Previous in Forum: PWHT Holding Time   Next in Forum: Fuel consumption by Deisel generator set
pressure and temperature dew point for compressed air
12/01/2009 1:21 AM
hi all
can anyone clarify the different of pressure dew point and temperature dew poing for compressed air.
Re: pressure and temperature dew point for compressed air
12/01/2009 7:00 AM
Pressure dew point is the pressure, at the system temperature, at which relative humidity reaches 100% and droplets of dew will form.
Temperature dew point is the temperature, at system pressure, at which relative humidity reaches 100% and droplets of dew will form.
12/01/2009 8:20 PM
dear PWslack
why the pressure dew point is using the unit DEGREE CELSIUS , and the temperature dew point also same.In this case ... is it the 2 degree celsius of pressure dew point is same with the 2 degree celsius of temperature dew point.
Actually 'im having problem water carry over ( more condensate) in the air dryer.
is it the pressure dew point is related to the condensate discharge produced by air dryer.high pressure dew point in the air dryer system means more condensate discharge from the dryer.?
syachah
12/01/2009 9:41 PM
syachah
12/01/2009 11:54 PM
You are having water carry over for several reasons. But first, we need to know the air flow going into the dyer, type of dryer ( refrigerated/ desiccant), inlet temperature to dryer, ambient temperature at dryer location, humidity of ambient air, size of dryer (rated flow). Then I can give most likely suggestions for cause of water carryover.
12/02/2009 1:44 AM
Dear Amed
The air dryer specification as follow:
type:refrigerated air dryer ( R22)
Max.working pressure:10 barg
Max.working temp:45 degree celsius
Air flowrate:13.3 m3/min
ambient temperature : 35 degree celsius.
Pressure Dew point: 2-5 degree celsius
Voltage/phase/frequency:230/1/50
The actual problem is the pressure dew point is abnormal...out of design range.
we have measured the pressure dew point using the DP 300 mobile dew point instrument and we get the reading is 18 degree celsius at the outlet of the dryer.with this temperature , more condensate accumulated in the system and cause the water carry over.
you have any idea?
syachah
Good Answers: 19
12/03/2009 2:08 AM
Do you have in-line moisture separators with an air trap at the bottom to drain condensate PRIOR to the Air Filters of the Air Dryer?
While you solve your problem, personally to safeguard my system - I always do this immediately to take away 95% of the load off the air filters.
Steam in-line Moisture Separator : Spirax Sarco/Ayvaz/Gestra
Application: Suitable for air, gas and steam applications
were the entrained liquid load does not exeed 40%
(by weight) of the separator.s maximum gas flow
capacity. This is a traditional looking separator and
many engineers simply prefer this configuration because
they are accustomed to it.
Performance: The Wright-Austin Type T entrainment
separator, when properly sized, installad and drained,
will remove 99% of all liquid droplet and solid particle
entrainment where the droplet and/or particle size
equals or exeeds 10 microns.
Operation: Moisture-laden gas enters the inlet of the
separator where it is deflected in a centrifugal downward
motion. The entrained moisture is thrown to the outer
wall and separated by a reduction in velocity. The
separated liquid falls below the .Vortex Containment
Plate. (VCP) where it cannot be re-entrained. Dry, clean
exit gas is drawn from the vessel center and it flows
upward through the outlet of the separator.
ASME Code Construction: These type T separators
are of welded steel construction in accordance with
section 8. Division 1 of the ASME Code for unfired
pressure vessels. Inlet and outlet connections can be
rotated radially upon request.
12/03/2009 7:57 PM
I do have a few ideas. First your outlet dewpoint is indeed high. On a service call I would be looking at the following things-----is the condensor coil clean ?---what is the temperature of the air going into the dryer ? the airflow you list--is that what the dryer is rated for ? what is the flow going in ? how compressors are feeding the dryer ? what kw are they? do you have an air receiver between the compressors and the dryer? does it have an automatic drain on the bottom ? is it working ? where in the system are you seeing the water ? how far away from the dryer ? I know this is a lot of questions, but it helps diagnose the problem and come to a solution.
Register to Reply 7 comments
Amer--Ed (2); ducon (1); PWSlack (1); syachah (3)
