Previous in Forum: Industrial Water Softener   Next in Forum: Correlating ANSI Standards to DIN Standards
61 comments
Formula for Nut Sizes and Wrench Sizes?
12/21/2009 7:21 AM
Is there any formula that show the relationship between Nut and it's wrench. for example a nut with size 1/2" has a wrench No. 22
is there any formula that show relationship between 1/2" and 22?
Re: Relationship between size of nut and it's wrench
12/21/2009 7:26 AM
12/23/2009 3:36 AM
GA
handy link from that thread:
Confirms Blink's post below
12/21/2009 7:43 AM
I am not comfortable with imperials .
But spanner no 22 seems to be 22mm which will almost suit a 1/2" nut @20.83
A link is here
Good Answers: 68
12/25/2009 11:57 PM
Hi Guest,
I think you may have gotten confused somewhere along the line.
The nearest metric size to fit ½" is 13 mm.
Are are you referring to the shaft of the bolt as ½" so the 'head' of the bolt will be 22 mm?
Good luck.
12/26/2009 12:45 AM
Unless it is an extra heavy nut, the standard size of nut for 1/2-inch bolts is 3/4 inch ≈ 19 mm. Not that one should mix these systems in the first place, but sometimes ya gotta do what ya gotta do....
There is a range of bolt sizes in which the nut size is 1.5 x bolt diameter, but this is not consistent in small and large sizes, so one must consult literature rather than attempt to calculate.
Good Answers: 68
12/26/2009 1:34 AM
Hi Tornado,
How you doing?
I think I might have read the question wrongly.
I am guessing when I say the UK metric size for 13 mm/ ½" nut is ~ ¼".
I read the nut size and did not think of the actual bolt shaft size much.
I just saw 22, which I assumed was 22 mm, and the Metric (½") is 13 mm, not 22 mm.
Sorry not well written.
Take care and good luck.
12/26/2009 2:11 AM
This whole issue is complicated by large-head nuts, nonstandard sizes, differences between US/metric, and not even God knows what else.
That said, there is virtually no relation between wrench size and bolt diameter, except in the range of standard sizes from 3/8" to 1" bolts or so (where nut size = 1.5 x bolt size). Even there, the variations almost outnumber the usual combinations.
That's why my original somewhat facetious post said wrench = nut + ~.005 (enough clearance to avoid interference). In the field, if someone stole the 3/4" socket, you make do with 19 mm (if they didn't steal that as well). And vice versa. Nuts and wrenches are relatively forgiving; don't try this with taps and dies. For metric bolts, use a metric Crescent wrench (250 mm vs 10") ?!?!?
Good Answers: 68
12/26/2009 8:35 PM
Hi Tornado,
Hope you had a nice holiday so far?
I am alone, but at least there is no one to argue with?
Yes I know what you mean. It is an interesting question but especially on larger sizes I just make sure I have the correct one or two wrenches!
I remember when I was in my teens, the be all and end all was the 'socket set' with the largest amount of sockets! Probably the most sockets I ever used was 6 to 8 in number, not size. yet I still had another 25 to use when and IF I ever bought something the the half dozen I used did not fit................. Have you ever found a ¼" nut that cannot be undone with an adjustable? Perhaps the smallest I have found that I came across more than once is ⅜", and that was on a tiny tape recorder.
In truth no one really needs more than perhaps a dozen sizes. I do not have the space and have not worked on engines and such for about ten years so I make do with adjustable wrenches now. Three covers all the jobs I am ever likely to do!
I find with working on computer and the like, and I was going to say what I found most useful, and what is mostly used on such machines, ......... but I have forgotten! They look more like a screwdriver than a wrench. Sorry my brain failed me when I needed it most!.................... But, hey what new! It always does.
Take care and enjoy the rest of the holidays!
12/26/2009 9:24 PM
Babybear,
The holidays are going great. Except for some plant checks I have to do, it's 3.5 days off for Christmas and 3.5 for New Year's.
In January or February we are installing an evap condenser. That'll be nasty--cold/snowy/rainy.
Refrigeration (which I have designed and operated for some 30 years) crosses over a variety of trades and disciplines, so I find much of interest in the CR4 forums on a range of topics.
I've done seasonal Alaska work in the past, but this is a year-round position. My wife is with me; she does a fair variety of art and has sold a few items in a local gallery.
