Previous in Forum: Heat Radiation Calculation   Next in Forum: Procedure for Discharge Calculation
Measurement for Moisture on metal surface
01/09/2007 11:13 PM
How to measure a moisture content on the metal (@100gm) surface?????
Re: Measurement for Moisture on metal surface
01/10/2007 7:34 AM
Errrmmmm I will pass on this question, as I don't understand it!
Good Answers: 19
01/10/2007 9:30 AM
Go to google type moisture meters and you will find thousands and thousands of meters to measure moisture on any surfaces
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
01/11/2007 12:49 AM
Not sure about that, but if you put Fluid Film on the metal surface it would be easier the measure it because the moisture would bead up on the Fluid Film and NOT penetrate the metal!!
Don
Check out our home page for specs on "Soft Neon"
Good Answers: 18
01/11/2007 10:29 AM
If you are looking for total moisture just do a simple measurement of weight then dry and reweigh. If you specifically want surface moisture, assuming a flat reflective surface, there are numerous optical systems capable of the measurement.
01/11/2007 11:18 AM
The problem is that we are all trying to fill in the missing information in the questioners' question....
I don't think there is an answer until the question is defined.
John.
agua_doc (1); Campbell Lighting (1); ducon (1); Electroman (2)
