Previous in Forum: Battery AH Rating   Next in Forum: NGR Sizing for Three Parallel Generators
Maximum Safe Voltage in Hydrocarbon Plants
12/27/2009 9:32 AM
Dear friends,what is the safe voltage limit that can be exposed in the hydrocarbon plants.....can we use battery operated ordinary device/meters in field ?which standard represents that?Thank you,....
"Know something about everything and everything about something"
Re: Safe voltage in the hydrocarbon industries......
12/27/2009 1:57 PM
I think its inversly proportional to the level of stupidity of the workers involved.
Smart workers may handle many hundreds of volts without ever causing problems. But the right idiot could manage to burn the whole place down with nothing more than a near dead AA battery as the ignition source!
12/27/2009 3:49 PM
See:
NEC Division 1 versus Division 2 locations.
NEMA-9 explosion-proof enclosures.
Explosion-proof (XP) motors.
Conduit sealing fittings and techniques to prevent explosive vapors from entering.
Intrinsically Safe devices.
There is a lot to this, well beyond forum-type answers.
12/27/2009 5:03 PM
Tornado is right.. Even voltage down 24 VDc can cause a spark that will ignite a hydrocarbon leak.
If you are using meters that are not intrisically safe, then you need to use a sniffer and make sure that there are no hydrocarbon leaks in the area, along with the proper hot work permit.
Re: Maximum Safe Voltage in Hydrocarbon Plants
12/29/2009 7:58 AM
Register to Reply 4 comments
PWSlack (1); Steve S. (1); tcmtech (1); Tornado (1)
You might be interested in: Planters, Plant Growth Chambers
