Previous in Forum: Short Circuit   Next in Forum: Switches or Relays?
10 comments
replacing phase failure relay with ordinary 220VAC relay
11/30/2009 6:45 PM
Engineers,i designed a star delta starter circuit where i used three,220VAC electromagnetic relays to function as and replace Phase failure relay expecting those relays to perform the same functions as phase failure relay. Each relay is fed with each of the 3phases respectively while each relay's Normally Open contacts are connected in Series which its final output then serves as my contorl line which fed control lines.i wired the control line correctly for Star delta starter (Automatic type) using Timer relay. At testing ,when no motor is connected to the circuit,when i intentionally simulated a single phasing fault for each phase,the circuit perfomed gracefully i.e at different time,the 220Vac relays tripped the Control circuit.
Later,i connected motor (7.5HP) to the circuit with no load on the motor,i stimulated single phase fault also but found this shocking results:
case1. when single phasing fault was stimulated,the motor continues to work as normal,i stopped it through STOP pushbutton,later tried to put it on ,not working.
case2. when i removed two phases after the whole 3phase was restored,the circuit trippe immediately through the relay ssytem i introduced
please,i want to know what else i could do to achieve my aim at from case 1 above?.i.e i want the circuit to stop working when asingle phase is outthe 3phase supply.
thanks in anticipation.
Re: replacing phase failure relay with ordinary 220VAC relay
11/30/2009 7:16 PM
you need to put this in the electrical section.
11/30/2009 9:58 PM
I think what happened here is that when you simulated the loss of one 220-V phase, the two relay coils sharing that phase, call it phase A, were still connected in series between phases B and C. Each coil would thus receive 110 V. If the relays were pulled in, they could still remain pulled in even with the reduced voltage. This depends on the drop-out voltage of the coils.
When you simulated the loss of two phases, none of the relay coils had voltage, so they all dropped out.
I'm not sure, but I suspect that if the relays had 127-V (127 ≈ 220/√3) coils and were connected in star, the loss of any single phase would drop out both relays sharing that phase, and your system would work.
Are the three relays less expensive than a single 3-phase failure relay?
12/01/2009 12:20 AM
YES,THE THREE RELAYS ARE VERY CHEAP THAN THE PHASE FAILURE RELAY
THANKS.
12/01/2009 1:40 AM
That makes sense. When trouble-shooting problems like this, it often helps to draw out the a complete star-delta diagram, and to make sure what is still connected to what when any item fails. In particular, you may get part voltages on relay coils, lights, etc., that still form circuits in the system.
12/01/2009 4:19 AM
Three AC relays are O.K to replace a phase failure relay.
We were using this system, at the time, electronic phase relays were not in the markets.
Now your mistake is using three 220 V ac relays. This means that you have connected those relays each across one phase (Say A1 to phase and A2 to neutral) and the neutral.
This is not the correct way of monitoring phase failure. This is wrong.
You should connect each relay between each two phases. Never use neutral.
Therefore your relay coils must be 380 Volt. Not 220 Volt. Because you connect them between each two phases. (Example: One coil betwen R-S, the other coil to S-T and the third coil to R-T)
Then if one phase goes, the corresponding relay will be off and cut-off your control circuit.
When 2 phase goes, it is comic.. If both two of the phases have gone, it means the third phase have also gone. Current, of which coming from one phase, returns on the other two phases. Any of the three phase motor neither works, nor burns in the event of only single phase.
Pls try and let me know abt your results.
Kindest Regards.
12/01/2009 11:49 AM
With relays you are only able to control 3 phase presence at the input of the contactor. not directly at the motor.
At older times we used a relay at the central point of the star - if a phase was lacking, the relay received a potential and tripped off the control.
The coils were 380V (not 220V) - that also helped out with a lacking phase.
12/02/2009 2:46 AM
Dear Yuri
Good idea to connect a relay across the star point of the motor and the neutral.
I have never tried this, and will try as soon as possible. (Considering the coil must be 220VAC)
However I think the control circuit for the motor must be the type of not re-starting automatically.
Otherwise you make a blinker starting and stopping in regular periods.
Regards
Nezih
12/02/2009 4:08 PM
Engineers,i am very grateful to all of u,appreciating all comments made so far,infact u are all great.More comments wil help me and others! I wil put all ur comments into action.Thanks,more comments pls.
12/09/2009 1:05 PM
Dear friend,are u sure of yr cct?Bcos if yr cct for star delta is okay,u need not have problem as in case 1.
It is very possible to use three single pole relays as phase failure.for u to be sure that yr star delta cct or other connections is wrong somewhere,test thesame cct with the 7.5HP motor,but this time,use a direct on line starter and makesure yr motor terminal connection is in DELTA or STAR formation ACCORDING TO YR MOTOR DATA PLATE.If yr cct is okay each of the relays should trip the power contactor of the motor when u simulate a phase failure fault on any of the relays at a time.
I have practically done this and is working on 7.5kw(10hp) motor.Power cct is different.The relays are supplied wt 3phase thru 3 single pole mcbs to A1 of their coils.The A2 of the relays are connected to neutral.From L1,L2,L3,L1 is fed to the input of NO of first relay,output to input of second relay,output to input of third relay and output of third relay to control mcb of yr control cct,from mcb to 95/96 of yr motor overload relay,from O/L to stop button 1/2,from stop button to start button 3/4 ,from start button to A1 coil of yr power contactor and A2 of power contactor to neutral.U must also latch or selfhold the 3/4 start button contact wt 13/14 auxilliary contact of yr power contactor.
This is a simple cct which works normally if yr power and control cct design is correct for both DOL or STAR-DELTA.In my example above,u can easily simulate a phase failure on any of the 3 relays by switching off any one single pole breaker connected to the 3 phases above and yr motor must stop for CASE1 or CASE2 above.
Patrick Whowha
Patrick Whowha
12/09/2009 6:02 PM
I am semolina,in fact the last person that comments is really encouraging me that this circuit can work,i really appreciate this,i know using 380V relay is a perfect sample of this project and everything under the sun is possible when efforts and mind is put to it. I will definitely try everything said here,everyone is highly appreciated by my co designer of this project.............THANK U,VERY MUCH!..............
Register to Reply 10 comments
Anonymous Poster (1); nezihozfirat (2); Patrick Whowha (1); semolina (2); Tornado (2); wareagle (1); Yuri B. (1)
