Previous in Forum: Least Material Condition (LMC) and Hole Size   Next in Forum: welding
Defining Torque for Different Parts
12/29/2009 1:22 AM
how to define torque in two different parts like Alluminium & cast iron joint, metal to plastic joint.etc
Re: how to define torque in two different parts
12/29/2009 2:11 AM
Are you speaking about a torque being applied to the joint itself, or about the torque applied to the bolts that may be part of the joint?
As for the main parts, the torques they exert on each other are equal, but in opposite directions of rotation.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Defining Torque for Different Parts
01/03/2010 9:42 AM
Hello Guest,
Are these joints critical? Could the loss of joint integrity result in loss of production, property or even life? If your answer is "yes", this is the proper way to define torque:
  1. Analyze your joint to determine the required clamp load
  2. Calculate bolt elongation at that clamp load
  3. Take a wild-a** guess at what the friction factor might be
  4. Use the above answer to calculate a torque figure
  5. Specify this torque value along with the required clamp load and bolt elongation
  6. Provide a bold warning to state that the specified torque will likely not result in the desired clamp load (Why not? Look here)
  7. State that bolt elongation should be measured while "torquing"
  8. State that the specified torque is only to be used as a general target in order to achieve the required elongation
  9. Specify that a record of all bolt elongations is to be maintained for QA management purposes
Best regards, HeviiGuy
