown and ever changing atmospheric conditions which would render the idea somewhat difficult to implement to say the least.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
Re: Moon Elevator?
11/10/2009 4:39 AM
A tapered cable will increase the maximum possible suspended length, although it is still not feasible with today's materials.
Good Answers: 109
Re: Moon Elevator?
11/09/2009 4:14 PM
The moon is a non-geosync satellite and thus the project would require a two stage elevator. One geosync and the other lunar sync with a shuttle to catch up with each other as they move apart. There could be no firm attachment between the two bodies.
Re: Moon Elevator?
11/09/2009 6:06 PM
The moon elevator will never be feasible simply due to the earths rotation. Think about it.
One serious problem thats overlooked is that even with an earth to orbit system wind loading and electrical discharge between the earth and the points in the upper atmosphere will create many problems.
If the cable is made of carbon based composites its still going to be slightly conductive and a passing storm that produces 100's of millions of volts of static charge is going to find that even slightly conductive carbon nano tube cable a far better conductor than air.
Good Answers: 12
Re: Moon Elevator?
11/09/2009 11:30 PM
One of the mechatronics professors at UWS (University Of Western Sydney Australia) was working on a similar project...The idea was to make a wind generator up in the air where the enormous wind would hold the generator up there and be held down by the conductor to 'transfer the collected energy' back to earth (somewhat like a kite). While the idea and theory worked, it was the actual mass of the 'conductive rope' that was the problem.
Good Answers: 25
Re: Moon Elevator?
11/10/2009 12:01 AM
Guest,
Even if a miracle line could be produced so-called Geosynchronous or Geostationary satellites are not truly stationary or synchronous. They drift and have to be regularly corrected or they will drift away. They also move about in the so-called stationary orbit in a figure 8 pattern.
Before the moon becomes Geosynchronous or Geostationary the sun will have become a red giant and Earth and moon will be fried.
So much for that dream.
Jon
Re: Moon Elevator?
11/10/2009 12:33 AM
the other thing I wonder is, as the cable is lowered from the bird., what happens to the orbital motion of the cable? doe it remain straight? or does it want to head easy with a faster orbit time because it is closer?
Good Answers: 97
Re: Moon Elevator?
11/10/2009 12:50 AM
I have a better idea!!!! (Pipe Dream)
Why don't we replace the cable with a tube, The tube can help to keep it in position.
The tube can then be used to suck water onto the satellite. Where it can be converted to HHO using the radiation from the sun.
Half the energy can be used to keep the contraption in the sky while the balance can be fed into a down wire.
By the time the electricity reaches the ground the voltage may have increased to 11 kilo Volt (due to gravity) and may be sold to a country using power in 11 steps.
I will leave the other advantages to the imagination of CR4.
Re: Moon Elevator?
11/10/2009 12:05 PM
"The tube can then be used to suck water onto the satellite."
The maximum height that water can be "sucked" up a tube is 15 feet.
Bill Morrow
Re: Moon Elevator?
11/10/2009 10:54 PM
Do you live on a high mountain? At sea level pure water can be sucked about 33 feet up give or take!
Re: Moon Elevator?
11/12/2009 10:45 AM
Oops! My mistake. I was confusing 15 psi with 33 ft. H2O as atmospheric pressure. But anyway, whether 15 ft or 33 ft, it is a long way from sucking water 100 miles or more into orbit.
Bill Morrow
Re: Moon Elevator?
11/11/2009 10:33 PM
Not only a pipe dream, but a wire dream too. With the addition of the water it becomes a wet dream.
Re: Moon Elevator?
11/13/2009 11:53 AM
Naughty Hendrik! Very naughty Hendrik!
Hobbies - Musician - New Member Greece - Member - New Member
Re: Moon Elevator?
11/10/2009 3:39 AM
I had another idea: We could built a metal tower with toothed pilars (this construction could be the tallest construction in the human history!!!) and a "vehicle/elevator" (we could call it "elevahicle") having toothed wheels could roll/move up and down on these pilars. It could get electric energy for its elevation through these pilars and it could restore electric energy during its way down (due to gravity). Again, we are free from cables and all the other problems that arise from their usage.
George
Re: Moon Elevator?
11/10/2009 6:27 AM
There is a small problem with the terminology in this thread:
Geostationary/Geosinc: is an object at approx 34000 km high, remaining above the spot where it was put upon launch. As the gravitation is not always the same (earth mass is moving, the moon passes by , ...) the exact location where the satellite is will vary. But the average position will remain.
