Previous in Forum: Finding datasheets on google.   Next in Forum: Is It Just Me?
Coal Consumption
11/19/2009 6:30 AM
What is the standard coal consumtion of 100mw thermal power plant if it operates at 80% PLF?
Re: Coal Consumption
11/19/2009 8:27 AM
It all depends on the coal analysis (%Volatile, Calorific value, Type of Coal, Moisture Content, ....)
Then based on that (if you want approximate, take the calorific value only)
From that- Steam generator Efficiency- TG Efficiency will give you the coal requirement.
Roughly I may say somewhere around 100 Tons/ Hour, if your coal is similar to mine.
11/20/2009 3:03 AM
The calorific value of coals may be found in Kempe's Engineers' Yearbook, any edition.
Good Answers: 137
11/20/2009 4:56 AM
What is PLF? If it means % maximum output = 80 MW, I make it about 26 tonne/h. This assumes coal CV 32 MJ/kg and overall efficiency 35%.
Cheers......Codey
11/20/2009 11:36 AM
If I assume the value 3600 Kcal/Kg of coal,
1 Kcal/Hr = 4.18/3600 KW
3600 Kcal/Hr = 1 Kg/Hr = 4.18 KW
1T / Hr = 4.18 MW (Ideal) = 4.18 * 35% = 1.46 MW (output)
So for 100 MW you will need approx 68 T / Hr.
Anonymous Poster (2); Codemaster (1); PWSlack (1)
