Previous in Forum: Silicone Electrical Isulator Gel   Next in Forum: Variation in Weight
11 comments
Good Answers: 204
Why does cooled rubber shatter if you hit it?
01/12/2007 11:24 AM
Preface:
Being -40C here in Red Deer Alberta yesterday, I got to thinking...
If you cool a material significantly, for example, rubber or plastic cooled with liquid nitrogen, and then hit it with a hammer, it will shatter. If you the same material with a hammer at room temperature, it doesn't. At the same time, steel doesn't seem to change its fractureability proportionally.
As I understand atomic theory, matter is a matrix of atoms, where the valence electrons provide the significant attraction to neighboring atoms, as well as gravity, which is considered very very weak.
Question,
Why does the temperature change this electromagnetic bond? Doesn't this suggest that there is more involved in atomic bonding than just valence electrons, because cooling does not remove electrons... Any ideas? Why would some materials be less affected, and some more, by the cooling. What are the variables involved?
does the magnetic field shrink, or do the electrons slow down... I have no idea, but something doesn't make sense for me with this.
Just curious
Chris
Pathfinder Tags: cooling valence electrons
Re: Why does cooled rubber shatter if you hit it?
01/12/2007 5:57 PM
There are many types of molecular bonding, some strong others weak....#
If you super cooled steel enough you would shatter it with a sufficient impact.
Remember what happened in the antartic with the radio transmitter towers... They held together with solder / lead tin mix... the tower fell apart in the cold just like the petrol can seams did holding the petrol for the Scott antartic expedition....
John.
Good Answers: 120
01/12/2007 10:48 PM
tin changes to another allotrope at low temperatures which has little strength
they call it 'tin pest'
This may have been a factor
http://en.wikipedia.org/wiki/Tin_pest
Per Ardua Ad Astra
Good Answers: 204
01/15/2007 10:48 AM
Yes, very interesting article.. and tragic.
01/13/2007 12:26 AM
-40 C./F. does tend to concentrate your thinking doesn't it? Mainly, what the hell am I doing here! But I've also had a similar experience when the inside plastic door trim on my Chevy shattered upon slamming the door at low temperatures. And being a simple mech. eng. I've also wondered whatever happens to a battery's capacity when cold? Any battery regains strength quite quickly after warming it up. Makes me think about how well an electric hybrid vehicle will function in these temperatures. Are there any elect. eng. out there who can convince me to buy a hybrid?
Quotations from anonymous authors are often the most believable. - Anonymous
Good Answers: 120
01/13/2007 12:40 AM
A rubber in this state is, in effect, a glass. At high temperatures a crack will not propagate because the mobility of the rubber allows stress to relieve. Cool it down and you reach the glass transition temperature = shatter time
http://en.wikipedia.org/wiki/Glass_transition_temperature
Metals can become brittle at low temps for other reasons
Per Ardua Ad Astra
Good Answers: 204
01/15/2007 10:55 AM
Well, I think that this is the answer.. thanks everyone. I was thinking in terms of atoms, and the answer clearly lies more in the realm of molecules, and the geometries at different temperatures... I have a lot to learn here, and thank you for this article.
Chris
01/13/2007 1:12 AM
Hi Chris
This works the same with a glass of water. if you pour a glass of water on the table and hit it with your hand it will just splash. But if you freeze the water then hit it and it will shatter.
Radar
Good Answers: 120
01/13/2007 1:27 AM
yes, and when you warm ice cubes close to their melting point they bounce around like rubber cubes. Well water has no glass transition temp. It is either a crystaline solid at 0C or a fluid at 0C, on either side of the heat of fusion energy differential
Per Ardua Ad Astra
Good Answers: 204
01/15/2007 10:23 AM
Well, states of matter are temperature dependent, so maybe this points in the right direction... if a change of state is a rearrangement of valence electrons into a different arrangement, and changes the geometry of the bonding, which of course affects the propagation of shear and fracture forces, or just forces in general, then "Geometry" is maybe part of the answer I'm looking for.
In a conductor with few valence electrons, there would be few arrangements possible, but as you increase the number of electrons, the geometry can change into more differently shaped structures, and therefore cause changes in elasticity and force propagation. hmmm. Does the speed of light through substances change with the temperature? If you chill the water in a radioactive pool, does the color of the light change? I wonder...
07/08/2010 5:35 AM
Good Answers: 204
07/08/2010 11:05 AM
if you are saying the hammer didnt shatter.. better watch again. in the last few seconds, it does.
thanks for the links.
chris
Register to Reply 11 comments
aurizon (3); chrisg288 (4); Electroman (1); kitenic (1); Radar (1); thermo (1)
You might be interested in: Impact Hammers, Drills, Heat Exchangers
