Previous in Forum: diesel engines   Next in Forum: What Was Your First Car?
25 comments
Good Answers: 74
Weather Record Shattered
12/14/2009 1:42 PM
Edmonton, Alberta had the dubious distinction of having the coldest Dec. 13 in North America. The city beat its previous record by 10 degrees. On Sunday at 5:00 a.m., the mercury plunged to -46.1oC, or -58.4oC with wind chill. For those of you who are still on the Fahrenheit scale, that would be -51.0oF and - 73.1oF respectively.
BRRR!
Bruce
Re: Record Shattered
12/14/2009 2:00 PM
We had those exact same temperatures here last week - except without those funny "-" signs.
The Engineer
Good Answers: 129
Re: Weather Record Shattered
12/14/2009 3:19 PM
Wow. I remember several years ago it got down to -25ºF. That was really really horribly cold. I can't even imagine -50ºF.
12/14/2009 3:37 PM
12/14/2009 4:16 PM
I'm from North Dakota we are used to that level.
Around here an odd way we have to pass the time in the winter is to do the "100" or "110" or rarely the "120". That is to get a 100, 110, or 120 degree F or higher difference in temperature from inside the house to the outside not including wind chill. I have done the 110 a couple of times in my life. Thats where its below -40 F outside and greater than +70 F inside!
Last winter we had an estimated wind chill of around -83 F one night. The actual temperature was below -40 F which is all the lower my digital thermometer will read. It just said 'LO' and we had high winds on top of that which is rather rare at the temperature around here.
Officially I think the coldest recorded temperature for my area came from the Minot air force base at -35 F but they are located on a higher point than the city of Minot and the local populations living in the river valley below the air base regularly have 5 -10 colder readings than what the air base reports.
After a certain below zero temperature its all the same any way. Nothing works, every thing breaks, and you just cuss at the thought of being outside for any reason.
12/14/2009 4:19 PM
-40 outside and 70 inside...thats a warm house.
12/14/2009 4:56 PM
Around here when they build a house they take the engineers recommended heating system capacity and then double it when hes gone! If he said a 75000 BTU furnace is big enough we put in a 150000! We all have friends and family members who have done similar over sizing when changing out older heating systems.
I live in 14 X 70 trailer with 4 inch walls and crappy windows. The factory furnace was 68 K BTU. The first winter I had the place it didn't shut off for about 2 plus months non stop and I slept in my winter clothes a few times.
since then with the heating system upgrades it plus my boiler heat exchanger under it and the other auxiliary heat systems can push around 180K BTU if needed!
12/14/2009 9:17 PM
Last week I had trouble with the gas furnace we had no temperature out side, (it was 0 ), We usually kept it at 66, (set it that way to cut expenses) furnace was turning on and off, I had the thermostat set @72 and was freezing my arse off,
Turned out the condensate trap was blocked. cleaned it out and now the house is warm @ 64....or at least it feels warm.
plus its a good thing my girlfriend made have curtains last fall for the windows and patio door.
Today storm is passing through, temps could drop again....atleast its not blowing.
Good Answers: 97
12/15/2009 12:27 AM
One evening about 15 years ago as I was driving between Minot and Powers Lake with the belly-pan & winter-front on the truck allowing a toasty interior when the drivers door warped due to the temperature differential. That door never would seal right afterwards. Was one of those freaky nights with the sticky fingers of fog like but frozen water crystals hanging and sticking to anything that passed through, funky prism like stuff.
I don't miss that stuff as now reside in the banana belt of the upper mid-west
12/15/2009 1:15 PM
I saw that "Ice Fog" for 15 miles over the 7,000 ft Continental Divide just West of Rawlins, Wyoming back in 1999. My CB antennas grew to the size of fenceposts. Kept my right wheels on the "rumble bars" to maintain control in case I hit "black ice". Shut the truck down for several hours at the truck stop at Rawlins. Somebody tell Owl Gore we have the global warming under control for now.
Good Answers: 146
12/14/2009 5:57 PM
My house is framed with 2X3 and insulated R-2000. But when it drops to -12 or below, the cold breeze off the doors and windows is enough to make you chilly even when the fire is roaring.
The prairies are famous for extreme low temps. We get a lot of high winds that add to the cold experience, but we never had anything like -50!!
I had to shoot sound outdoors once in -22 C. A bit challenging to maintain blood flow, since you have to be very still to avoid making any noise! Brrrrrrrr indeed. My sympathies to the Calgarians!
incus opella
Canada - Member - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Chemical Engineering - New Member Technical Fields - Technical Writing - New Member
12/15/2009 10:42 AM
It's mighty cold here in Saskatoon as well. The temperature outside is -32 C right now, and the weather network won't display the windchill value, but it's something below -40 C according to the radio. Unfortunately we have 5 cars at home and only a 2-car (unheated) garage. I'm glad that my boys set up all the cords so that they can all be plugged in! Our house is one of the few in Saskatoon with solid concrete walls all the way to the roof. I'm not sure what the R-value is, but we don't have any problem keeping the house warm in winter and cool in summer, with much less heat duty than our neighbours who have a much smaller home. Yay concrete!!