Ketchikan has about 14,000 people on the island, with a pretty good music/play/art scene for a small town.
Good Answers: 68
12/27/2009 4:43 AM
Hi Tornado,
appreciate all the detail some of it person, thank you for that!
I am please you have your wife with you, it can make the difference to a job in the not so nice weather going smoothly or not? After all if you were alone you would be worrying half the time about her and any other Family you have?
Does you wife have any pics on her Art Work?
If I understand it right, you get 'holidays' but need to stay where you are to run the Plant? So it is a holiday, but with 'strings'?
Good luck with the install of the Evap/Condenser. We had about 12" (30 cm) of snow about ten days ago but most of it has gone now. It had a chill factor of minus 9 °C. It is a little warmer now. I bet it is just a 'little' colder where you are! Sounds like you are more or less your own boss with that much responsibility?
Something I had in my last job. If I did not work (which was never because I worked with not a single day off), unless I planned it like at summer holidays, nothing happened. But I could not afford not to plan work for when I was on holiday. My job was not so important as yours, but nothing was made and sent out if I was not there. I could have only one week at a time on holiday. Just a small time production job I did, but I was completely in charge of production and stripping the machines down once a year at least which made things interesting. And it was nice to set my own goals and achieve them! 12 hour days with 4 hours journey time in total per day was a bind but it was a great job with a lot of planning.
I will look up your island on google to see how far north you are.
Anyway, Take care
12/26/2009 10:57 PM
I think you are thinking of a nut driver. They certainly are very handy. A jeweler's screwdriver is great for that small stuff too.
Lehman57
Good Answers: 68
12/27/2009 4:52 AM
Hi Lehman57,
Thanks for the reply post! And I hope your holidays are going as OK?
I remember the name now. It is Torx? I think that is what the screwdriver like small nut and screw tighteners are called. Torx Bit Drivers.
Is that what you lean? If not can you please send a link, if you do not mind?
Take care
12/27/2009 5:55 PM
Hi bb - hope all's well with you.
FYI, 'torx' is name of a specific security-type screw head.
Here's the head (countersunk version):
& here's the driver:
The hole in the head is to accomodate the 'pip' which some versions have:
Cheers,
John
Good Answers: 68
12/27/2009 11:48 PM
Hi JohnDG,
Nice to hear from you John.
I was and am thinking about Torx, (I remembered tonight!) because I am into knives and a lot of them are constructed with Torx. I rightly or not, also had the impression computer backs were also bolted on with the same system. Forgive me if I was wrong. BTW, great illustrations!
I tend to know what I am looking for but do not know what they are called, that is the Torx system drivers. Very small fasteners.
Take care and I wish you the best of luck.
12/27/2009 6:25 PM
Torx? No, not what I was thinking. JohnDG's photos are a good illustration of a Torx driver & fastener. As far as I know they are not used on the little fasteners like inside a computer.
What I was thinking, a nut driver, is like a small 6-point socket on a screwdriver-like handle; it does hex nuts or screws. I have seen them up to 1/2". These are similar to using a standard socket on the end of a socket extension.
Lehman57
12/27/2009 7:41 PM
Thus:-
(best snaps I could nab at short notice).
12/27/2009 7:52 PM
The best nut drivers have a hollow shaft that can accommodate the screw projecting beyond the nut. That way, you can tighten the nut all the way down.
12/27/2009 8:10 PM
Agreed! So bloody frustrating when the nut stops (or will not start) engaging with the tool because the screw/stud/whatever is too long for the tool.
Another big frustration is a nut spinner with in unnecessarily large OD, when the nut is close to any other projection (side panel, neighbouring nut etc.). I used to have one (5.5mm A/F to suit M3 nuts) which was ground down to get to all but the tightest of corners. Someone nicked it .
Good Answers: 68
12/28/2009 12:00 AM
Hi Tornado,
on the whole I do agree with you. but there is items like small folding knives which do not have room to use ¼" fasteners, and of course raised fasteners are a no no of a knife for the most part anyway. The Torx on a folding knife do not need to deal in a great deal of pressures, really just need to hold the various tools and other implement aligned, rather that tightly together.
Hey, all the bast kind of wishes to you..............
01/04/2010 6:35 PM
I prefer socket head screws to Torx. They allow you to use a ball end driver that allows you to access a screw from an angle, very important some times. And yes they make Flat head socket screws that would work nicely in a pocket knife assembly. I have used them with threads as small as 0-80.
