Previous in Forum: Output Choke in Drives   Next in Forum: Chemicals in Batteries
PLC Ladder Diagram
12/07/2009 7:45 AM
hi all,
how to write a PLC ladder diagram for push button call queue?
I mean call waiting for passenger elevator application
Thanks in advance.
“Thousands of candles can be lit from a single candle, and the life of the candle will not be shortened. Knowledge never decreases by being shared.”
Re: push button call queue
12/07/2009 7:51 AM
12/07/2009 8:14 AM
There is an existing thread running on this topic.
Good Answers: 54
Re: PLC Ladder Diagram
12/07/2009 11:50 PM
This sort of problem is best solved using a clocked finite state machine (FSM). Most problems are. You define each possible state of the system and then define how and when the system moves between each state. This requires a bit of initial thought and understanding, but that's not necessarily a bad thing for a machine designer
Many PLC's have FSM's built in, but if not, then you can usually set one up (on any PLC) using a register with comparison and move instructions.
eg. At start up NUM = 10, IF NUM=10 and Level is LOW then NUM = 20, pump ON. IF NUM = 20 and Level is EMPTY then NUM = 10 pump OFF etc.
One advantage of state machines is that they are easy to fault find, only 1 rung is active at any time eg when NUM = 50, only the statement IF NUM=50 .. is going to be holding things up. (compare this to the boolean spaghetti in most programs).
The speed of modern PLC's means that most programs can be written as sequential operations and it still look like they're operating as parallel.
FSM - Not to be confused with his noodly goodness the "Flying Spaghetti Monster".
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
12/08/2009 5:25 AM
Smells like homework to me....... go to www.thelearningpit.com
or www.plcs.net
cheers
05/30/2011 7:11 PM
12/08/2009 10:08 AM
As mentioned check out this site. http://thelearningpit.com/. They actually have a simulation using an elevator. Writing a PLC program is fairly easy but it also depends on whci PLC you are using. You might also be able to find a programmer through the web site. Good luck
God Bless everyone!
05/30/2011 7:13 PM
Register to Reply 7 comments
Anonymous Poster (1); ffej (1); jamesw (1); juvenalo (2); lyn (1); PWSlack (1)