How is this possible? By it's own speed, relative to the centre of gravity which is dominant: the earths centre of gravity. This force keeping it up is exact the same as the force pulling it down, the resulting movement is a circle.
All satellites have the speed which keeps them up. Lower orbits need higher speeds as the center of gravity is closer, higher orbits need less speed.
At the geostationary orbit the speeds makes the satellite go round is exact one day, when the direction is correct chosen the satellite will remain above the correct spot on the equator.
The moon is going round in 28 day's: thus it is much further away from the earth than the geostationary orbit, and it has a speed which is a bit to high, so it moves away from us.
When the geostationary satellite needs to carry something hanging in the direction of the earth it will have to pull, this means that the speed needs to go up (higher resulting force), needing to put the satellite in a higher orbit, to keep the geostationary position.
But, while a mass is moving up the speed it has will be the same as on the earths surface. while it has to go up due the fact that is needs to go straight up.
The satellite will have to deliver the energy needed to accelerate the mass travelling up. So it will be pulled down and to the side.
Ahr I feel a drawing would help. Sorry no time.
Unless you find a fixed point up there I fear it is a difficult and costly exercise.
Re: Moon Elevator?
11/10/2009 8:01 AM
"Sorry no time"? You spent half hour yapping about a complete nonsense! Dude, you have WAY to much time in your hands...
Reply Score 1 for Off Topic
Good Answers: 61
Re: Moon Elevator?
11/10/2009 12:35 PM
"The satellite will have to deliver the energy needed to accelerate the mass travelling up. So it will be pulled down and to the side."
Check out the stories at Dave864two's link, or this direct. The latest proof-of-concept experiment used a ground-based laser to provide energy to a photovoltaic array on the cable crawler. It worked amazingly well and powered hte carrier up a 900M cable suspended from a helicopter.
Re: Moon Elevator?
11/13/2009 3:11 AM
The energy needed to travel up is one part of the required energy.
The mass also needs to be speeded up to stay geosinc.
  • At earths surface level we are geosinc, Speed: 1667 km/hr or approx 1000 mile/hr
  • At a geosinc orbit the satellite has a speed of ((7000 + 34000)* 2pi)/24 [km/hr] ≈ 10700 km/hr
  • delta is 9000 km/hr
  • This speed (and the force needed to accelerate) is perpendicular to the force created by the pull force of the satellite, so the up traveling mass will from slow down the top station (and the earth but this is neglectable)
To be short: the whole system needs constant new fuel to keep the top unit at the position.
The helicopter experiment was only to prove that you can power a rope crawler from a distant. the delta in speed was approx 3 km/hr, the helicopter used enormous amounts of energy to keep up in the air, at it's position, but why didn't they use a balloon?
United States - Member - Member in Good Standing
Good Answers: 61
Re: Moon Elevator?
11/13/2009 3:25 AM
Gwen, you are missing the point. Once in place the entire space elevator is place it becomes a simple matter of climbing the cable and the time involved is barely relevant. Since the electricity is provided by a solar powersat, who really cares how much power it takes? The main thing is that the kilogram to orbit cost is a fraction that of using rockets.
DrMoose
Re: Moon Elevator?
11/10/2009 8:20 AM
Re: Moon Elevator?
11/10/2009 10:01 AM
I remember reading this years ago in Popular Science.
http://www.popsci.com/scitech/article/2004-04/space-elevator
Good Answers: 25
Re: Moon Elevator?
11/10/2009 10:04 AM
Guest,
While spinning around on my office chair I stuck out one of my legs and noticed that my rate of spin decreased significantly.
I figured that mankind could speed up or slow down the rate of spin of the earth by grinding mountains down or building all manner of tall structures everywhere.
Of course as with other frivolous projects the progress of the people who took them on had been slowed and their true purpose in life had been deviated. They were supposed to spread all over and populate the earth but decided to stay in one place and play with each other making towers in the sand.
Jon
Re: Moon Elevator?
11/10/2009 1:32 PM
THE TEN COMMANDMENTS:
Now that I called your attention, let me ask:
Hey!! what happened to one of the last posts by a Guest, saying it was tried in the past and referred to a passage in the Genesis?
Was it removed for religious reasons? or in the contrary?.
