Previous in Forum: Flow Sensors and Flow Measurement   Next in Forum: instrumentation design
Calculating Cable Size and Length
11/19/2009 12:29 AM
I have One rosemount Pressure transmitter , loop powered 24VDC and Loop impedance 600 ohms...it will be installed in the Zone 1 divII
pls tell me how to calculate cable size and length.
Good Answers: 46
Re: cable
11/19/2009 2:17 AM
The transmitters work on a current loop 4-20ma or one of the communications like Hart, field bus, or others. Current loops only one transmitter per loop. Hart communications in multi-drop off one line can have up to 15 transmitters with the analog current set to 4ma output.
I have run upwards of 2000ft on 24ga wire to a transmitter in analog current.
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Re: cable
11/19/2009 2:44 AM
Cable Length You will Find from the-- Instrument location layout diagram
Cable size Your Client specs will specify
As a general if Wire size is 18 AWG
Then,
1)600 Loop Impedance
2)assuming 250 ohms for Control system impedance you have(600-250)= 350 ohms for cable
3) For 18 AWG Wire size 10 ohms for single wire ,(10*2) ===20 Ohms for pair cable
4)(350 /20)*1000 FT= 17500 FT
If your finding the length is more , With respect to plot plan increase the wire size to 16 AWG
Regards
Jose
Re: cable
11/19/2009 3:28 AM
8 more transmitters are there in the same loop.Total 9 pressure transmitter are there of same feature (24Vdc,600ohms)
Communication protocol is HART. mean to say Bell202+4-20maanalog
should voltage drop also be taken care.
is there any selection chart for Metric cables viz: 1.5sqmm/10ohmsfor each cable
Re: Calculating Cable Size and Length
11/20/2009 3:06 AM
Just use BS5308 cable. Size and length won't cause energy-storing capacity that exceeds the parameters applicable to EEx i circuits.
Anonymous Poster (1); josej (1); metalSmiths (1); PWSlack (1)