As for feeling sorry for Calgarians - No way! The chinooks (warm wind off the mountains) in the area mean that they rarely get as cold as Edmonton or anywhere in Saskatchewan. It's positively balmy as prairie weather goes. When they do get even a brief cold snap, I just say "Welcome to life on the prairies!".
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka" but rather "Hmmmm... that's funny". - Isaac Asimov
12/15/2009 8:26 PM
I hope your using the silicone rubber type cords rated to -40! I went to unplug in my vehicle and snapped my cheap plastic one in four places like it was made of glass just by tossing it to the side.
Good Answers: 22
12/16/2009 1:19 PM
I think you may have an issue with the decimal point in your data. If your framing is, in fact, 2x3, the inner wall space would be about 2-1/2". If you have installed closed-cell foam insulation, which I believe offers the greatest "R" value per inch, ~6 in aged value, you could have an R-15. In order to have R-2000, you would not need any framing, as you would effectively have an "igloo" of foam with walls over 300" thick. Not very likely, practical, nor cost-effective.
Also, if you did have an R-2000, you would likely not feel, see, nor hear anything but your own breathing and voice.
Good Answers: 146
12/16/2009 3:24 PM
Sorry badly worded and big typo - it's 2X6 not 2X3 (that wouldn't even be up to code!). The R-2000 standard is an energy efficiency standard, not insulation alone. The insulation needed to meet R-2000 depends on various factors, like climate, architectural design etc.. It's a Canadian thing.. http://www.oee.nrcan.gc.ca/residential/personal/new-homes/r-2000/energy-efficiency.cfm?attr=4
incus opella
12/15/2009 4:14 AM
Ironically, if global warming kicks in, and the gulf stream: which keeps us (the UK) at the same temperature all year round, turns off, I guess we can look forward to similar temperatures.
12/15/2009 5:17 AM
Thanks for the info, I justed started on a job in Calgary (the job is being done out of our Edmonton office) and will be travelling up that way in the next couple of weeks. Lucky me.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
Good Answers: 18
12/15/2009 7:15 AM
Fear not, global warming is on the way.
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
12/15/2009 8:27 AM
My brother who lives along the Pacific in Alaska is averaging around 33 F right now. Last year they had some warm spells up around 60 F.
John J Baker
Good Answers: 39
12/15/2009 12:45 PM
The things I have to live through to make the news. . Minus 40 is what we call half-cigarette weather, still going out for a smoke, but can't stay out there for a whole one. Last time my city made news was,
the 1998 Ice storm on the eastern edge of the continent.
And i moved across the country for this?
All that is required for evil to succeed is for good men to do nothing.
Good Answers: 93
12/16/2009 9:55 AM
Sometimes I can't believe I lived through winters in Chicago, and Rochester and Toronto. Never quite as bad as this report. No wonder such a good number of Canadians move to Florida to retire.
Remember again now the time I had to walk across Rochester during a cold snowy night, and I wore my motorcycle helmet as it was the warmest "hat" I had.
Down here in central NC, it really is nice. It's been raining a good deal, more like normal. Couple of years ago had a drought so severe there was not even morning dew.
Was up in Maine once and noticed up that way they built the barn for the cows, and the house for the people together so as apparently to capture the heat of the animals.
P.S. I want to thank ba/ael for including in his post both temperature scales. Courteous of him in my opinion.
You don't get wise because you got old, you get old because you were wise.
12/16/2009 10:36 PM
Building the barn, house, etc together also lets you go from one to another without going outside and, maybe, getting lost in a blizzard or buried in 12 ft of snow.
12/17/2009 7:27 AM
We also sometimes get cold weather , at least overnight, perhaps once or twice every few years.
Winter before last it got down to a little over 7C (about 45F).
Talk of the town for ages!
We always complain if it gets below 15C (about 60F), but it is always over 20C (68F) during the day.
Worst I had was commissioning a pumping station near Young (NSW). A tap had been dripping and had built an interesting ice stalactite which persisted most of the day.
Seriously, I can't even imagine what it would be like at the temps you fellows experience.
12/17/2009 9:43 AM
That big a swing must not be no cloud cover?
12/17/2009 9:14 PM
Winter is usually fine, with little cloud.
My solar water heater works much better in winter than summer. In fact I oriented it towards the east to improve summer performance
Good Answers: 74
12/18/2009 1:19 AM
Well, we had a few chilly days, but now the mercury has risen to -1oC (30oF) so it looks pretty good for the next couple of days. Time to take off my shirt and get a little sun tan.
Bruce
Register to Reply 25 comments
Anonymous Poster (2); Apothicus (1); artsmith (2); ba/ael (1); bakerjohn (1); Bayes (1); bhankiii (1); bwire (1); d_m_rosenberg (1); Data (1); Doogleass (1); GRAY HAIRED OLD GOAT (1); phoenix911 (4); Randall (1); sceptic (2); tcmtech (3); Transcendian (1)
You might be interested in: Weather Instruments, Reed Switches, Cable Assemblies