Even if the content of it was biased, impossible or just against common sense, he had the right to express it and let the rest of us (grown up guys) to consider its validity, read it for its cultural value, or read it just for recreational porpuses.
Besides I didn't take a note of the chapter and versicle, and I wanted to look it up !!!
Please put it back !
Yahlasit
Re: Moon Elevator?
11/10/2009 1:43 PM
Guest,
Are you talking about #24?
Re: Moon Elevator?
11/10/2009 1:57 PM
If you have a "stationary" satellite of certain weight including the cable, and drop the cable down to earth, that will decrease the centrifugal force on it and also pull the satellite down.
If you have the same satellite, but want to approach it from below using a space shuttle that carries the cable, as soon as you attach the cable to it, it will become a load that will take the satellite out of its current orbit (into a lower one) and bringing it down.
Solution? a weightless cable that is also massless to avoid dragging by the winds, I suggest one that is made of opium dreams.
We all are going to die (old and sorrounded by our loved ones I hope) and would have never seen such a thing.
Yahlasit
Re: Moon Elevator?
11/10/2009 2:46 PM
If a wire or a structure were constructed that extends from the upper atmosphere to the ground, would it not become the world's greatest lightning rod? Even if it were built from non-conducting material it would provide a conductive path when it became wet from rain. Remember, this is not a structure with a large cross-section like an office buiding or an airplane. The current of the lightning discharge would be concentrated into a much smaller area. Is there any material/mechanism that could survive such frequent lightning strikes and still function?
Bill Morrow
Good Answers: 25
Re: Moon Elevator?
11/10/2009 2:50 PM
Bmorrow,
To say nothing of the extreme frost and ice buildup.
Jon
Re: Moon Elevator?
11/10/2009 4:28 PM
Come on you guys, open your minds!
http://www.geek.com/articles/news/team-wins-900000-in-space-elevator-competition-20091110/
Re: Moon Elevator?
11/10/2009 9:56 PM
What about the effect they came across doing the 'tethered satelite to the shuttle' experiment when it built up a static charge?
Good Answers: 114
Re: Moon Elevator?
11/10/2009 11:15 PM
If we consider the mass of the rope at the various heights, would it be travelling at the correct speed for them to be in geosync orbit, for the rope to stay in a straight line?
Re: Moon Elevator?
11/12/2009 6:19 PM
"Hi guysthis is an extract from an aryicle on my file that I got 4 years ago"
The theory behind the elevator is simple. First proposed 111 years ago by a Russian scientist, it was popularized by Arthur C. Clarke in his award-winning 1978 novel, The Fountains of Paradise, and goes like this: Earth is constantly spinning. So if you attach a counterweight to it with a cable, and put it far enough away--62,000 miles--the cable will be held taut by the force of the planet's rotation, just as if you spun around while holding a ball on a string. And if you've got a taut cable or ribbon, you've got the makings of an elevator.
So why hasn't anyone tried to build one yet? Because the material needed for the ribbon didn't exist. Until 1991, no substance came close to being strong, lightweight, and durable enough to do the job. Then a Japanese scientist stumbled on an arrangement of carbon atoms that became the strongest material ever tested: carbon nanotubes. Nanotubes are as much as 100 times stronger than steel, yet weigh only a fifth as much.
We shall require a substantially new manner of thinking if humanity is to survive. (Albert Einstein, 1954)
Good Answers: 61
Re: Moon Elevator?
11/12/2009 11:22 PM
All of us have at one time or another tied a weight to the end of a line and spun the thing in the air. A space elevator, or skyhook, is the exact same thing, except on a really huge scale. Of course the tension on the structure would be incredible, and carbon nano-tubes are about the only material available that shows some promise of providing the kind of strength needed for the cable.
As for the actual construction, consider this. If cables are paid out from a satellite both up and down at the same time, tidal forces will hold the structure in a rigid, radial orientation. So, if the construction station is placed in geostationary orbit over the desired location on the equator, the cable could them be spun out from there, and would approach the atmosphere at zero relative velocity. Granted, actually getting it down the last hundred miles will be interesting, but once anchored at the surface and a counterweight such as a small asteroid attached at the far end, the thing would become a rigid structure, and anything attached to it just ain't goin' nowhere.