Good Answers: 68
01/05/2010 6:30 AM
Hi Maxxx,
The screws I will be using the Torx things on will be on a bench so no problems with getting at them. Though ususally I would think the same way!
A whole lot of knives (folding) use Torx and that is what I am referring too.
Take care.
01/05/2010 10:09 AM
There are many benefits to Torx not the least of which is a secure engagement between the tool and fastener. If I designed things that were not such complex assemblies with intense manufacturing demands I would use Torx where I could. As it is, assembly line and or cell versatility makes socket heads across the board my best friend. If I do my design carefully I can allow manufacturing to set up only a few hanging pneumatics with as few sizes as possible and they can assemble any of multiple sub assemblies with the same tools. OK we may be off topic from wrench size -vs- nut size but in reality the entire subject seems to have been off topic from the beginning.
Good Answers: 68
12/27/2009 11:54 PM
Hi Lehman,
Yes you are right. I think I may have been mistaken about Torx on desktop computers, but they are on some laptops.
Take care and I wish you well!
12/29/2009 7:21 PM
"This whole issue is complicated by large-head nuts, nonstandard sizes, differences between US/metric, and not even God knows what else."
Non-standard sizes! Just this afternoon I was using a 19/32" wrench on a nut for a 5/16" stud. 5/8" was too loose & 9/16" wouldn't fit! And it was not metric since it was made in 1925--but I must confess that I have replaced those nuts.
Lehman57
12/21/2009 7:45 AM
" a nut with size 1/2" has a wrench No. 22"
My nuts with size 1/2" has a wrench 1/2"
There's your problem. Get a set of wrenches with the dimension of the nut on them and throw those wrenches with whole numbers in the trash.
12/21/2009 2:41 PM
a 1/2" nut does not use a 1/2" wrench.
12/21/2009 3:03 PM
"a set of wrenches with the dimension of the nut on them"
Good Answers: 247
12/22/2009 12:42 PM
Nut size is ambiguous. In the US, a 1/2 inch wrench fits a 1/2 inch nut -- you'll never convince mechanics otherwise.
With respect to wrenches, the nut size is the dimension across flats. However, a 1/2 inch nut (measured this way) actually fits a 5/16 bolt or stud (which is measured on the diameter).
Making it even more inconsistent is the fact that nut sizes (across flats) are not consistent with respect to the bolt size, with fine thread nuts sometimes having a different dimension across flats from coarse thread, in the larger sizes.
The metric nuts are better but also inconsistent. If you work on European cars, you use a 13mm wrench very frequently. If you work on Japanese cars you never use one, but instead use 12 mm wrench for 8mm bolts.
Then there are the two curses inflicted on the world by the British Empire: BS and Whitworth.
12/22/2009 4:34 PM
Good! American and Metric have the wrenches labeled with the size across flats of the nuts. However the BS and Whitworth are labeled with the stud/bolt size I believe--not the nut XF size.
Then consider that regular hex and heavy hex nuts for the same bolt size take different wrench sizes because the XF size is larger for the heavy hex.
Lehman57
12/23/2009 3:40 PM
01/04/2010 11:17 AM
How could someone score me as "off topic" with my ???? when it's a direct reference to a Guest's comment that one does not use a 1/2" wrench on a 1/2" nut? What reply could possibly be more "on topic"?
Good Answers: 68
01/04/2010 4:45 PM
Hi Maxxx,
Just a guess here, but it may have been because someone has seen "???????" and thought you said nothing? I know what you meant but, it does not follow all did?
Take care
01/04/2010 6:26 PM
Thanks BabyBear for understanding this simple old engineer. They'll be telling me next that a 2x4 isn't 2" x 4"... So do "Off Topic" votes count against your life points in this game environment?
01/04/2010 6:46 PM
I assure you, you can amass as many off-topic votes as you like (or don't like) - you won't get GAME OVER here (that way ).
Good Answers: 68
01/05/2010 6:34 AM
Hi JohnDG,
regarding off topic stuff................
I think it is a good idea to keep an eye on what is happening. Not very often but, sometimes there is what I can only describe as 'vindictive' voting?
Then is the time to write to admin !
