Previous in Forum: VMC Machines   Next in Forum: Pressure Standards for PN 10 and PN 16 Pipes
11 comments
Anti-Splash Mechanism for Pressure Vessels
12/14/2009 12:11 AM
Hi There!
Kindly refer me to a practical design of Anti-Splash mechanism for Pressure vessels.
Thanx in Advance.
It's ur destiny that took u everywhere u did'nt want to......
Pathfinder Tags: Anti-Splash
Re: Anti-Splash Mechanism for Pressure Vessels!
12/14/2009 1:43 AM
One possibility (among others) would be a perforated plate arranged above the splash zone but below any exit nozzles.
12/14/2009 4:04 AM
Hi!
Guid me to the design literature please.
12/14/2009 2:26 AM
Not quite sure what you mean,
One way we do it, on milk vats to keep it from foaming, is on the inlet, we have a tube with a elbow that channels it to the inside wall of the tank, the product comes exits the tube gently contacts the wall and then the product follows the wall down to the level.
p911
12/14/2009 4:07 AM
Hi!
To be more specific, I am asked to contain the liquid level within the specified limits in pressure vessel. please guide me to the design literature for this problem.
12/14/2009 5:20 AM
So, this is really about level control in a vessel?
The easiest way to get accurate level control is to introduce overflow weirs into the vessel.
12/14/2009 11:50 AM
Hi!
U realy got the point, so please send me some standard practices.
Thanx.
Good Answers: 49
12/15/2009 12:13 AM
The easiest way to deal with this is to check out materials from steam boiler manufacturers and their water level / low water cut-off controls. These can be installed in parallel with a pressure-rated liquid level site glass (a vertical glass tube contained in a pressure-rated housing) so you can observe the liquid levels as well as control them.
The level control will keep a valve open to fill the pressure vessel to the required level, and then shut the valve when the level is reached. Additional switches are available to open a drain valve at over-flow level and to sound an alarm if the liquid level falls below some pre-defined lower limit.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
12/14/2009 10:45 AM
I'm not sure if there really is any design literature on this, other than adapting designs from earlier vessels built in the manufacturer's past. A sketch of the proposed vessel woud help, with all inlets and outlets shown; and pressure, temperature, and fluid specified.
12/15/2009 10:36 AM
Try a dip tube and a level transmitter controlling inlet valves to stop the inflow of material. The dip tube should address your splashing problem; the level control your... level control issue.
12/15/2009 11:19 AM
There are many differeent designs that will work, Splash plate, Defusser, baffle, spreader bar, deflector plate, ect. E-mail me at Processes Unlimited Int. Inc. rflaurin@prou.com and I will send you a PDF example. I will need to know the carteristics are and at what pressure your liquid is entering the vessle in order to determine the best sugestion
Good Answers: 49
12/15/2009 11:39 AM
Two suggestions-
1- Register with the forum to get both a "name" and a way for members to contact you "off-line"
2- Don't publish your email directly- very negative possibilities
Register to Reply 11 comments
Anonymous Poster (1); energygod (2); GameJudge (1); phoenix911 (1); PWSlack (1); rajae312 (3); Tornado (2)