As far as getting up and down the thing, the most likely method would involve linear electric motors, much like a maglev train. And obviously there would have to be safety devices in place to lock an "elevator car" in place in the event of a power failure. The thing would almost certainly be powered by a solar power satellite orbiting near the geostationary point of the tether. And it would be a fairly simple matter to engineer in the ability to carry the current of a lightning strike to ground, or even to a massive capacitor bank, to harness all of this energy.
The really nice thing about a space elevator is that it would make the per-kilogram cost of lifting a payload to geostationary orbit almost trivial. Of course actually getting the thing off the ground (pun intended) would be a pretty stupendous undertaking. It would have to be built in orbit, and the materials would absolutely have to space-based, since dragging them up from the surface would be ridiculously expensive.
To build this thing is certainly within our grasp. The physics involved is fairly well understood, and everything else is just engineering. Furthermore, the spin-offs of such a project would ripple across the world's economy in the same fashion as did the space race of the 50s and 60s. Now this would have been the place to invest all of those so called stimulus dollars.
DrMoose
Good Answers: 114
Re: Moon Elevator?
11/16/2009 7:32 PM
Difficulty. Maybe what Gwen was getting at, maybe not, but related.
For a satellite to be in geosync. it must be in orbit with a rotation of one circuit per 24Hr day. There is only the one such orbit, increase velocity and you move outward and drop behind the earth, decrease velocity and you drop to a lower orbit and appear to go faster.
Consider a mass being lowered from the satellite. As it is lowered, it's velocity would be reduced, but it's natural orbit at the lower velocity would make it rotate faster than the earth and the satellite.
Perhaps the shaft would have to be a spiral when observed from the N or S pole.
Good Answers: 61
Re: Moon Elevator?
11/16/2009 7:44 PM
You assume that the elevator cars are in a free orbit. However, they are bound to the skyhook cable, which is a very rigid system. As soon as the car begins to descend, it it no longer in freefall. It will in fact only be in true freefall when it is at the geostationary station.
Remember the weight whirling at the end of the string. This is what we have here. The string is our skyhook, and the weight is the asteroid we have attached to the end of it. Obviously, the asteroid is not in a free orbit, it is moving much to fast at that altitude, and the tension it exerts on the cable is nothing short of incredible. The elevator cars moving up and down will be of little more significance than a bug climbing up that whirling string.
DrMoose
Re: Moon Elevator?
11/25/2009 3:37 AM
The asteroid is not hooked at all, the position is only guarantied by the game of forces.
Start adding more forces and you will find that the asteroid is moving his position.
The spiral idea is not so bad, only one problem: the stuff coming back from space has an enormous speed, which will need to be reduced before it hits the first layers of our atmosphere.
But now we assume that that the rope is laid in such a pattern that the lowering mass can use the rope to accelerate/decellerate. again energy which has to come from the masses supporting the rope.
Good Answers: 12
Re: Moon Elevator?
11/25/2009 5:39 PM
Seems like the idea is not too far away....
http://www.newkerala.com/nkfullnews-1-145940.html
Re: Moon Elevator?
11/25/2009 5:47 PM
See post #32. It is the same contest as yours.
Good Answers: 130
Re: Moon Elevator?
09/11/2010 10:48 AM
во гробе моем перейду
Исаак Юдович Ozimov
Good Answers: 25
Re: Moon Elevator?
09/11/2010 2:32 PM
I can see why Isaac Asimov would roll over in his grave. By the way, how is the new bridge accross the horn?
Good Answers: 130
Re: Moon Elevator?
09/11/2010 9:48 PM
Ha! 53
Good Answers: 25
Re: Moon Elevator?
09/11/2010 10:19 PM
How is the new bridge across the horn in Vladivostok?
Good Answers: 130
Re: Moon Elevator?
09/11/2010 10:48 PM
"Проект разрабатывается в соответствии с графиком и финансируются в полном объеме"
Reply to Forum Thread 53 comments
34point5 (3); Anonymous Poster (10); bkar (1); bmorrow492 (3); Chankley (1); charsley99 (1); daffy (2); Dave864two (1); DrMoose (3); G.K. (1); garth (1); Gwen.Stouthuysen (3); Hendrik (1); kevinm (1); kudukdweller9 (5); lyn (1); meched (1); NSS (1); passingtongreen (2); pwr2thepeople (1); PWSlack (2); Quobaldt (1); RVZ717 (1); StandardsGuy (1); Stangrag (1); tcmtech (2); velisj (1); YWROADRUNNER (1)
