Previous in Forum: new member :)   Next in Forum: Reduction in current capacity by half of any 2 pole MCB
GOVORNER
11/15/2009 10:11 AM
WHY GOVERNER IS REQUIRED IN A HYDRO ELECTRIC PLANT
Good Answers: 101
Re: GOVORNER
11/15/2009 10:15 AM
WHY GOVERNER IS REQUIRED IN A HYDRO ELECTRIC PLANT IS SAME REASON WHY GOVERNER IS REQUIRED FOR ANY OTHER MECHANICAL SYSTEM TO GOVERN
Re: GOVORNER
11/15/2009 10:15 AM
TURN OFF CAPS LOCK.
WHY GOVERNER IS REQUIRED? To control turbine speed.
The correct spelling is governor.
Re: GOVORNER
11/15/2009 10:57 AM
Actually it's not required if your electricity consumers could use any voltage and frequency and you were able to provide infinite power.
53 69 6D 70 6C 65 4D 69 6E 64
Good Answers: 97
Re: GOVORNER
11/15/2009 12:29 PM
The main purpose other than frequency would be to balance the flow (energy) of the water with the load.
Re: GOVORNER
11/17/2009 5:59 PM
byjuram; is this generator feeding an existing power grid? terry
Re: GOVORNER
11/20/2009 6:02 AM
Dear Byjuram
As the flow rate of water to the turbine varies, the speed and the freequency also will vary accordingly, so we have to use a governor to control the water flow to the turbine, by adjusting the valve/ flap
Regards
Anand.mandarapu
Re: GOVORNER
02/21/2024 9:47 AM
BECAUSE IT DOESN'T WORK PROPERLY WITHOUT IT.
Register to Reply 7 comments
anand.mandarapu (1); Anonymous Poster (3); DVader1000 (1); Hendrik (1); lyn (1)