01/05/2010 9:54 AM
Well looky there John and Babe. Isn't that interesting. Even though our little sub string is very clearly marked as purposely off topic we are being voted "Off Topic". We're up to 5 now. This really is an interesting social microcosm isn't it. Those that get it and those that don't. Without a little "Off Topic" commentary, being an engineer would drive even the best of us a little wonky. Maybe that's the issue with our anonymous voters.
01/05/2010 10:26 AM
If you mark (or vote) yourself off topic, it automatically tots up 5 votes. Also, if you reply to an off-topic comment, it inherits the "off-topicness" unless you uncheck the off topic checkbox before posting.
They're not out to get us, honest.
[As an example, I've just unchecked the off topic box on this post].
01/05/2010 11:15 AM
I appreciate the education. Allow me to compliment you JohnDG... and babybear, and Tornado, and a few, very few, others who really rock with good information presented clearly. Not just on this thread but on also on others I have seen you guys prominently. Even when, on occasion, the question, primary or secondary, should not have needed to be asked or maybe is asked in the wrong way. Case in point... this thread... nut size -vs- wrench size. You guys gave reasonable and helpful answers when my first response to the question was that it was a joke. 1/2" nut = 1/2" wrench, 19mm nut = 19mm wrench. But you guys, quite reasonably, get into many issues that I would not have thought to discuss. I'm still not sure what the original question should have been. Is he actually looking in fact for a correlation between (Thread size) and nut/wrench size? This I would have taken seriously. I will learn this lesson form these few of you... that I should try to be more introspective when reading these requests for help and maybe try to figure out what the questioner really needs to know. This really is an educational forum. You really are good guys. (Assuming "guys" is the appropriate term here babybear)
Good Answers: 247
01/05/2010 3:23 PM
Welcome!
The answer, I suppose, is "who the heck knows?" Often, the original poster will come back to clarify the question, but not infrequently, he never returns.
My guess is that the poster is from a country in which "inch size" wrenches are uncommon, but has had occasion to work on equipment that has "inch size" bolts. Although the nut on a 1/2" bolt is usually 3/4" (which is close enough that a 19mm wrench usually fits) perhaps he found a 1/2" thread size bolt or fitting to which a 22mm wrench could be successfully applied (spark plug? 12 point socket on square-headed bolt?). A 13/16" spark plug wrench is close enough to 22 mm that a 22mm wrench could be used to remove a spark plug, I suppose. (He may be also be generalizing from British Standard or Whitworth, which would surely throw a spanner into the works of coming up with any sort of formula.)
But unless he returns, we will never know what he had in mind.
(Incidentally, I share your like of ball-headed hex keys, although I cringe a little when using them, because when they are tilted, the engagement goes from 6 lines to two points.)
01/05/2010 8:07 PM
My take on the OP's question was:
"is there a rule like: 'B size bolt needs a B x 1.5 AF spanner, except after 12.4mm add 2mm' (etc)"
As we (all) know, no such relationships exists.
01/06/2010 9:42 AM
Thank you guys for showing me the sense of community here. When I first came across CR4 I thought it was a cute time killer for times when the work load was light. This small group, you know who you are, has changed that perception for me. This is a real resource for serious answers as well as tension relief through a little peppering of humor. Love it!
Good Answers: 68
01/06/2010 1:00 PM
Hi Maxxx,
You have encapsulated what the site is in your few words! Do not forget there is other part of the site science etc and parts you can search for publish info as well!
Take care
Good Answers: 68
01/06/2010 12:32 PM
Hi Maxx,
I really appreciate your note and really all I do is try and give an accurate answer. When the question is not clear and or the questioner does not return, which I think is the case on this thread although I for one have learned a lot of stuff about wrench and bolt sizes etc, we will never know what the OP, (Original Poster) meant!
I try to give the thread a helping hand by reading between the lines. Often I realise the OP does not have English as a first language so you have to 'interpret' somewhat?
Take care and good luck with the rest of your time on CR4!
01/06/2010 8:25 PM
Sure is off topic, but I'm glad you said OP = Original Poster. I figured that, but had never seen it stated. Thanks.
Lehman57
Good Answers: 68
01/07/2010 8:58 AM
Hello Lehman57,
Well here's another off topic which I have listed as 'on topic' to allow others to see and perhaps find their own pictures of odd-ball-item to ask questions about!
I thought I should put what the meaning of "OP" was as I was replying to a relatively new member and they may not realise?
