I would be grateful for anyone's help, this is a relatively simple one, does anyone know if it is possible to design a twin Francis turbine? That is, a single turbine powering two generators.
If it is, will the turbine be able to power each of the two generators so that they operate at or can better 55% efficiency, or will the 'twin' turbine/generator simply produce just half the power of a single turbine generator?
I am not necessarily looking to find out if it can produce maximum power from each generator. I am only looking to see to see if it is possible for there to be any kind of output that is better than 50% from each generator if such a design could be done.
