I have developed a Silicone Gel ... from neutral silicone adhesive.
The problem is a chemical reaction with the copper, oxidizing it.
How can I eliminate this oxidation ?
If you're using a moisture-cure adhesive (does it smell like acetic acid?), try switching to a two-part catalyst type. There are silicones that are made to work with circuit boards, that will avoid reactions with copper. Your adhesive manufacturer can probably offer alternative formulations.
" Ignorance and arrogance have more in common than their last four letters. "
Standard RTV is not at all neutral, as the other poster notes it uses acetic acid to vulcanize the rubber. GE make a grade that uses an alcohol base. It is called RTV-162 and is considered "Electrical Grade". It is very metal friendly and I have used it extensively without any problems.
why not try RTV's with platinum cataysts....clean and smell less cures fast and does not react with materials as you have mentioned..worth a try...definetely....wacker have a great range..