Do you have any other "can you guess what this is" questions, lined up? I really like those.
In the 'old days' the skilled artisans needed these 'instruments' to do what is now done in a factory and the item is delivered complete and ready to fit or ready working? My Father has a whole lot of stuff but most unfortunately went rusty when the cellar flooded.
Take care and all the best kind of luck for the coming year!
Good Answers: 68
01/06/2010 12:21 PM
Hi JohnDG,
I was wondering where the off topic votes came from when we sent a post as 'off topic'. Now I know, thanks!
Take care
Good Answers: 68
01/05/2010 6:27 AM
Hi Maxxx,
No I am pretty sure they will not go against you!
Does kinda make you wonder about some peoples Math and thoughts thought?
Take care
Re: Formula for Nut Sizes and Wrench Sizes?
12/21/2009 6:24 PM
I don't believe there is any "formula", but there are published standards.
Here's a handy chart:
http://www.imperialinc.com/pdf/A_CapScrewHeadWrenchSizeChart.pdf
12/22/2009 12:37 AM
Wrench size = across-flats nut size + ~0.005 in.
12/22/2009 9:55 PM
Please translate your motto. all I can get is wine,truth,throat,song,and water.?
Not edumacated in Latin.
thanx.
12/23/2009 3:32 AM
Looks like:-
In wine, truth; in beer, peace; in water, E coli (a nasty stomach bug).
to me, but, like you I've got no Latin.
12/23/2009 9:38 AM
In wine truth; in beer song; in water a species of coliform bacteria.
Adapted from the slogan of a microbrewery (Cirque) some friends owned.
"Carmen (pl. carmina" can also mean poetry, but "song" is what I had in mind.
12/23/2009 11:32 AM
Somewhere I think we are about to miss the [bolt] boat..Being in the wrench grabbing field from my very early years and head set against the metric system, I'm now 74 and have to realize I do have to use the knowledge I've gathered under the hood, tho against my head set judgements. The metric system is here to stay..so lets use the antiquated knowledge we have and adapt..Neat 'huh'..A half inch bolt does not use a half inch nut, the wrench to fit a 1/2 inch nut is 1/2 american standard. Truly you will find a Metric wrench that will closely fit, 13mm..'closely' meaning you will round off the nut on multiple use. Bolts are not nuts, wrenches are made to tighten nuts to bolts regardless of the size of the bolt..A metric nut will need a metric wrench.
Jim
Good Answers: 68
12/26/2009 12:03 AM
Hi Farzad,
What wrench to use on the size of bolt - Page 2 - OnlineConversion ...9 posts - 2 authors - Last post: 21 Oct 2008If useing extra heavy nuts add 1/8th to your wrench size. ... slot) the formula is Width Across Corners = Width Across Flats/cos(30deg) ...
forum.onlineconversion.com/showthread.php?p=55319 - Cached
Spanner Jaw SizesThis page has a useful chart for comparing spanner sizes (a wrench in the USA) and common nut/bolt use. Although it is believed to be correct, ...
www.sat.dundee.ac.uk/~psc/spanner_jaw.html - Cached
Is this what you mean?
Good luck
12/29/2009 1:01 PM
Hi farzad,
Thanks for this thread.
thoughts becomes things.
i need atable for bolts and wrench sizes
04/25/2010 2:57 AM
hi please help me
Good Answers: 75
Re: i need atable for bolts and wrench sizes
04/25/2010 9:50 PM
With what? That isn't even a reasonable request.
Re: i need a table for bolts and wrench sizes
04/26/2010 5:10 AM
Good Answers: 75
04/26/2010 10:28 AM
Good link. I'm glad you understood what he (she?) was looking for. I presume this IS the answer for which he (she) was looking.
02/03/2025 7:48 AM
02/03/2025 7:54 AM
According to reports, then, a <...22...> millimeter-across-flats spanner fits a <...1/2"...> Whitworth nut even without the use of inappropriate apostrophes.
It's no big deal, is it?
Register to Reply 61 comments
Anonymous Poster (5); babybear (17); Blink (2); JohnDG (7); jtd405 (1); Lehman57 (5); lyn (2); Maxxx (8); micahd02 (2); pantaz (1); PWSlack (1); Randall (3); sandeep lokhande (1); Tornado (6)
You might be interested in: Nut Runners, Nut Runner Controllers, Wrenches
