Hi Everyone,
I have a problem with GE OM CSI 1000W metal halide lamp in THORN's OQ1000 Fitting
so my problem it, At the site with the same fitting some of the lamps are failing for god knows what reason. What i did i took one of the fitting in which there was a lamp failure replaced with a new lamp (same specs) and the fitting is working fine, i left it open for two days straight and no error such a s lamp failure has occured. so i told the people at the site that there must be an issue with your wiring at the site or excessive voltage is present over there which is causing the lamp to fail. But at the site they have checked another working fitting on the same spot where a lamp failure has occured and the fitting is working fine.
so now i am confused what is the reason for the lamp failure, if i supply new lamps at the site and later on they fail too so it will be a waste of time and money .
Guys i need help Pleaseeeeee
